March 21st, 2012, 07:43 PM | #41 |
Anyway, I didn't get to rebuild my forks today as I intended so I haven't put my new chain on yet. Before I do, how much of a flare should I make on the rivet head?
I'm pretty sure I'm well past the service limit on my front rotor so this will probably be my last set of pads on them (I finally got the calipers to check last week). IIRC, you said that they messed up the bolt holes by not having a place for the head to rest flush or something like that, right? Well, my bolts are probably trash and will need to go when this rotor comes off, so I'll probably need to buy some anyway. I'll go dig up the PMs. Last futzed with by CZroe; March 28th, 2012 at 06:30 AM. |
March 21st, 2012, 09:17 PM | #42 |
I don't remember exactly. I think I have one with the wrong sized holes, and another replacement that was drilled-out to spec. If interested I'll get it down from it's shelf....
March 22nd, 2012, 09:09 AM | #43 |
March 28th, 2012, 06:33 AM | #44 |
When riveting the master link, how do I know what size to flare the pin to? I will be using a Harbor Freight chain tool that can be used to rivet links even though it wasn't made for it. The service manual mentions some measurements that I'm pretty sure are meant for an EK SRO rivet link. Volar sent me instructions but they do not say how much to flare the pins of the link. Should I just use calipers to measure a normal pin from another link and flare it to match?
March 28th, 2012, 09:50 AM | #45 | |
April 28th, 2012, 11:34 AM | #46 | |
Volar Warning!!!!
Please, please, please do yourselves a favor and stay way away from Volar. Just rode 50mi with a NEW Volar chain, and it chewed up my back tire. Issues started during install, when the master link rivet cracked apart while setting the rivet.......didn't even apply half the pressure used to set previous chains. I compared tensile strength to that of an old DID link I had laying around. Volar claims over 10,200lbs, but the link cracked in half at a 20 degree bend......compared to the DID that bent at a 45 degree with no signs of breakage. There is way too much lateral movement in this chain, and I'm now missing large chunks from the edge of the tire and sidewall. Now I not only need a new chain, but a new back tire. VOLAR CHAIN IS LETHAL! There is no way this chain should be on the market, and I still haven't gotten any response from D2Moto (the seller). Steer clear, and get yourself a chain that's road worthy. Good luck, toobem 1998 TL1000R 1 liter Duc eater........ |
April 28th, 2012, 11:55 AM | #47 |
That wasn't a tensile test. Tensile tests pull the item apart lengthwise. There's not any bending involved in a tensile test.
^^ this is what a tensile testing machine looks like. that 10,000lb+ estimate from volar is found by stretching the object in question out. |
April 28th, 2012, 11:57 AM | #48 |
Jigglin' your Jiglets
MOTM - Apr '13
How does a chain destroy a tire???
April 28th, 2012, 12:08 PM | #49 | |
The chain moves an extraordinary distance side-to-side, and rubs the tire when in motion. There are huge melting points/chunks in my Sportmax. This is my 5th chain I've installed, and I've never seen or had an issue even resembling this. Sorry for the misrep of a tensile test.........my bad. However, bending the link does stretch it, and when it breaks in half at a 20 degree bend........probably not good. Check for yourself if you can. My bet is that under proper conditions with a tensile testing machine/contraption you'll get similar results. Unsafe, period. That's the point. Thanks for the correction, though. |
April 28th, 2012, 05:30 PM | #50 | ||||
This post could not have come at a better time. I attempted to install a D2moto-sourced chain with similar results recently and I just received two revised Volar chains for review on Friday. These are supposedly improved and I had to wait until they got their samples incorporating the improvements to get mine.
My primary complaint so far is the continued lack of replacement parts even after their "solution" of telling me to buy a compatible RK O-ring link. They do seem responsive to customers and their demands. @vincent33 is the user they contacted me through, if you would like to contact them yourself. They aren't super-light racing chains but, then again, they aren't claiming to be expensive and fancy "better than O-ring" chains either, and the bulk probably increases their strength (assuming that they are still bulky; I haven't opened the package yet). If what they say is true, I expect OEM quality and expect that they are more than good enough for our small bikes. Now, I will not be reviewing them through rose-colored glasses just because they sent me free chains (it's not like I didn't also PAY for two chains) and I will be incorporating everything you said into my impressions. That said, I'm glad that I did not jump to conclusions about their chain being at fault for the last failure and hope that you aren't doing so. When the OEM EK SRO chain began doing the same thing my Volar chain did, I considered them mostly vindicated in that respect. |
April 28th, 2012, 07:04 PM | #51 |
I've been running a 200 on the back for the last 27,000 miles, or so. I've used RK, EK, DID, and no Volar. All were/are O-ring chains. All were used while using the same alignment process, and all but one, the Volar, performed well. The chain moves too much laterally. I initially thought that I might be at fault, but I did nothing different than I had previously.....not a thing different.
I believe the reason you may assume RK produces Volar is because of the latter's purchase of the former's used (and worn) production equipment. Unfortunately, Volar does not use the same, proven production methods and materials as RK......just the same colors. All the links clearly state "520", except that now they're coated with burnt/melted rubber. It's my opinion, and not only mine, that a foreign, or non-matching, master link is a bad idea and usually results in binding and extra wear either on the master or the links directly in contact with it. I believe any moto mechanic will support that opinion and, furthermore, that it's irresponsible of D2Moto to suggest anything of the like. But at least they responded to you........I'll see what they have to say during the week, if I have to show up in person. I wish I'd had the luxury of testing multiple chains to find the best quality, but I'll have to go with the opinions of every consumer report on the subject, mostly because I value the continued functionality of my bike and my limbs. Not to be smart, but that's really what's at stake and my recommendation to everyone is to stay away from this brand when purchasing a part that's so crucial to safe operation. It's just not worth the savings. Again, not my first rodeo......I've used all the aforementioned chains in the same manner, using the same installation method, and the only one that failed (miserably so) was Volar. When they claim 10,280 lbs tensile strength, they're not just suggesting it will be good enough for small bikes......they're marketing to the largest of race/street bikes, and that is definitely a bogus claim. The only logical conclusion is that Volar is an inferior and unsafe chain. |
April 29th, 2012, 12:59 AM | #52 | |||||
April 30th, 2012, 02:02 PM | #53 |
Volar chains
You're right in that there are very few to zero reporting on this brand......I wasn't referring to specific reports, but rather the consensus that you get what you pay for, and that we should never sacrifice quality for pricing when purchasing such a crucial component.
For my part, I feel it's my obligation to try to reach every rider possible and relay my experience. You've had trouble, and I've had more trouble with Volar quality.........In essence, the only two bits of feedback anyone is finding so far. Whether these are isolated instances is up for debate, but the fact that two had potentially lethal failings is enough to warrant serious criticism. Hoping no one gets hurt or worse...........just spend the extra dollars, man. Let the experts test the things, and stay safe. |
April 30th, 2012, 02:06 PM | #54 |
Volar chains
At the very least, we gotta wonder where the hell is the quality control at the factory?? Someone is either dropping the ball, or worse, doesn't care and won't care until these issues affect his/her bottom line.
April 30th, 2012, 03:27 PM | #55 |
Join Date: Oct 2009 Motorcycle(s): 09 Ninja 250 Posts: 56
Just a suggestion, a few of the guys in my town that race and have 125/250's suggest (if using clips) to safety wire the clip and to be extra sure you can jb weld the the wire and pin connection to be extra sure.
http://www.gtamotorcycle.com/vbforum...nks-over-rivet |
April 30th, 2012, 03:46 PM | #56 |
Volar chains
Def a good idea to safety wire. Thanks, but I'll be riding only on a riveted link from now on.
Also, just a quick correction: Volar claimed 9,850lbs tensile strength, not 10,280 as I suggested earlier. I must've confused with another chain I was shopping. Sorry 'bout that! |
July 7th, 2012, 05:42 PM | #57 |
Well, just rolled last nite in from a trip to Canada last night to meet some of our northern bretheren.
While doing my post-trip lube up on the chain, I discovered a split o-ring. However, it's NOT on the master link or any of the adjacent ones. This is an RK520XSO chain with almost exactly 7,000mi on it. I fed my chain PJ1 Blue label every 500-800mi like clockwork and cleaned it with a very brief kerosene rinse two or three times (after which it was promptly air-compressor blow-dried). Kept the chain on spec for tightness the whole time and sprockets look fine. Any ideas how this happened? My only thought was trauma during my get-off at the track a lil over two months and 2,500mi ago, but the chain barely got dirty. I assume a fubar o-ring means the chain's done. Still haven't had time to do a thorough check of the rest of the chain for other bad rings, but I'm not thrilled about the early death of my $65 chain. OTOH, I ordered a spare master when I originally bought the chain, not knowing if it'd come with one or not. Assuming there aren't any other obviously bad rings, would it be insane of me to replace this link with my spare rivet master? Edit: After about 20 minutes looking, I'm missing 6 x-rings, and a handful more don't look so healthy. New chain in order. Bleh.
Proud member of the Blue Army Last futzed with by Momaru; July 12th, 2012 at 07:06 PM. Reason: Finally looked @ the chain in detail |
RK 520XSO Chain Clip vs Rivet Master Link | agentbad | 1986 - 2007 Ninja 250R Tech Talk | 5 | May 15th, 2014 07:35 PM |
DID 520VX2-106 X-Ring Chain with Connecting Link | willis9076 | 2013 - 2017 Ninja 300 Tech Talk | 2 | July 15th, 2013 07:50 AM |
Adding a rivet master link to the stock chain ??? | Tiane | 2008 - 2012 Ninja 250R Tech Talk | 1 | June 13th, 2012 12:58 AM |
Request: Silver chain, gold master link. | Mountain Dew | Pictures | 3 | January 25th, 2012 08:24 AM |
Is any 520 sized 106-link chain "the right chain?" If so, what's wrong with these? | CZroe | 2008 - 2012 Ninja 250R Tech Talk | 12 | March 24th, 2010 12:36 PM |
