November 29th, 2012, 10:19 PM | #1 |
Jigglin' your Jiglets
MOTM - Apr '13
Pirelli Diablo Supercorsa Front
What do you guys think? Is it worth going to a 120 in order to get the sexiness that is this tire? I'm thinking of running the Supercorsa front a rosso 2 rear.
November 29th, 2012, 10:35 PM | #2 |
Don't your tires work fine?
November 29th, 2012, 10:43 PM | #3 |
MOTM - Apr '13
Yea but...
that one is stickier...
November 29th, 2012, 10:44 PM | #4 |
Join Date: Apr 2011 Motorcycle(s): 2022 Honda CRF300L Rally, 2015 Ninja ZX6R 636, 2014 Ninja 1000, 2013 Ninja 300 (sold), 2011 Ninja 250R (sold) Posts: 479
Besides slower steering and less change in your pocket, what would you gain over the Rosso II?
November 29th, 2012, 10:45 PM | #5 |
cuz
Join Date: Jul 2011 Motorcycle(s): 09 ninja 250r Posts: A lot.
I thought they had 110 for it... yea know some of track 250s that run this set up
THE GOOD LIFE |
November 29th, 2012, 10:47 PM | #6 | |
MOTM - Apr '13
I couldn't find a 110. Thats what I've read though
November 29th, 2012, 10:49 PM | #7 |
Ninjette wanabe :D
Join Date: Apr 2011 Motorcycle(s): white 300 :D Posts: A lot.
Do it and tell me how it is
VROOOM vrooom >.> |
November 29th, 2012, 10:51 PM | #8 |
Better tires only hide your mistakes.
November 29th, 2012, 10:51 PM | #9 |
I think your efforts would be better spent on Rosso IIs and then dialing in your front suspension for your weight.
November 29th, 2012, 10:52 PM | #10 |
MOTM - Apr '13
Oh hey I found a 110, not a lot of people seem to carry it
November 29th, 2012, 10:53 PM | #11 |
MOTM - Apr '13
I'd prefer my mistakes to be hidden than end up in a ditch
November 29th, 2012, 10:54 PM | #12 |
MOTM - Apr '13
November 29th, 2012, 10:55 PM | #13 |
November 29th, 2012, 10:56 PM | #14 |
November 29th, 2012, 10:56 PM | #15 |
MOTM - Apr '13
November 29th, 2012, 10:57 PM | #16 |
crash 250, get supersport
Join Date: Apr 2010 Motorcycle(s): 2010 250R SE (Sold 6/9/14), 2009 ZX-6R (Sold 6/25/14), Subaru BRZ Posts: A lot.
Quite a beefy tire, if you feel that it's worth the change from your DR2's then go for it I guess?
November 29th, 2012, 10:57 PM | #17 |
cuz
a quick Google search does wonders
Da cheapest 1 i found im sure there's a better deal out there http://www.ronayers.com/ProductDetai...79/SKU/1197686
THE GOOD LIFE |
November 29th, 2012, 10:57 PM | #18 |
Ninjette wanabe :D
http://www.pirelli.com/tire/us/en/mo...subtype%3Droad the super sp's come in 110/70 and 150/60 :S
VROOOM vrooom >.> |
November 29th, 2012, 10:59 PM | #19 |
cuz
FYI
There are different compounds
THE GOOD LIFE |
November 29th, 2012, 11:04 PM | #20 |
It's very true for automotive racing and I am guessing it would be true for motorcycles as well.
I autocrossed my car for a year before I owned my bike. I learned quite a bit about how tires change the car. With super grippy tires you can get away with many mistakes but with okay tires you really have to be a good driver to get the car to do what you want it to do. You have to be super smooth with crappy tires (not saying you shouldn't be smooth with super grippy tires) but once YOU can push the limits of a car with crappy tire then once you move up to grippy tires you will be able to go much faster than someone who skipped the basics and started with the most expensive grippy tires they wanted. I am tired am probably not being clear with my thoughts. |
November 29th, 2012, 11:07 PM | #21 |
Seems like Sean is comprised entirely of straight cash, homey.
If so, buy it and sell your DR2? |
November 29th, 2012, 11:12 PM | #22 |
MOTM - Apr '13
November 29th, 2012, 11:22 PM | #23 | |
...but to play devil's advocate: The Dunrocks suck. They slide. They don't turn in quickly at all. They don't stay stable mid-lean. They're vague when pushed at all. They generally are good at nothing except keeping the rim off the ground. now compare that to BT45's, or Diablo scooters. They flick over quickly. They stay planted and stable mid-lean. They don't feel slick. They get up to temp quickly and stay sticky. If anything, stickier tires show off my problems more, because they allow the bike to follow my every bad input and show me where I'm going wrong, whether that's too much bar input while shifting my weight, or just a bad line in general (I'm guilty of both). |
November 29th, 2012, 11:30 PM | #24 |
November 29th, 2012, 11:32 PM | #25 | |
I see what you're saying there. I never experienced the dunrocks. I have BT45s on my ninja and Roadwinners on the KLX. Side note: I don't get why people bad mouth the Roadwinners, they work fine for the street. On neither bike do I have issues with the tires. If the tires were to slip for any reason it would be because of me making a mistake. But Jiggles has decent tires. DR2's. He doesn't NEED anything with more grip. He is just scared he is going to lowside for some reason. |
November 29th, 2012, 11:36 PM | #26 | |
The roadwinners (from the 2 times I've ridden on them) are alright. Nothing super confidence inspiring, but with so many better options out there, I would never buy a set. Jiggs, get faster first |
November 29th, 2012, 11:37 PM | #27 | |
MOTM - Apr '13
The roadwinners are totally fine for the street, I never had a problem with them and I scrubbed the strips off them too.
November 29th, 2012, 11:38 PM | #28 | |
MOTM - Apr '13
I got a 2.38, I'll bet the next time I'm out there I can break 2.30 the 250 lap record is 2.08
November 29th, 2012, 11:39 PM | #29 |
November 29th, 2012, 11:40 PM | #30 |
MOTM - Apr '13
I'll still want the stickiest tires.
Can we get a velcro track?
November 29th, 2012, 11:48 PM | #31 |
November 29th, 2012, 11:51 PM | #32 |
MOTM - Apr '13
You have never heard @Nemesis's bike
November 29th, 2012, 11:53 PM | #33 |
November 29th, 2012, 11:54 PM | #34 |
Gear crash test dummy
Join Date: May 2011 Motorcycle(s): 2010 Ninja 250 race bike, 2014 ZX-636r Posts: A lot.
Also. I have the SC2 120 front. It is quite sticky/awesome. However, they are hard to get because they don't usually ship to the west coast. When I have to get a new front it will be a Diablo Rosso II. NOT because I don't like the Supercorsa, I think it's great. I'm not at a point where I think I'd be able to tell a great difference between the two, and wont be there for a while. I know the SC2 is better, but I don't need it yet, I'm just not there. Neither are you. Stick with the Diablo Rosso IIs, you have more to work on first, like butt to seat removal :P
CVMA #531 |
November 29th, 2012, 11:56 PM | #35 |
MOTM - Apr '13
Too late I ordered one hahahaha. It's going on the next front tire replacement, should be a few thousand miles more or about 4-5 more trackdays
November 29th, 2012, 11:59 PM | #36 |
Steve has used his SC2 front and DR2s for the whole race season. I think you have more than 6-7 Track days on yours... Save your money, this will get more expensive! :P
CVMA #531 |
November 30th, 2012, 12:02 AM | #37 |
Looks like I don't need to worry about replacing mine before my next track day then! I'll likely buy a new set and bring them with me though, just in case.
November 30th, 2012, 12:05 AM | #38 | |
Hahaha.You do realize 30 seconds is a huge amount of time in racing. Maybe you will be faster once you start shifting gears more often! Oh and I am sure that new tire will make you like 10 seconds faster. |
November 30th, 2012, 12:21 AM | #39 | |
MOTM - Apr '13
The only thing that will have changed is the front tire
November 30th, 2012, 02:11 AM | #40 |
cuz
That's a fast tire need to keep the speed up (so it can work to it's potential)
GL
THE GOOD LIFE |
[motorcycle-usa.com] - Pirelli Diablo Supercorsa SP on 1299 Panigale | Ninjette Newsbot | Motorcycling News | 0 | January 27th, 2015 03:00 AM |
[roadracingworld.com] - Pirelli's Diablo Supercorsa SP Chosen As Original Equipment O | Ninjette Newsbot | Motorcycling News | 0 | January 26th, 2015 05:20 PM |
[sportrider - latest stories] - New Pirelli Diablo Supercorsa SP Tire Take to the Tra | Ninjette Newsbot | Motorcycling News | 0 | September 7th, 2012 05:20 PM |
[motorcyclistonline] - Pirelli Presents the New Diablo Supercorsa: Top Performance on | Ninjette Newsbot | Motorcycling News | 0 | November 15th, 2011 02:50 AM |
[topix.net] - BIKES: Pirelli Presents The New Diablo Supercorsa | Ninjette Newsbot | Motorcycling News | 0 | November 14th, 2011 09:10 PM |
