Old May 17th, 2021, 04:04 AM   #1
SirAyeJay
Motorcycle(s): 08 Ninja 250r
Angry Clanking Noise when I hit my brakes
Sooo this just started...
I Was pulling into my drive way last night and went to hit Rear break and a clanking noise came from around my shifter area....And it only does it when it’s in gear
I am stumped..
Any help would be great
SirAyeJay is offline   Reply With Quote
Old May 17th, 2021, 06:55 AM   #2
Start by checking the chain adjustment, and look for any seized links.
Next would be confirming the sprocket is tight on the countershaft.
Then look at the rear caliper, rotor, and the "cush drive" for excessive play.
https://faq.ninja250.org/wiki/How_to...the_cush_drive
Old May 17th, 2021, 06:44 PM   #3
Ducati999
Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD)
Also check to make sure you dont have any teeth missing from the front or rear sprockets
Ducati999 is offline   Reply With Quote
Old May 20th, 2021, 09:26 AM   #4
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
Probably chain slap on the swingarm from poorly adjusted or worn out chain.
Brakes??? Billtrill 2008 - 2012 Ninja 250R Tech Talk 18 April 27th, 2017 01:02 PM
Brakes what would you do? crazymadbastard General Motorcycling Discussion 7 March 30th, 2015 11:27 AM
Weird bionic noise from brakes nickjpass General Motorcycling Discussion 12 September 24th, 2014 09:13 AM
problems (clanking noise) Batman's 250r 2008 - 2012 Ninja 250R Tech Talk 4 August 26th, 2011 10:04 PM
Front end clanking/chatter noise indr 2008 - 2012 Ninja 250R Tech Talk 7 November 21st, 2010 03:40 PM
