Old October 12th, 2017, 09:18 AM   #1
maverick9611
"a legend in my own mind"
maverick9611's Avatar
MOTM - Feb '18
valve timing question
i noticed that my timing somehow moved. prior to removing cams i set alignment dots up on the inside and verified it was on 2t. now that i everything back together i notice the 2t mark has moved. i never moved the crankshaft and set cams back in dot to dot(actually line to line as my painted dots were not painted correctly)
do i need to pull valve cover and retime again?
why did it move?
could it have moved when i loaded up cct?
"trying not to get old"
Old October 12th, 2017, 09:27 AM   #2
Did you rotate crank to tighten pulling side of chain before releasing CCT? Or rotate cam backwards slightly?
You need pulling side of chain fully tight and CCT side loose before releasing CCT. If both sides of chain are evenly loose, the CCT will tend to pull cam backwards when released.
Old October 12th, 2017, 09:36 AM   #3
maverick9611
MOTM - Feb '18
no i didn’t do this. of all the reads on this i didn’t see this or i missed it. thanx for the info. so pink mark must align with the little metal tab? if i do the rotate cam backwards would alignment dots be slightly up or down?
Last futzed with by maverick9611; October 12th, 2017 at 02:31 PM.
Old October 14th, 2017, 09:04 AM   #4
maverick9611
MOTM - Feb '18
ok, i have valve cover off and spark plugs loose. i have indicator set. i noticed my painted timing lines are off. on exhaust it’s high, intake low. it looks like i’m 1 tooth off
Old October 14th, 2017, 10:01 AM   #5
maverick9611
MOTM - Feb '18
ok, i have valve cover off and spark plugs loose. i have indicator set. i noticed my painted timing lines are off. on exhaust it’s high, intake low. it looks like i’m 1 tooth off. just reset again. same result. soon as the cct loads. crank moves and timing looks off. i jumped one tooth also
Old October 14th, 2017, 10:51 AM   #6
maverick9611
MOTM - Feb '18
after reviewing the diy. my alignments look exactly the same
diy pic
my alignment
Old October 14th, 2017, 11:14 AM   #7
maverick9611
MOTM - Feb '18
is your cam timing out of phase?
i don’t think so. the diy pic looks like similar to my cam phasing.
Old October 14th, 2017, 11:22 AM   #8
disagree...look closer
the EX cam line is pointed FORWARD to the cc seam....
the IN cam line is pointed BACK to the intake side cc seam
Any Kaw I've *ever* done..the cam timing is situated per the drawing.
Yours out 180 degree?
Note on drawing the arrowed timing marks are situated to the FAR left and right. Yours *between*.
Old October 14th, 2017, 11:27 AM   #9
maverick9611
MOTM - Feb '18
there is no punch mark either. when i bring up ex on left side there is no punch mark up on top
Old October 14th, 2017, 11:32 AM   #10
maverick9611
MOTM - Feb '18
did you look at the diy pic? it looks exactly like mine. obviously the paint marks are wrong. the painted above the ex line and below the in line. i’m looking at the actually lines on the sprocket.
Old October 14th, 2017, 11:49 AM   #11
Apologies-
your newgen timing position is completely different to earlier, traditional cam timing I'm familiar with.
There is a old 2008 valve clearance thread by user "Vex" , mentioning the timing mark apparently being off too, similar to your situation ...found in a google search..
Disregard my comments, I'll sheepishly return to the carbs I'm working on.
Old October 14th, 2017, 11:59 AM   #12
maverick9611
MOTM - Feb '18
Apologies-
that's ok i looked at the 2008 manual. you bring ex on exhaust sprocket and count 36 pins over to in on intake sprocket. guess i need to do this to be sure
Old October 14th, 2017, 12:00 PM   #13
maverick9611
MOTM - Feb '18
Apologies-
can u fire that link to me
vulcan9611@gmail.com
Old October 14th, 2017, 12:12 PM   #14
sent.
You get my envelope?
Old October 14th, 2017, 12:25 PM   #15
maverick9611
MOTM - Feb '18
sent.
not yet, but mail hasn’t come yet today. thanx again🍺
Old October 14th, 2017, 05:32 PM   #16
Schweedo
Schweedo's Avatar
Motorcycle(s): 2012 Ninja 250, 2007 YZF600R
I just went through this doing my first valve adjustment, it looks like the cams may or may not be a tooth off but the problem is having the chain slack on the wrong side of the crank when the cct is reinstalled. If the slack is on the opposite side of the crank it will spin the crank to take the slack out.
Schweedo is offline   Reply With Quote
Old October 14th, 2017, 10:12 PM   #17
maverick9611
MOTM - Feb '18
after searching for hours. finally found this via google search. the how to valve adjustment with pictures needs to be updated with this post to get proper valve timing.
https://www.ninjette.org/forums/showthread.php?t=288741
Old October 17th, 2017, 10:21 AM   #18
wickedstock
Motorcycle(s): Honda VFR400R
Awesome pic.
wickedstock is offline   Reply With Quote
[RideApart] - BMW GS Series to Get Variable Valve Timing? Ninjette Newsbot Motorcycling News 0 August 2nd, 2017 05:00 AM
[motorcyclistonline] - What Is Variable Valve Timing (VVT)? Ninjette Newsbot Motorcycling News 0 January 3rd, 2017 08:30 AM
[sportrider - tech] - Inside Suzuki's Variable Valve Timing Ninjette Newsbot Motorcycling News 0 April 7th, 2016 01:10 PM
[motorcycle.com] - Ducati DVT Desmodromic Valves Meet Variable Valve Timing? Ninjette Newsbot Motorcycling News 0 October 10th, 2014 11:31 AM
[visordown.com] - Variable valve timing for new 2015 Ducati Multistrada Ninjette Newsbot Motorcycling News 0 October 10th, 2014 04:10 AM
