Old June 28th, 2013, 01:10 PM   #1
indr
Downshifting Probs
Upshifting is fine. To downshift, I have to really slam my foot on the gear change lever.
When I rebuilt the engine, I changed out both springs on the gear change mechanism.
indr is offline   Reply With Quote
Old June 29th, 2013, 04:29 AM   #2
tubarney
How did you install that big spring? Was it like this?
Are the internals of the neutral bolt installed?
Old June 29th, 2013, 09:33 AM   #3
sLick415
Since were on the topic (really don't mean to thread jack), what's part# 92027 for?
sLick415 is offline   Reply With Quote
Old June 29th, 2013, 10:00 AM   #4
indr
Yes. Neutral bolt? What is that?
Old June 29th, 2013, 10:01 AM   #5
indr
It's a plastic spacer that goes on the outside of the crank-case. It sits between the crankcase and the sprocket cover (I think) on the shift shaft.
Old June 29th, 2013, 08:06 PM   #6
tubarney
Yeah it a spacer that matches the internal diameter of the big spring. So the spring has less chance of bending out of shape.
Old June 29th, 2013, 08:07 PM   #7
tubarney
This thing. http://www.ninjette.org/forums/showt...t=neutral+bolt
Also make sure the teeth that turn the drum are properly located. I'll get you a photo.
Old June 29th, 2013, 08:25 PM   #8
tubarney
Here how it should look.
I had problems shifting mine when I put it back together. Turns out it was the neutral bolt and big spring.
Old June 29th, 2013, 10:01 PM   #9
indr
Thanks for that. I'll open up the clutch cover and see how it looks. I'm pretty sure I got it right though. Both springs were new, and the teeth hooked on fine.
Also, when you pulled apart the shift shaft, did you notice any side-to-side play between the upper and lower teeth like this?:
Old June 29th, 2013, 10:02 PM   #10
indr
Also, what was wrong with your neutral bolt? I pulled mine out along with the little cylinder. They seemed fine.
Old June 29th, 2013, 10:04 PM   #11
indr
You mean it goes under the spring? I left mine out. It sits between the sprocket cover and the crankcase as a spacer.
Old June 30th, 2013, 01:07 AM   #12
tubarney
Yes you will get side play. That is normal. I was wondering about that to. I have a second engine and it was the same. Mine is like that and shifts perfectly after I sorted out the spring and neutral bolt.
Old June 30th, 2013, 01:08 AM   #13
tubarney
I didn't have mine installed. You can remove the internals so if they were missing it would be the same as not having it installed.
Old June 30th, 2013, 01:13 AM   #14
tubarney
The spacer goes on the inside of the big spring(where I am pointing the knife). You have to take the shaft out of the engine to put it on.
note: the shaft is not pushed in all the way. The Spacer is not installed!!
It could be causing the spring to bend out of shape.
The spacer stops the spring from moving around on the shaft.
Old June 30th, 2013, 01:15 AM   #15
tubarney
Also, If you haven't already, on the other side of the engine check that your linkage is not hitting your kickstand or something.
Old June 30th, 2013, 09:43 AM   #16
indr
This was the problem. I had the ends of the springs installed crossed. Not like the photo. Fixed it. I had yet to take it out for a ride, but now, there is definite tension on the shift lever. Before it was sloppy with no "springiness."
2009 ninja 250 blinker probs Cereal 2008 - 2012 Ninja 250R Tech Talk 5 September 19th, 2014 01:36 AM
starting up probs UltraHarley1 2008 - 2012 Ninja 250R Tech Talk 3 June 16th, 2014 07:33 AM
Downshifting woes RogerPapaMike 1986 - 2007 Ninja 250R Tech Talk 14 April 30th, 2014 10:20 AM
Downshifting for turns dcx4610 Riding Skills 106 October 24th, 2012 01:31 PM
Downshifting akshay11 Riding Skills 17 March 18th, 2012 02:52 PM
