Old March 3rd, 2018, 07:29 AM   #81
^^ Yepp. It's worth the science, but I found response was better (smoother and less agressive, therefore a little easier to work with) in the mid range with the factory slides than with drilled holes. I plugged mine and had zero issues for many miles. It's worth the science though!
They have a habit of snapping up and down. Good for going wide open, not so great for street mid throttle, which was more my use. NBD.
Remember that those slides move up and down in response to vacuum as a method of controlling the airspeed through the throat. This is why they're called Constant Velocity carbs. There's definitely some tuning to be done with when and how fast those slides move for optimal constantness, but that takes some serious time
Old March 3rd, 2018, 07:37 AM   #82
Originally Posted by maverick9611 View Post
#70 drill bits really need to be used in a pin vise. i used a standard chuck and had to wrap duct tape around the the end for a shim. i have extra bits if any one needs one.
An old trick is to wrap solder around the shank of the bit in a neat layer.
Old March 3rd, 2018, 08:50 AM   #83
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
good info the duct tape worked but barely
"trying not to get old"
DIY - Cleaning the Carburetor g21-30 2008 - 2012 Ninja 250R Tech Talk 11 January 10th, 2018 07:54 AM
DIY - Carburetor Sync'ing! VeX 2008 - 2012 Ninja 250R Tech Talk 86 April 14th, 2014 11:41 AM
Drilling off and replacing bar ends kdogg2077 2008 - 2012 Ninja 250R Tech Talk 15 January 16th, 2014 07:10 AM
Drilling the windscreen Kevin2109 General Motorcycling Discussion 32 March 19th, 2012 07:51 PM
DIY - Rebuilding the Keihin CVK Carburetor g21-30 2008 - 2012 Ninja 250R Tech Talk 4 April 8th, 2010 06:44 AM
