Old February 26th, 2018, 08:26 PM   #1
Larbronson
Larbronson
Motorcycle(s): 07 ex250f
Got fuel? In the exhaust pipes?
I do. But not the crankcase! How is that possible.
Petcocks good, I have the floats set at 20- 21mm.BUT... no fuel filter.so I get it. Googling the prob. Seems there's a lot of it happening but dumb a's are you sure it's gas, not condensate, bad petcock,. I see it's a common problem and explains a lot of other ones I've been having.
Why isn't the crankcase full? Is there another explanation besides floats? It's hard to start, dies at stop signs etc.
Last futzed with by Larbronson; February 26th, 2018 at 08:30 PM. Reason: More info
Larbronson is offline   Reply With Quote
Old February 27th, 2018, 03:13 PM   #2
Do you have a cylinder that isn't firing right? That would explain all the symptoms you've listed. Been there, done that. Check the plugs/leads/coils for signs that one cylinder might be failing to fire reliably (charred leads, etc).
Why do you assume that the case would have to be full of fuel for there to be fuel in the exhaust pipe?
Are you sure it's fuel in the pipe as opposed to oil?
Old February 27th, 2018, 03:39 PM   #3
Yeah, fuel not igniting would go out exhaust-valve into exhaust pipe...
Old February 27th, 2018, 04:59 PM   #4
Larbronson
Larbronson
Hey guys thanks for the replies.
Definitely gas, I left the fuel cock on while I was at work. I checked my gas level before I left the house to work and had half a tank. After work , it had a little puddle when I went to start it, that's kinda normal (I'll explain later). But I did my normal hard to start routine...... bike didn't even attempt to fire. I look down and there's a gas puddle past my rear tire And fuel pouring out underneath my foot pegs.so naturally I think it's the overflow tube so I shut the petcock off. Wait a few minutes and the puddle was bigger and fuel is still pouring down. I pull the overflow tube and it's dry , look way underneath and fuel was coming out where the muffler is clamped to the header on the right side and just before the muffler on the left. Look inside my tank and it was almost dry. ( live 3.6 miles from work).....
So MAYBEEEE.....my overflow PORT is plugged, floats stuck and, vacuum line to petcock pinched and fuel filled the cylinder for 8 hours. When I went to start it pushed all the fuel out of the cylinders into the exhaust. And have excellent oil rings because I only have oil in my crankcase no gas.
Last futzed with by Larbronson; February 27th, 2018 at 05:16 PM. Reason: More to the story.
Old February 27th, 2018, 05:19 PM   #5
Larbronson
Larbronson
This is the first set of the vacuum carbs I've worked on so I didn't open the top or side vac says. Just jets an floats. Covers, not says.
Old February 27th, 2018, 05:24 PM   #6
Larbronson
Larbronson
Bike runs smooth to 5000 rpm. 5 to 9 sputters, 9 to 13 pulling wheelies in 3rd gear.
Old February 27th, 2018, 05:46 PM   #7
VaFish
VaFish's Avatar
MOTM - Jan '16
Sounds like you just need to ride WFO all the time.
Old February 27th, 2018, 05:48 PM   #8
Larbronson
Larbronson
Lmao, only does 105 mph.
Old February 27th, 2018, 07:23 PM   #9
FYI: no need to turn off the petcock on a daily if it works. It's vacuum operated, not manual.
Sounds like you have more going on than you originally let on.
Old February 27th, 2018, 08:16 PM   #10
1. Petcock defective, it's stuck open even without vaccum
2. Float valves not working to close off fuel-feed
Old February 27th, 2018, 08:16 PM   #11
Larbronson
Larbronson
Right? But that's only on the 2017-19 at least that's what I noticed on Google, earliest post I found was 2009 on a 2007. About 2 year old bikes start having pcock problems.
I think the fuel may be seeping (pouring) from the main jet needles.looking at the slant of the carbs., and the way the overflow tube is routed higher than the venturi may be most of the problems.
I'd like to see what Ducatiman has to say.??
Old February 27th, 2018, 08:21 PM   #12
Larbronson
Larbronson
I thought the gas leak and puddle I mentioned earlier was do to the guy I bought it from put the wrong bolts in the upper fairing to tank mounts and punctured through.
Old February 27th, 2018, 11:31 PM   #13
Well, there can be more than one leak. Thoroughly clean outside of engine; so clean you can eat off it. Completely dry with hairdryer. Get strong flashlight and mirror-on-a-stick.
1. Unbolt fairing from tank and LOOK at where bolts would puncture tank. Is there a hole on either side? Is there gasoline pouring out?
2. Look at puddle of gasoline on ground. Look upwards from centre of puddle. Do you see gas dripping down into puddle? Use flashlight and mirror to trace path of drip upwards. Is it falling onto top of exhaust and wrapping around as it drips?
Use a dye and fluorescent blacklight to find path of gas from inside tank to the ground. https://www.walmart.com/ip/TRACERLIN...71620/46243614
Pipes/Exhaust Kiid-_-Buru 2008 - 2012 Ninja 250R Tech Talk 19 July 27th, 2015 09:36 AM
Cleaning Exhaust Pipes khaoz069 2008 - 2012 Ninja 250R Tech Talk 9 April 1st, 2015 02:45 AM
My attempt at removing rust from exhaust pipes SamBizzler 1986 - 2007 Ninja 250R Farkles 4 January 17th, 2013 08:15 PM
2 Stroke Exhaust pipes? chitor 2008 - 2012 Ninja 250R Tech Talk 12 July 2nd, 2011 06:58 AM
