June 9th, 2014, 02:36 AM | #1 |
Join Date: Apr 2014 Motorcycle(s): '08 Ninja 250 Posts: 132
Vinyl Wrap Vs. Plastidip
What's are the pro's and con's of both of them?
June 9th, 2014, 02:44 AM | #2 |
Join Date: Jun 2014 Motorcycle(s): ninja 250 05 Posts: 19
Having used both, with vinyl, you get some bubbles. Even if you use a heat gun. With plastidip, it is hard to clean, if you rub against it , it will sort of leave a smudge. Hard to not scratch it, last the most 4 months, then will need to be redone, to look good !
June 9th, 2014, 03:32 AM | #3 |
Is weight a big concern with plastic dip?
June 9th, 2014, 05:39 AM | #4 |
No weight is no issue, it's just a bit thicker than vinyl, after the recommend two coats, of plasti dip !
June 9th, 2014, 09:01 AM | #5 |
Once you get past the difficulty of a good application, a vinyl wrap is going to be a lot more durable.
If done properly (edges cleaned and wrapped over) the vinyl looks just like paint, and can be washed without lifting. Plastidip isn't going to give you that. |
June 14th, 2014, 08:29 AM | #6 |
Lays er down
Join Date: Apr 2012 Motorcycle(s): 2008 Lime green Ninja 250R Posts: A lot.
plasti dip can be power washed without coming off. Its very cheap, easy to apply and easy to remove (when you want it to). Spend 8 dollars on a can and try it on something. if you dont like it you can peel it off
Want to buy Plastidip for $1.53? (Extremely cheap plastidip) | SON1C | Off-Topic | 10 | September 11th, 2014 04:36 PM |
