March 25th, 2015, 11:46 AM | #81 |
March 25th, 2015, 11:55 AM | #82 | |
Private Joker
MOTM - Mar '14
The vanishing point is the point where you can no longer see the road in front of you for whatever reason. Reasons including but not limited to elevation change, distance, a cliff or treeline on the inside of the corner blocking your view ahead, or a bike passing you on the inside (or that you are passing on the outside) blocking your view ahead. To look at the vanishing point is to look at the farthest possible decipherable point ahead in the corner or straight
March 25th, 2015, 12:04 PM | #83 | |
Private Joker
MOTM - Mar '14
You're definitely taking that differently than me and way faster too since it was my worst corner by far. Also, I'm not looking through to turn 2 until about the point that I'm WOT which is a good bit after the 2nd meatball apex. Side-note: T2 (and 12 but I never got 12 WOT) was intense for me. I wasn't even WOT through it on the 250 last time but managed to get through WOT on the gsx-r a few times in the mock race. My heart was beating like a jackhammer every time I exited T2 after entering WOT or barely checking up going in.
March 25th, 2015, 12:13 PM | #84 |
Spot on Ben!
Turns 2 and 12 are great for identifying visual skill weaknesses. To many riders, they look pinched or appear to close up (ie, the exit is more narrow than entry). But as you have ridden, those turn's exits are just as wide as the entries. The challenge is to SEE IT! When you see it, rider's can adjust their turn in point and rate to adjust for a WOT line through the corner. Lazy turning and WOT through turns normally don't work out too well. Until then, SR's will always have the rider rolling off or setting an entry speed that leaves the rider let's just say... wanting a little more.
March 25th, 2015, 12:18 PM | #85 |
Private Joker
MOTM - Mar '14
I may see it but I still question it as I turn in "oh ****, T2 again" *cross fingers* *flies through feeling like a jet doing a flyby* "AWW YISS!!!"
As for "wanting a little bit more" I'm perfectly ok with my speed through T2 and know that it'll increase on it's own next time I'm down there when I figure out T1, which is where I got that "wanting a bit more" feeling
March 25th, 2015, 12:21 PM | #86 | |
Why do you question it? I believe you will find your answer hidden inside your own question and a hint from my previous post.
March 25th, 2015, 12:43 PM | #87 |
Private Joker
MOTM - Mar '14
Visual skills and SRs straight up. I see it visually, I know I can do it but there's a part of me deep down inside questioning that I can do it and I fight the hell out of that SR
March 25th, 2015, 03:49 PM | #88 | |
Ninja chick
Join Date: Jun 2009 Motorcycle(s): '13 Ninja 300 Posts: A lot.
MOTM - Dec '13, Feb '15
...until you know your bike is pointed there. Don't look at any reference point for too long. And don't skip past one in a turn like corner 1 because, well, you tend to aim for that 2nd meatball too early, and well, oversteer. If you do end up in that situation, for the love of God, do not think, "Oh, ****, I'm too close to the edge." If you do think that, do NOT, whatever little demon takes over, do NOT look at that sand only millimeters from your tire. If you do, those millimeters will disappear mighty quickly, but that moment in time will stay with you permanently.
Sometimes it's the journey that teaches you a lot about your destination. ~Drake Check out my Appalachian Trail journal, 2015! Postwhores are COOL! ~Allyson |
April 28th, 2015, 12:49 PM | #89 |
Bump for the start of the riding season and.... a nugget.
If... your cornering and suddenly find the the need to look back at "where you currently are", this is a sign that you need to work on some vision skills. Why do you think this is the case? Safe cornering ya'lls!
Goal: Shake A Million Hands | Look through the corners | Track Day Prep | Closest track? | The Mid-Ohio School Last futzed with by csmith12; April 28th, 2015 at 02:22 PM. |
what turns you have problem with the most...? | RJprod | Riding Skills | 12 | June 6th, 2013 07:44 AM |
Downshifting for turns | dcx4610 | Riding Skills | 106 | October 24th, 2012 01:31 PM |
Taking turns | TnNinjaGirl | Riding Skills | 51 | August 3rd, 2012 04:32 PM |
U-turns on a Ninjette | akima | Riding Skills | 14 | October 13th, 2011 12:00 PM |
Slow U Turns | Liber | Riding Skills | 17 | August 14th, 2011 07:35 PM |
