April 3rd, 2014, 05:13 PM | #1 |
Join Date: Oct 2010 Motorcycle(s): 93 ninja 250 Posts: 111
need some electrical help
So i have a 93 ninja 250 and currently neither the low beams or brake lights are functioning, high beam works fine. check all the fuses, and all wiring seems to be in place. any ideas?
April 3rd, 2014, 05:18 PM | #2 |
April 3rd, 2014, 05:49 PM | #3 |
April 3rd, 2014, 06:07 PM | #4 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
They give those out at http://faq.ninja250.org/wiki/Main_Page
I just had my Ninjette headlight low-beam burn out last week. I pulled the front fairing off to make room to access the bulb. Is there an easier way to do it? (without being a gynecologist, anyway). |
April 4th, 2014, 12:04 AM | #5 | |
Join Date: Jan 2012 Motorcycle(s): YZF R15, CBR 250R, Ninja 250R, KTM RC 390 Posts: 15
turn the handle to the left approach from underneath the fairing and feel for the rubber mount of the headlamp. pull the connector out pull the rubber mount out( or whatever you call it) use your fingers to feel the clip. it disengages from the left side. take a pic by passing your cellphone underneath the fairing to get a better idea. though the clip( silver in colour) looks like it could be connected at both ends, it actually can be pulled out from the left. Pull the bulb out. check.if the filament is gone then you would need to push in the new bulb. please don't touch the glass area of the new bulb. the oil deposit could cause harm when it heats up. reverse the process and you are done. Yes, it needs some serious touch and feel. the first time might take some time but once you have mastered the art it's very very easy. yes, you would need the skill of a gynec This is for a 2012 ninja 250R why did i have to write so much? watch this video: http://youtu.be/EQc8xbNbARA |
November 26th, 2017, 12:01 AM | #6 |
Headlight not working :confused:
Hey Guys,
I got the same issues with my headlights.Low/High Beam not working. they stopped working on a ride home from work. Checked all fuses bulbs light up hooked up direct to battery. Changed relay to a heavy duty one. And yes I have the bike running to see if the lights go on or not. All wiring is intact. not cuts or exposed wires. Any ideas what it could be? |
November 26th, 2017, 03:31 AM | #7 | |
Join Date: Mar 2017 Motorcycle(s): 2007 Kawasaki 250 Ninja, 1982 Honda Ascot FT500 Posts: A lot.
Bill
Insanity: doing the same thing over and over again expecting different results each time. |
I got a little electrical problem. | infinitewhiskey | 1986 - 2007 Ninja 250R Tech Talk | 3 | August 8th, 2013 10:36 AM |
Will I be asking too much of my electrical system? | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 4 | June 2nd, 2013 07:16 AM |
Electrical | jarred6644 | 1986 - 2007 Ninja 250R Tech Talk | 10 | February 2nd, 2012 03:46 AM |
Electrical gurus | cuong-nutz | Off-Topic | 14 | December 18th, 2011 06:42 AM |
[motorcyclistonline] - New Permatex® Liquid Electrical Tape Keeps Electrical Connect | Ninjette Newsbot | Motorcycling News | 0 | February 26th, 2011 01:20 AM |
