Old April 30th, 2013, 02:08 PM   #1
agentbad
agentbad's Avatar
Idle/Start issues with 2005 Ninja 250
I just picked up a used 2005 Ninja 250 a week ago and now having some starting issues with it. It has 5800 miles on it and other from a few scratches here and there it seems to be in good shape. To get it started I often have to turn the idle up a bit and after 30 seconds to a minute it will get warmed up and I can turn the idle back down and all is right with the world. If I give it any throttle or choke before it will die. If I give it little throttle after maybe 30 seconds it will bog down a bit but usually keep going. The previous owner said he just had the carbs cleaned recently so what else could it be?
Old April 30th, 2013, 02:11 PM   #2
Welcome Bob, seems like cleaning the cabs (idle jets) is in order, take the prev owner at face value? Maybe, maybe not.
Old April 30th, 2013, 02:28 PM   #3
cataphysic
Motorcycle(s): 2006 Kawasaki Ninja 250R
Well it does sound Carb related to me. High float level maybe. Something causing it to drip fuel while its just sitting overnight and flooding it. If you cant choke it until it clears out, it needs the extra air to lean out the mixture. Thats what it sounds like to me anyway. Did the previous owner clean the carbs himself or did he have a repair facility do it?
cataphysic is offline   Reply With Quote
Old April 30th, 2013, 02:59 PM   #4
agentbad
agentbad's Avatar
Howdy, he said a buddy cleaned them that works on bikes and has shop but who knows. I put some seafoam in the gas tank to see if that would help a bit. I know it will probably need a valve check/adjustment coming up here soon but I'd like to ride it a little bit before spending more money on it.
Old April 30th, 2013, 03:49 PM   #5
cataphysic
Well, I can definitely understand wanting some ride time before having to put some more dollars in it. Going through some issues with mine as well and can relate. Not likely its a valve gap issue. Especially if it runs fine after its been running for a minute or two. Still think its a fuel thing. Out of curiosity, have you tried starting it with the throttle held open half way or so instead of adjusting the idle screw? Just until it starts then let off. I know theres a recall for fuel tanks leaking, but I think thats externally and doesnt affect starting or idle. When riding, do you notice any surging, stumbling or mis-firing?
Old April 30th, 2013, 03:57 PM   #6
your enricher (choke) jet is clogged.
Old April 30th, 2013, 04:37 PM   #7
agentbad
agentbad's Avatar
I have tried starting with the throttle half open and it won't turn over but as soon as I turn the idle knob up a bit it will fire up and then needs to sit for little bit. When the idle gets high and I turn it back down and it's usually ready to go. I haven't messed with the air screw or fuel screw.
This an easy fix or a tough one? I haven't done much maintenance on bikes so I may just take it to the local shop up the street. Would they fix the jets if I just got routine carb clean and sync?
Update: My buddy has offered to help me clean the carbs so I will give that a go and report back. Thank you for the suggestions.
Last futzed with by agentbad; May 1st, 2013 at 01:24 PM.
Old May 6th, 2013, 08:10 PM   #8
inkyben
Motorcycle(s): 2005 ninja 250, 2008 zx10, 2003 r6, 2008 187cc drag bike.
I'm sure it's carb related but it wouldn't hurt to check your vacuum line and fuel line before taking the carbs off. Cracked or loose vacuum line can give a nasty running condition on these little carbs. With the tank off and a few extra bucks you should throw in some NGK spark plugs.
inkyben is offline   Reply With Quote
Old May 7th, 2013, 05:15 AM   #9
agentbad
agentbad's Avatar
I actually just ordered some NGK spark plugs but now the bike won't even start. It will idle really rough and high for a second go down to about 500-1000rpm's and then sputter out. I ran some seafoam through it but I think it just lossened up more gung and clogged it worse. It has a fresh battery but I am going to try to jump it just to see what happens. Also noticed a bit of gas from messing with the idle knob too much.
Old May 7th, 2013, 06:01 AM   #10
cuong-nutz
cuong-nutz's Avatar
Personally, I would pull the carbs and clean them yourself. I seldom trust other folks when it comes to my toys unless I truly know their work skills. Like the previous people mentioned, it's carb related and sounds like the jets are still clogged. Some people think spraying carb cleaner on the carbs is cleaning it which isn't. You'll have to remove the jets, and clean the tiny orifices with some copper wire to scrape off all the crud.
There are many tutorials here that will go over the cleaning process and carb removal.
HalfFast Racing Team
Old May 7th, 2013, 10:22 AM   #11
agentbad
agentbad's Avatar
I think I am going to give this go with help from a buddy. Can I use a E string from a guitar in place of the copper wire for the jets? I think I will start with the pine sol soak and work from there.
Old May 7th, 2013, 12:53 PM   #12
Scraping stuff inside jets makes me nervous. soak them in cleaner and use compressed to blast everything out if possible.
Old May 7th, 2013, 01:13 PM   #13
quicklooker
Motorcycle(s): Ninja 250R '07
It must be copper or you risk scrapping metal outta the jets and then you'd have an even bigger problem.
Source: 250WIKI
quicklooker is offline   Reply With Quote
Old August 24th, 2013, 03:43 PM   #14
agentbad
agentbad's Avatar
Carbs were clogged as hell and rejetted and things seem to be working way better now. Thanks everyone for advice.
Old August 24th, 2013, 05:51 PM   #15
Idle issues - Idle is different every time I start up. 106 1986 - 2007 Ninja 250R Tech Talk 6 November 13th, 2014 04:57 PM
my kawasaki ninja 250 2005 won't start Yehia 1986 - 2007 Ninja 250R Tech Talk 15 August 5th, 2014 08:37 AM
idle issues jgcable 1986 - 2007 Ninja 250R Tech Talk 9 July 30th, 2014 03:13 PM
2002 Ninja 250 - issues (spark pugs, dirty carbs, won't idle, etc?) Pocket Sprocket 1986 - 2007 Ninja 250R Tech Talk 12 May 17th, 2013 11:13 AM
Idle issues Gyrene 1986 - 2007 Ninja 250R Tech Talk 15 May 4th, 2010 11:43 AM
