Old December 30th, 2015, 11:11 AM   #1
[motorcycle.com] - NHTSA Officially Announces 2015 Yamaha YZF-R1, YZF-R1M Recall
The National Highway Traffic Safety Administration has officially announced the recall on 2015 Yamaha YZF-R1 and YZF-R1M models to correct a problem with their transmissions. As we previously reported, the issue may cause the second, third and fourth gears to break under excessive stress. The recall affects 2,921 motorcycles in the U.S.
From a letter Yamaha released, we know the second gear wheel and pinion gears may break when put under high stress or from improper shifting because of inadequate component strength and stress concentration at the gear teeth bottom land. Meanwhile, the third and fourth wheel gears may deform or break under hard use due to inadequate component strength. Should any of these gears fail, the transmission could lock up, causing a loss of control and increasing the risk of a crash.
New documents released by NHTSA reveal Yamaha Motor Co. alerted its U.S. subsidiary about the problem on Nov. 13 after it was discovered during quality control testing. To correct the problem, Yamaha designed new gears with a different shape, size and material to improve durability. The new component was introduced to 2016 R1 and R1M models but dealers will need to replace the transmissions on all 2015 units. The process is quite complicated, requiring about 16 hours of work.
[Source: NHTSA]
NHTSA Officially Announces 2015 Yamaha YZF-R1, YZF-R1M Recall appeared first on Motorcycle.com News.
Click here for full story...
[motorcycle.com] - 2015 Yamaha YZF-R1 and YZF-R1M Recalled for Transmission Problem Ninjette Newsbot Motorcycling News 0 December 18th, 2015 01:21 PM
[motorcyclistonline] - RECALL NEWS: Yamaha Motor USA Announces Recall Of 2015 YZF-R1M Ninjette Newsbot Motorcycling News 0 May 8th, 2015 08:00 PM
[motorcycle.com] - NHTSA Confirms US Recall on 2015 Yamaha YZF-R1M Ninjette Newsbot Motorcycling News 0 May 6th, 2015 02:10 PM
[motorcycle.com] - 2015 Yamaha YZF-R1M Affected by Ohlins Recall Ninjette Newsbot Motorcycling News 0 April 17th, 2015 03:10 PM
[motorcycle.com] - 2014 EICMA: 2015 Yamaha YZF-R1 and YZF-R1M Preview Ninjette Newsbot General Motorcycling Discussion 20 November 6th, 2014 07:03 PM
