Old August 21st, 2018, 04:24 PM   #1
skip
skip's Avatar
Motorcycle(s): 2009 250r
how much oil
Is it 12oz per each fork when replacing fork seals for a total of 24oz?
skip is offline   Reply With Quote
Old August 22nd, 2018, 06:07 AM   #2
taz
taz's Avatar
MOTM - May '17
this is from ninja wiki
The Kawasaki Service Manual has, from time immemoriam, recommended a fork oil level of 226mm for the 86-87 and 205mm for the 88-07, but we're here to say that that number is not correct. Rich Desmond of Sonic Springs, who works with this stuff every day, says that there should be more oil in your forks (remember that, since you are measuring down from the top, a smaller number means there is more oil/less air space). He recommends a level of 115mm, and several of the guys in the club have done so and report no ill effects. Instructions for Race Tech GVEs specify 130mm. Others have gone with 200mm and say that that level works fine. The FAQ recommendation is to choose one of these figures and then do some tuning if you have any doubt.
Note from Payne: I've historically (60,000 miles) run a fork oil level of 205mm per my manual, but based upon the FAQ I raised it today to 160mm and I've got to say, Wow! I could tell an improvement as soon as I left my driveway. Rode for 60 miles, and I definitely prefer this feel. The front feels "happier" and not quite so "nervous" and harsh. Seems to give a better feel for what's going on up there.
Old August 22nd, 2018, 06:12 AM   #3
taz
taz's Avatar
MOTM - May '17
one thing they don't say is to do the measurement without the springs in and if you decide to do the 115 mm it would be 4.5 inches of air space.
Old August 23rd, 2018, 10:51 AM   #4
skip
skip's Avatar
So how many Oz per fork
Old August 23rd, 2018, 12:49 PM   #5
Hard to say because some remain when draining. Procedure is outlined above, pour some in, measure from top, pour some more, measure again. Stop pouring when distance from top reaches desired level.
Then repeat for other fork. Level varies depending upon your goals and performance requirements.
If you're looking at how much fork oil to purchase, get about 30-40 oz
Old August 23rd, 2018, 02:58 PM   #6
Ceeloo Yello
Motorcycle(s): 250
When I did mine I bought 1 quart and still had some left over.
[motorcyclistonline] - MC Garage Video: Mineral Oil vs. Synthetic Oil For Motorcycles Ninjette Newsbot Motorcycling News 0 June 3rd, 2016 05:30 PM
Is it normal for oil to increase a bit in the crankcase after an oil change? cadd 2008 - 2012 Ninja 250R Tech Talk 10 May 15th, 2014 08:38 PM
5qt. G-Oil Synthetic Motor Oil (5w-30) Free After $26 Rebate setasai Miscellaneous 3 May 25th, 2011 01:59 PM
[webbikeworld.com] - Substitute Ducati Oil Filters - Changing the Multistrada Oil and Ninjette Newsbot Motorcycling News 0 October 26th, 2008 05:10 PM
