Old August 1st, 2021, 06:07 AM   #1
erbarry88
Motorcycle(s): 2011 Ninja 250R, 2007 GSX-R 600
Wiring new speedo
So I'm installing a cheap speedo I got off Amazon and had a few questions.
Can I replace the temp sensor with a pregen to get the coolant temp displayed?
Some wiring diagrams show an aux power connector but I can't seem to find it in the forward end, is this for pregen?
2011 Ninja 250R
2007 GSX-R 600 (Sold)
erbarry88 is offline   Reply With Quote
Old August 4th, 2021, 04:24 AM   #2
Bob KellyIII
Retired motorcycle Mc.
Bob KellyIII's Avatar
Ugh ! totally unknown here ! ...
but I've seen some of the LCD speedo/instrument panels put on different bikes and they seemed to work well for them...
While you got the front all apart, if your thinking of going with LED turn signals now would be a great time to add the 2 diodes to the bulb in the instrument panel...LOL....
of all the bikes I've owned the 2012 250R ninja is the hardest bike to work on yet ! plastic covers everything and it's so tight under the carb I can't fit my hand in there ! .... makes me wonder if they do everything with chop-sticks !
later !
Bob.......
Old August 4th, 2021, 10:52 AM   #3
erbarry88
Bob.......
I added a singe headlight with DRLs and turn signals and added the relay for it since they weren't blinking at first. I got it all wired up now and just wired the water temp switch to 6 gear indication. It works pretty good.
2011 Ninja 250R
Old August 4th, 2021, 11:25 AM   #4
Bob KellyIII
COOL looks like your getting it ! keep up the good work you'll have it up and running in no time !
Bob.......
Speedo Drd, Speedometer and Odometer Accuracy-Speedo Healer/drd Klondike1020 General Motorcycling Discussion 8 August 17th, 2014 12:23 AM
My speedo is way out! Damo990 2013 - 2017 Ninja 300 Tech Talk 14 March 5th, 2014 06:54 AM
Speedo Came Off! komohana 1986 - 2007 Ninja 250R Tech Talk 8 May 29th, 2011 01:55 PM
My speedo is off??? Kitdog 2008 - 2012 Ninja 250R Tech Talk 3 June 28th, 2010 03:24 PM
Speedo out of whack?!!? TmP 2008 - 2012 Ninja 250R Tech Talk 8 May 2nd, 2010 09:48 AM
