Old October 29th, 2017, 07:16 AM   #1
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
delkevic swingarm
another trick item from Indonesia
"trying not to get old"
Old October 29th, 2017, 09:28 AM   #2
That's pretty trick!
I was just thinking of bracing the factory arm with Columbus tubing and using a 4.5" rear wheel... Gonna have to do some weighing....
Old October 29th, 2017, 09:44 AM   #3
maverick9611
MOTM - Feb '18
trying to contact them. looks similar to zrx swingarm but inverted
Old October 29th, 2017, 09:47 AM   #4
maverick9611
MOTM - Feb '18
they say it allows for larger wheel
Old October 29th, 2017, 10:07 AM   #5
The 650R 4.5" rear wheel fits fine with thinner spacers. A 150 rear tyre is max as wider rubs chain. Not sure how they're fitting wider wheels, unless they put all extra width on right side.
An EX500 3.0" front wheel also fits, giving better support for radial tyres...
Yes, I'm piecing together my 250 Superbike machine for next season. Would be nice to be in races with more than 10 people!
Old October 30th, 2017, 05:19 AM   #6
verboten1
verboten1's Avatar
MOTM - June '15
You've done the 650 rear wheel? Please show me your setup if so.
Ride more, worry less.
Old October 30th, 2017, 01:14 PM   #7
Got all the parts coming in after researching. The N300 4.0" wheel is direct bolt-on, but if I'm going to get bumped into 250 Superbike for the upgrade, I might as well maximize it (along with Turbo and/or 2T engine). The swingarm on 650 is 13mm wider, so we have to remove 13mm from its wheel+spacer combo. Here's what I'm going to do:
- 17x4.5" 650 rear wheel + center spacer
- 650 cush-drive & sprocket
- 650 brake-disc
- N250R wheel-bearings
- N250R left spacer
- N250R inner-right spacer
- N250R brake-carrier
Process goes something like this:
- replace 650 bearings with N250R bearings
- mill 6.5mm off left-spacer
- mill 6.5mm off outside end of brake-carrier
- install
There may be some measurements I may be missing, such as sprocket/chain-offset on 650. So I'll compare when all pieces come in.
Old October 30th, 2017, 02:16 PM   #8
Here's good thread on customizing spacers, cush-drives and brake-rotors for wheel swaps.
https://www.garagejournal.com/forum/...d.php?t=187446
If you don't have your own mini-lathe, these guys can supply custom spacers
http://www.flattrackaccessories.com/FWheel.shtml
Depending upon load (weight, power, speed, etc.), making spacers from aluminium can save some weight, but can allow flexing and uneven bearing wear. Titanium is a good metal with densities, modulus and strength right in-between steel and aluminium. Bracing swingarm can help reduce this flex as well.
Old October 31st, 2017, 05:57 AM   #9
verboten1
verboten1's Avatar
MOTM - June '15
I've fit the wheel in the swingarm, but just barely. I think that the sprocket carrier will need to be milled down as well. I did that when I put the SV650 wheel in the 86 ninja swinger on my CB550F
I gave up on it, but if you need a swinger or wheel, I have them laying around
*edit*
I knew I had taken pictures at some point.
https://www.ninjette.org/forums/show...6&postcount=94
Old October 31st, 2017, 06:22 AM   #10
Abu_Mishary
The Asian Caucasian
Abu_Mishary's Avatar
Name: Abu Mishary Mohd Fairus
Motorcycle(s): Kawasaki Ninja 250 SE 2015 (sold); Honda ADV160 (current)
MOTM - Jan '17
Contacted them before to purchase items for my bike. Thought that it would be cheaper since Malaysia is just beside Indonesia and boy i thought wrong! It seems buying directly from USA is far cheaper than from Indonesia!
Losing someone is not painful. They are a part of us all this while and will always be with us. But missing them is.
Abu_Mishary is offline   Reply With Quote
Old October 31st, 2017, 11:45 AM   #11
*edit*
Ah, thanks. I figured I'd have to move the sprocket inwards by at least same amount left-spacer was shaved down. Simple enough remove studs and mill that down.
Old November 2nd, 2017, 05:09 PM   #12
GregS
Motorcycle(s): Ninja 300, GSXR-750, Ducati M1100
Only $260 although the shipping and handling would probably be a bit steep
GregS is offline   Reply With Quote
Old November 2nd, 2017, 11:46 PM   #13
maverick9611
MOTM - Feb '18
difficult to contact them. no replies on emails either. trying to find out how to pay if i purchased. they use indonesian banking stuff.
Old November 2nd, 2017, 11:58 PM   #14
maverick9611
MOTM - Feb '18
still confused bout method of payment. they ship worldwide.
Old November 3rd, 2017, 12:36 AM   #15
maverick9611
MOTM - Feb '18
they finally replied back, trying to find out about payment info
Old November 3rd, 2017, 09:21 AM   #16
I find using the chat works really well. Gets answers quickly.
Old November 4th, 2017, 01:51 AM   #17
Mohawk
Mohawk's Avatar
Motorcycle(s): ZZR250, VFR800
If you want a drop in alloy swingarm that's stronger & better than the skinny steel one that comes with it, then a KR1-S one drops right in. I fitted KR1-S front & rear to my ZZR250.
The pivot bolt on mine is 16mm the new SA is 20mm, I used a piece of stainless 20mm OD 16mm ID tube to make up the difference. I fitted a VTR250 rear wheel to match the KR 17" front (KR rears are 18") this setup will take up to a 160 tyre, but I'm on the stock ZZR 140 rear tyre. You need to make up so spacers to get the alignment for chain & I added a torque block to the swinger for the brake stay.
Old November 4th, 2017, 11:05 AM   #18
maverick9611
MOTM - Feb '18
i reaches to revzilla on why these parts are not stocked here. i sent them link to all the trick indo parts. here is what they said:
Hi Mike,
Thanks for your feedback! We will take a look and see what we think!
Best,
Joe
Joseph C.
RevZilla.com
877-792-9455
Follow us @RevZilla!
we all need to push on this
Old November 29th, 2017, 10:14 AM   #19
BernawanFR
BernawanFR's Avatar
Motorcycle(s): Kawasaki Ninja 250R 2011
Hello, this probably is a late reply but better than none
Talking about Delkevic swingarm and wheels set, it is the main recipe for Indonesian Ninja 250/300 modification, around 60% of member in my Ninja250 Community in my town apply Delkevic sets on their bike
Costs us around
$200 - swing arm (up to 6.0)
$350 - front 3.5 inches and read 5.5 inches wheels
$250 - 120/60 and 180/55 tyres
bigger rear sprocket is recommended, since changing swing arm and bigger wheel and tire might add some weight. Just add $100 for sprox and chain
Delkevic bigger wheels set is the most popular product in my country, can be easily found in local motorcycle mods shop, the mechanics on the shop would install those parts for you, and you could just sit down, relax while drinking iced tea.
Talking about the payment, yes it's going to be difficult because they are using local bank transfer method instead of Paypal, and sorry to say, I'm quite familiar with the shop you showed on above pic, it's a little bit overpriced, but if you're okay with that then it's a green light for ya. You might want to try to contact "MotoChief" which the contact can be found on Instagram (just search motochief) and send a direct message. Indonesian shops are not familiar with websites, mainly because it's not free, and social media like Instagram can be accessed easily and freely by Indonesian.
I'm telling you, Asia (especially Thai and Indonesia) is your motorcycle mods heaven, trust me
BernawanFR is offline   Reply With Quote
Old November 29th, 2017, 10:31 AM   #20
maverick9611
MOTM - Feb '18
no this thread isn't dead. we need members to come forth and show indonesia is doing cutting edge mods to the 250 ninja. maybe the 60% you mention will join this forum. i will keep digging into how to pay by contacting these pay institutions and navigating payment options. would be great if a shop knew peeps in the usa are interested in buying their products.
Old November 29th, 2017, 11:44 AM   #21
That swingarm is way more than I need. What I do want is two sets of V-Rossi wheels in 17x3.0/4.5".
I think we can pay a fee for someone to organize an LCL shipment.
Old November 29th, 2017, 06:48 PM   #22
Abu_Mishary
The Asian Caucasian
MOTM - Jan '17
Hey BernawanFR, nice seeing you here. Can't you advice them on how to set up a PayPal account? I could see that this is a good business opportunity here for the American market. Maybe Ninjette could also be the authorized distributors for all these mods.
Old November 29th, 2017, 07:42 PM   #23
Hmmm, design flaw on that swingarm. Needs an additional gusset connecting bend in brace to swingarm.
Old November 30th, 2017, 01:12 AM   #24
BernawanFR
BernawanFR's Avatar
Hey there mate, it's been a while
The first thing I'm gonna do is to ask whether the shop has Paypal account or not. If they don't own one, I'll make sure to talk to the owner that American and prolly European market are willing buy.
Interchangeability 08 to 14 delkevic slipon mikedabike64 General Motorcycling Discussion 1 July 21st, 2015 04:24 PM
Delkevic DS70 Renner 2008 - 2012 Ninja 250R Tech Talk 4 June 28th, 2012 09:27 AM
Thoughts on this exhaust? - DELKEVIC caphilli 2008 - 2012 Ninja 250R Tech Talk 16 November 29th, 2011 11:28 AM
