Old May 10th, 2013, 11:29 AM   #1
Time Mage
2007 Ninja 250 won't start
Hi, I have a 2007 Ninja 250 and it has been sitting for 8 months while I was at school. Now when I try to start it the bike makes a clicking sound that sounds like it is coming from the fuse box.
-Tested the battery and it shows 12V.
- Bike won't bump start. It seems like the rear wheel is locked and it skids.
- Screwdriver across solenoid does not start the bike.
-Jumping the relay does not turn the starter motor, and the voltages to the relay are normal.
-All fuses intact.
Time Mage is offline   Reply With Quote
Old May 10th, 2013, 11:32 AM   #2
Try turning the engine by hand first.
Use the plug on the left side engine's cover.
Old May 10th, 2013, 11:45 AM   #3
lgk
first cast haste on the starter motor, then thundaga on the battery.
nm, just check the battery and crank the motor by hand
Old May 10th, 2013, 02:12 PM   #4
Charge the battery. It may be showing 12V with no load, but still have not enough energy to engage the starter.
Old May 10th, 2013, 02:26 PM   #5
dead battery.
also, jump start the bike in 3rd, not first. when you let the clutch out, jump or land on your butt... basically push the rear wheel down with your body weight when you let the clutch out so it doesnt skid
Old May 10th, 2013, 06:19 PM   #6
Time Mage
Thanks I'll try these and report back tomorrow. I really hope it isn't the battery I replaced it before I left for school.
Old May 12th, 2013, 11:43 AM   #7
Time Mage
Well I put it on the center stand and turned it on, put it in first gear with clutch out, and tried to spin the rear wheel and it didn't move very much before locking.
Old May 12th, 2013, 12:31 PM   #8
Old May 12th, 2013, 01:56 PM   #9
Time Mage
Originally Posted by Motofool View Post
Heh I don't know much about bikes but a friend told me to try to turn the wheel by hand enough to turn the engine a bit. I also tried jump starting it again with no luck. When my friend is free he will try to turn the engine by hand.
Old May 12th, 2013, 02:55 PM   #10
Heh I don't know much about bikes but a friend told me to try to turn the wheel by hand enough to turn the engine a bit........
Now I see, thanks
If it didn't turn with a jumping cable (the donor's engine should have been off), then, your engine may have something internal preventing it from turning.
If your friend cannot make it turn by hand (no excessive force), he may want trying taking both spark plugs out and pouring some drops of Magic Oil into each cylinder for overnight soaking.
Old May 13th, 2013, 02:49 PM   #11
ilanidrac
ilanidrac's Avatar
Motorcycle(s): Yamaha RD350, H-D Electraglide, BSA Lightning, Suzuki GS550
I will give that a shot next time I can get over there. I think I have some Marvel Mystery Oil somewhere to try for that too. Will update as soon as we can!
03 H-D Electraglide, 75 Yamaha RD350 cafe, 79 Suzuki GS550L with sidecar hack, 71 BSA Lightning 650, 14 Ducati Monster 796
ilanidrac is offline   Reply With Quote
Old May 13th, 2013, 04:21 PM   #12
Felipe the Ant
Motorcycle(s): 2011 Ninja 250R SE GREEN!
You're not gonna spin the engine by hand through the wheel or bump start it after it's been sitting, the carbs are most likely clogged. Your battery should read 12.6V+ if it's fully charged, 12.4(iirc) or less if it's dead. The clicking is your starter solenoid, your battery is dead. Either charge it or clean the carbs and try to bump it again. When you bump it you have to slam your ass down on the seat when you drop the clutch or it'll skid like you said
Also when you're getting moving to bump start it leave the transmission in neutral until you're ready to drop the clutch, less friction that way. Easier on the pushers
Trust me, I'm a banana!
Felipe the Ant is offline   Reply With Quote
Old May 13th, 2013, 04:33 PM   #13
CC Cowboy
CC Cowboy's Avatar
MOTM - Mar '13, Jun '14
Firstname, Glide, RD, and Lightning. You are a lucky man. I'll pretend I didn't see the GS550.
Get a tie down and pull the 250 with Glide. Get your speed up to about 35MPH and have him dump the clutch. Make should you get it on video!
Old May 14th, 2013, 02:21 PM   #14
ilanidrac
ilanidrac's Avatar
haha yup I have a few toys! And the GS550 is actually pretty fun with the sidecar on it
Going to have to tear into it hopefully this week(end). Gotta get this thing running. Havent had much of a chance to go over to look at it because my job has been wrecking me haha
Old May 20th, 2013, 06:45 PM   #15
ilanidrac
ilanidrac's Avatar
Just as an update, the bike is running now. I took the battery to my place and put it on a tender here. It actually charged like it should have.
Put the battery back in the bike, and it started right up.
Thanks for all the other suggestions though!
Old May 21st, 2013, 10:19 AM   #16
Old June 14th, 2013, 01:12 PM   #17
Time Mage
Another update The bike did run after charging but the battery won't hold the charge. After a few days the bike wouldn't start. I can bump start it and a couple times (if i ride 30+ minutes) it will turn on again but the battery dies pretty quickly and if it is a short ride then there is no chance of it starting. My friend doesn't have time to check it out so I'm bringing it to a bike place nearby. At least I can ride it there.
Old June 14th, 2013, 03:17 PM   #18
FvnnyL3tt3r1ng
FvnnyL3tt3r1ng's Avatar
Motorcycle(s): Ninja 250 2001
You can get the battery tested for free at autozone/advanced/napa.... Cheaper than a mechanics hourly rate
Old June 14th, 2013, 03:21 PM   #19
fishdip
fishdip's Avatar
Motorcycle(s): 250/300
I had to do this with a 600gsxr
Old June 14th, 2013, 03:26 PM   #20
lgk
so its a stator/regulator issue then?
Old June 14th, 2013, 08:40 PM   #21
Time Mage
Thank you I will do this tomorrow.
Old June 17th, 2013, 09:01 AM   #22
Memengkamatis
Memengkamatis's Avatar
Motorcycle(s): ex250r, vulcan 800b, k1200r
Talking Faster
FishDip, me wanna go fast/ brakes no apply, mee fly.
Memengkamatis is offline   Reply With Quote
Old June 17th, 2013, 10:24 AM   #23
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
I'm faster bud
AFM #676
Supersports are for n00bs
Old June 17th, 2013, 10:02 PM   #24
Time Mage
I had the battery checked and they said it looks fine just needs a charge so I'll be bringing it in.
Old June 17th, 2013, 10:14 PM   #25
Jiggles
Jiggles's Avatar
MOTM - Apr '13
How about Santa Clara and Santa Teresa
AFM #676
05 Ninja 250 won't start on its own - help! AmyF 1986 - 2007 Ninja 250R Tech Talk 59 July 8th, 2014 11:46 AM
Ninja 250 won't start! please help me! Black knight 2008 - 2012 Ninja 250R Tech Talk 4 May 23rd, 2013 03:22 PM
06 ninja 250 won't start wolfpuss 1986 - 2007 Ninja 250R Tech Talk 7 February 21st, 2012 05:57 PM
2007 won't start, not even getting neutral or oil warning lights! davidfriend 1986 - 2007 Ninja 250R Tech Talk 13 May 6th, 2011 09:51 PM
2007 250 Won't Start mveezy 1986 - 2007 Ninja 250R Tech Talk 16 June 28th, 2009 06:24 PM
