March 15th, 2014, 08:05 PM | #1 |
The Violet Vixen
Join Date: Jun 2012 Motorcycle(s): Perigee (250), Hotaru (250), Saturn (300), Pearl (300), Zero (S1000RR), Chibi (Z125), Xellos ('18 HP4R) Posts: A lot.
MOTM - Jun '16
Short shift lever tie-rod?
So if you read my story over in ride reports, I had a fun experience where adjusting my shift lever ended poorly because I didn't pay enough attention to getting my locking nuts down tightly.
I have that all sorted out now, but I'm still a bit unhappy with the placement. Is there a way I could get the same rod but shorter? I'd really love to move the shifter up higher but it's as a high as possible given the OEM's length. |
March 15th, 2014, 08:13 PM | #2 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
Why not just move the crank on the shift shaft a spline or two clockwise?
I wanted my shifter lower, so I moved mine one spline counterclockwise. |
March 15th, 2014, 08:21 PM | #3 | |
The Violet Vixen
MOTM - Jun '16
I can live with it where it is, but it isn't quite 100% where I want it. |
March 15th, 2014, 08:28 PM | #4 |
Participant
You could go to a machine shop and have a short rod custom made. It'll take a pro to do it because one end of the rod has left-hand threads. But it shouldn't cost more than one-half to one hour's shop time.
March 15th, 2014, 08:39 PM | #5 | |
http://faq.ninja250.org/wiki/How_do_...the_shifter%3F
March 15th, 2014, 08:56 PM | #6 | |
The Violet Vixen
MOTM - Jun '16
March 15th, 2014, 09:26 PM | #7 |
I see.
Consider that the best resolution and symmetry of the shifts is achieved when the rod is perpendicular to each of both levers. The same machinist could easily extend the right-thread of the rod and cut it shorter in a lathe or even with hand tools.
March 15th, 2014, 09:33 PM | #8 |
The Violet Vixen
MOTM - Jun '16
Yeah, with everything where it is right now the shifter is a good inch or inch and a half lower than the foot peg.
March 15th, 2014, 10:07 PM | #9 |
Participant
March 15th, 2014, 10:20 PM | #10 |
The Violet Vixen
MOTM - Jun '16
Yep, with my tiny feet I basically have to go off of the peg to get my boot in good shifting position -- which is both distracting and reduces my leverage. If I move the shifter position (the 'peg' on the lever itself) inward then downshifting becomes easy but upshifting becomes too tight. Bleeeeeh :P
March 16th, 2014, 07:21 AM | #12 | |
A non-ergonomic shifter takes away all the fun of sport riding. I am very sensitive to the position and smoothness of the shifter-boot-foot relationship.
March 16th, 2014, 08:35 AM | #13 |
Participant
March 16th, 2014, 09:08 AM | #14 |
The Violet Vixen
MOTM - Jun '16
Sure, here ya go
From where it is in this picture I can't rotate the bar any further to get the shifter higher |
March 16th, 2014, 01:10 PM | #15 | ||
Post #2 explains the same with better wording: Quote:
It would look something like this: /____ / ............ which is still OK. A more radical option could be to switch to the reverse shift (Moto GP style), using a shift lever clamped directly to the shifter shaft.
March 16th, 2014, 01:14 PM | #16 |
if rotating the arm on the output spline isn't feasible because of the geometry of the rearset, you could remove the rod, remove a quarter inch with bolt cutters, then run a die over it to clean up the end, and maybe take the threads in a bit further.
Lowside- bent clutch thrust rod and possibly bent shift fork? | Klondike1020 | General Motorcycling Discussion | 3 | April 1st, 2014 02:29 AM |
WTB Tie Rod for Shift Assembly | TooNasty | Items Wanted | 0 | May 15th, 2013 01:32 PM |
WTB: Left side turn signal/clutch lever/ shift lever/fairing (green/red or black) | daedrick | Items Wanted | 0 | April 3rd, 2012 12:44 PM |
Tie rod keeps coming off | Xz1atl | 2008 - 2012 Ninja 250R Tech Talk | 7 | January 10th, 2012 06:01 PM |
Slipping shift pedal tie-rod | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 9 | June 16th, 2009 10:46 AM |
