Old February 18th, 2013, 01:14 PM   #1
ElJokerr
Motorcycle(s): 2006 Kawasaki Ninja 250R
Valve Clearance Problem
Hi, first time posting here. I own a 2006 Ninja 250, has about 21,000 miles on it, maintained very well with oil and filter changes at every interval recommended. I'm having problems starting it, especially when it's cold, it turns over, but it just won't get running. If the air temperature is warm, as it is around noon, it will struggle a bit but eventually start up. I pulled off the cylinder head cover to check the valve clearances, and the intake valves on cylinder 1 is way too tight, not even a .076mm feeler gauge will fit between the cam lobe and rocker arm, and the specs for inlet are 0.08mm-0.13mm. I turned the valve adjusting screw loose and turned it out to open up the clearance, but the clearance did not adjust at all, it's as if something is stuck. Our mechanic neighbor mentioned that it might be a bent rocker arm, or bent rod, but it's only a guess. I don't want to have to take apart the whole thing to replace everything and still have the same problem. I plan to fix this myself as I took it to the shop in December for the same thing, they did fix it, but the problem came back again and I'm not looking forward to wasting another $300. Any ideas on what might be the source of the problem? Any suggestions helps. Thanks.
Last futzed with by ElJokerr; February 18th, 2013 at 01:18 PM. Reason: Input of valve clearance specs limits
ElJokerr is offline   Reply With Quote
Old February 18th, 2013, 02:57 PM   #2
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
can you post a pic?
Old February 21st, 2013, 03:51 PM   #3
n4mwd
n4mwd's Avatar
Are you sure you have your crank exactly on the TDC mark for the cylinder you are working on? And not TDC + 1 rev? Lobes should be TDC and should look something like this "\ /".
The rocker arms don't really bend - they break. A bent rod would have no effect on valve timing.
My Ninja Blog
Old February 21st, 2013, 07:59 PM   #4
ElJokerr
I just barely got a call from the shop that I took it to, apparently there's no more adjustment available because the valves were wearing out and needs replacement. Basically what happened was that the valves were worn and went deeper into the seat, which tightened up the valve clearance between the cam lobe and rocker arm, thus disallowing space for adjustment. I'm having the shop do the valve job and it should be ready in about 12 days from now, more or less.
Old February 21st, 2013, 10:15 PM   #5
n4mwd
n4mwd's Avatar
Something isn't right here. First off, it should not have any serious problems at only 21K miles. You said you did all its maintenance. Did that include the scheduled valve adjustments every 6K miles?
My Ninja Blog
Old February 21st, 2013, 10:23 PM   #6
ElJokerr
Actually I didn't do the valve adjustment as required -_- lesson learned
Old February 21st, 2013, 10:39 PM   #7
cuong-nutz
cuong-nutz's Avatar
indeed. There's more to maintenance than changing oil.
HalfFast Racing Team
Old February 22nd, 2013, 05:54 AM   #8
n4mwd
n4mwd's Avatar
If your heads really are damaged, then you would be better off buying a new head set from ebay. A valve job alone would cost several hundred dollars. But again, I still say something isn't right with a failure at only 21K miles. Lack of maintenance would end up with the valves being held slightly open before they wore out the seats - resulting in a hard or no start condition.
Did you at least remove the rocker arm in question to see if there was anything strange about it?
My Ninja Blog
Old February 22nd, 2013, 07:39 AM   #9
lgk
Yea it definitely doesn't sound right.
You should have lots of adjustment left...
Old February 22nd, 2013, 12:40 PM   #10
FvnnyL3tt3r1ng
I have to 2nd (and 3rd) that it seems strange you need a valve job at this point.... If you post pics it would help a lot.
valve clearance sharky nrk 2008 - 2012 Ninja 250R Tech Talk 8 July 18th, 2014 06:19 AM
Should I do the valve clearance inspection myself? nickjpass The Ex-Ninjetters Lair 13 June 13th, 2014 12:50 AM
What is the Optimal Valve Clearance? krolinked 2008 - 2012 Ninja 250R Tech Talk 2 March 15th, 2013 02:25 AM
valve clearance specs dotsony 1986 - 2007 Ninja 250R Tech Talk 20 March 17th, 2011 02:46 PM
valve clearance??? what are they supposed... ecannon1 1986 - 2007 Ninja 250R Tech Talk 3 May 20th, 2010 10:41 AM
