Old September 1st, 2018, 05:55 PM   #1
Darksik
Darksik's Avatar
Motorcycle(s): 2010 Kawasaki Ninja 250R, 99' Suzuki Katana 600 (RIP)
Gearing and battery questions
Hi guys i got some questions, i want to change my bike gearing and i hear the 15/41 is the most lowered sprocket to put on the bike also my bike chain because i ride on highway and i have to rev up to 8k rpm, but also i want to reduce the rpm to don't force the engine, if someone knows a good but economic brand on ebay please share with me the link
Also i want to change the battery because i have with the battery like 4 or 5 years and i don't know what size or amps the battery need to have or that stuff
Ps: my english is bad
Darksik is offline   Reply With Quote
Old September 2nd, 2018, 02:57 AM   #2
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
why change gearing? your newgen is quite happy cruising at 9000 rpm. they are designed to do this.here is the battery i'm currently using. it has has duel pos/neg hookups too its on ebay
"trying not to get old"
Old September 2nd, 2018, 03:03 AM   #3
maverick9611
MOTM - Feb '18
model MBTX9U
here is the correct one for your ninja
https://www.ebay.com/itm/Motobatt-Ba...0AAOSwSutaEb1t
Old September 2nd, 2018, 06:05 PM   #4
Darksik
Darksik's Avatar
I want to change gearing because i heard it could reduce like 500-900 rpm and im a student and i don't have much money to spend in gas :/
Old September 2nd, 2018, 09:01 PM   #5
There will be NO MPG changes with gearing. What determines MPG is total aero-drag as determined by cA*cD. This drag does not change with gearing nor power-required to overcome that aero-drag.
For example, about 7bhp is required to push Ninja 250R through air at 100kph. With taller gearing, guess how much power is required for same speed? EXACTLY THE SAME!!! However, since HP = (TQ*RPM)/5252, instead of 8000rpms @ 60mph, using 7000rpms @60mph will require more torque. That means with taller gearing, you'll need larger throttle openings to generate same amount of HP and speed. No reduction in fuel consumed there.
What will improve MPG is reducing total aero-drag. I've found installing taller windscreen (Double Bubble or Corsa), and tucking in as low as possible behind it improves mileage from 60 to 70 MPG. Also drafting big trucks as much as possible on carriageway really helps (Mythbusters did experiment confirming this).
Old September 2nd, 2018, 10:43 PM   #6
Darksik
Darksik's Avatar
well ignore the "fuel consume", but i want to ride on federal highway and don't force the bike with high revs
what is the price for that type of windscreens?
Old September 3rd, 2018, 03:22 AM   #7
maverick9611
MOTM - Feb '18
el cheapo double bubble
https://www.ebay.com/itm/Double-Bubb...AAAOSw65FXvqIn
Old September 3rd, 2018, 03:46 AM   #8
You can buy from Ali
https://www.aliexpress.com/item/HotS...647363340.html
Old September 3rd, 2018, 10:31 AM   #9
Battery technology is ages old (ancient Greeks had it). Chemistry is well known as is necessary care. Lead-acid battery can last 10-yrs with regular desulfating. It's secret auto-industry has been hiding to make more profits from battery sales.
There are smart chargers that have de-sulfation cycles where it tickles high-voltage +30v sine/square-wave pulses at high-frequency 1-20khz with low amperage through. Need to get over minimum activation energy to dissolve lead sulfate crystals back into solution.
http://www.superstreetonline.com/how...-fact-fiction/
https://www.impactbattery.com/blog/2...racle-charger/
With monthly desulfating, batteries in my autos are reaching 10-yrs as well as 3 on my bikes.
Old September 3rd, 2018, 10:39 AM   #10
JohnnyBravo
Certifiable nontundrum
JohnnyBravo's Avatar
MOTM - Sep '13, Sep '16
What kinda charger you got?
Old September 4th, 2018, 11:38 AM   #11
I use one of these with 4-way Y-split to connect 4 bikes at once: https://www.amazon.com/dp/B000P23HZS
For autos, I use this with 2-way split (garage only holds 2 anyway). https://www.amazon.com/dp/B00Q3CM2QY
Questions on gearing. JayJay 2008 - 2012 Ninja 250R Tech Talk 38 June 24th, 2015 05:46 PM
FS: Battery Tender 022-0165-DL-WH 12-Volt 2-Bank Battery Management System (Automotiv Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
FS: Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger (Automotive) tagg Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
FS: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger (Automotive) ta Amazon Postbot Amazon - Popular Motorcycling Items 0 April 23rd, 2013 04:52 PM
