May 30th, 2012, 01:52 AM | #1 |
Join Date: Aug 2010 Motorcycle(s): 2010 Kawasaki Ninja 250R Posts: 28
Help!! Need advice... Bike Wont Run
Okay so i just got my new diaphram installed on the carbs and after i put everything back together i tried to start up the bike. But it struggled to start up and the choke lever didnt make the bike respond at all. Once i had it started it would only idle at 1k then if i tried to rev it at all it'll reach 1.5k then just die. I kept trying to start it but it just wouldn't. I'm going to rip the carb back out and i'll check everything. But i was hoping someone would have any idea what could be causing this??
May 30th, 2012, 05:19 AM | #2 |
Join Date: Mar 2012 Motorcycle(s): 2011 Ninjer 250, 2002 TL1000R, 2009 Concourse14, 2009 ZX6, 2006 SV650 Posts: 19
Diaphram?
May 30th, 2012, 10:08 AM | #3 |
Sounds like mine cold without choke. Reconnect the choke cable?
May 30th, 2012, 06:32 PM | #4 |
Yeah i checked the other diaphram that i didnt replace and it was fine, maybe its clogged up somewhere
Need Help Diagnosing Bike That Wont Run | Yondaime | 2008 - 2012 Ninja 250R Tech Talk | 25 | October 4th, 2014 01:18 PM |
Oil leaking out of airbox bike wont run properly | peeweecollins | General Motorcycling Discussion | 18 | July 9th, 2011 10:05 PM |
Bike wont start, please help? | zev42 | 2008 - 2012 Ninja 250R Tech Talk | 11 | November 9th, 2010 01:02 PM |
bike wont run without choke on? | ReDnEcK | 1986 - 2007 Ninja 250R Tech Talk | 4 | September 15th, 2010 08:50 PM |
Ninja 250r Wont Rev or run without choke | esde | 1986 - 2007 Ninja 250R Tech Talk | 21 | November 9th, 2009 02:32 PM |
