Old June 12th, 2013, 05:51 AM   #1
Christofini
Christofini's Avatar
Motorcycle(s): '08 Ninja 250R
Stripped bolts
Hey all. While trying to remove the front fender I noticed the two hex bolts attaching the top of the fender are stripped. The previous owner botched a lot of the screws, but these are the only ones I couldn't replace.
Any advice for getting them out? They're in an awkward position and most of my tools don't fit even with the fairings / headlight removed. I was told an "Easy out" would help but they aren't available here. Ill likely take a drill and drill / sand off the two heads.
Do these bolts have loctite on them? And is there an easier way than drilling them out?
Thanks
Christofini is offline   Reply With Quote
Old June 12th, 2013, 06:04 AM   #2
rojoracing53
Fast-Guy wannabe
rojoracing53's Avatar
MOTM - Jan '13
Ok so try this.
If you remove the front wheel you can access the bottom of the bolts from underneath with a drill. If you start with a small bit and drill in about 8mm then grab a slightly bigger bit and slow drill in it will grab the walls of the first hole and if you bolts aren't to tight it will spin out you bolts. There shouldn't be any locktite on any fairing bolts unless the previous own added some.
Old June 12th, 2013, 06:16 AM   #3
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Basically what your trying to do is remove the fender from the mounting bracket, and the mounting bracket is attached to the fork legs. You can remove the 6 bolts holding the mounting bracket to the fork legs without having to remove the front frender at all. What I'm not sure about is wether after removing the 6 bolts if you can twist and guide the fender and bracket out of the bike as one piece. Also you'll need to remove the front wheel for this as well.
Here's a few pics showing the 6 bolts that hold on the fender bracket.
Old June 12th, 2013, 06:32 AM   #4
Christofini
Thanks! I wasn't sure if I could get at the holes from under the fender. Removing the mounting bracket would likely make it much easier for me - either way the fender has to go! Previous owner damaged it and it rattles a little while I drive.
Old June 12th, 2013, 06:43 AM   #5
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Originally Posted by Christofini View Post
Thanks! I wasn't sure if I could get at the holes from under the fender. Removing the mounting bracket would likely make it much easier for me - either way the fender has to go! Previous owner damaged it and it rattles a little while I Ride.
Here I fixed that
Or since your from Spain ill accept "pilot" as well since that's what they seems to call me while I was racing world.
Old June 12th, 2013, 09:36 AM   #6
Christofini
Too right :P Suppose it is piloting, in a sense. I'll try drilling it once I get home and let you know how it goes...New fibreglass fender is going on in it's place - ever raced in Ascari, Ronda? Few friends and I are hoping to get a 250 group going there.
Old June 12th, 2013, 10:38 AM   #7
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
No I've never been there but I did race at Catalunya and go to do a private test for a Suzuki team at Valencia all by myself :lol
When I was at Valencia it felt so errie to have a track of that magnitude all to myself
Old June 12th, 2013, 03:51 PM   #8
Christofini
That's awesome I "raced" 50cc mini-bikes from when I was 13 till 16 with friends. Always wanted to run larger bikes but my family was never too keen on two wheeled vehicles
Anyways, update on my fender issue. The bolt wouldn't budge at all, I'm guessing it's rusted in there. Owner #1 had it sitting in the sun by the beach with no cover. I'll bring it to the shop and ask them to see if they can do it tomorrow.
P.S: Next time you're around here do let me know! Spanish riders aren't very good company
Old June 12th, 2013, 04:13 PM   #9
rojoracing53
Fast-Guy wannabe
MOTM - Jan '13
Haha yeah for sure next time I happen upon a full paid ride on the European circuit ill be sure to swing on by
My impression of Europe was every and I mean nearly everyone loved Motorsport and that included motorcycles I guess I was wrong.
What's wrong are the Spanish street riders to hot headed to enjoy a good clean ride?
Old June 12th, 2013, 04:28 PM   #10
Christofini
Yeah I've got kids on mopeds trying to overtake me on a 40 street, and get quite a few super sports signalling me for races and wheelies. Kawi's are quite rare here so I guess they think I'm rolling on a super sport too I haven't seen another 250 on the streets, makes me feel unique
Removing stripped rotor bolts FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 33 April 17th, 2013 07:41 PM
Stripped thread! Help please. EthioKnight 2008 - 2012 Ninja 250R Tech Talk 15 July 8th, 2012 03:06 PM
stripped screw scotty 2008 - 2012 Ninja 250R Tech Talk 17 October 6th, 2010 11:05 AM
Help! Heat shield bolts stripped! poo poo 2008 - 2012 Ninja 250R Tech Talk 6 September 8th, 2010 08:25 AM
Stripped Rims Snake 1986 - 2007 Ninja 250R Farkles 2 February 18th, 2009 07:57 AM
