Old May 11th, 2019, 11:32 PM   #1
Samahorn
Motorcycle(s): 2003 ninja 250
Need help dead bike
So I’ve recently decided to take my 2003 ninja 250 and turn it into more of a streetfighter / cafe style bike. I stripped it down , road it while is was stripped, decided it needed clip ons , so I ordered them. Install went smooth ( or so I thought ) it was running literally the second before I installed the new bars. Now the bike it completely lifeless, turn the key. Nothing. Push the start. Nothing. No dash lights, no oil lights. I replaced all the fuses. Nothing. Even tried Jump starting thinking maybe I just left the key on. Nothing. I looked for pinched wires and couldn’t find anything. Any advice would help. Really trying to avoid taking it to the shop. Considering the labor is like 120 an hour. Thank you !
Samahorn is offline   Reply With Quote
Old May 12th, 2019, 07:08 AM   #2
Welcome,
Did you check the main fuse?
Old May 12th, 2019, 10:03 AM   #3
Samahorn
Where would that be located ?
Old May 12th, 2019, 10:14 AM   #4
This should help...
https://faq.ninja250.org/wiki/How_to_check_the_fuses
Hope it's an easy fix for ya.
Old May 12th, 2019, 12:10 PM   #5
Samahorn
So it was the main fuse, but as soon a I put a new one it it blew as well
Old May 12th, 2019, 12:20 PM   #6
Something is definately shorting out.
1st, make double sure you connected the battery properly. + is red, - negative. Then, move to the throttle side and double check your wires going to the switches. If need be, take it apart and replace the fuse. If nothing blows, then you know for sure your issue is there.
Old May 12th, 2019, 01:26 PM   #7
Samahorn
Redid battery connections and bought new fuses , running like a champ. Thanks so much for your help
Old May 12th, 2019, 01:31 PM   #8
Was the battery connected backwards?
Old May 12th, 2019, 02:59 PM   #9
Samahorn
Not at all. Just undid the connections and tightened them back up.
Old May 12th, 2019, 03:55 PM   #10
Huh... that doesn't explain a blown fuse. You may have an intermittent short circuit that will show up again.
Old June 4th, 2019, 10:27 PM   #11
Ducati999
Motorcycle(s): Ducati 999 2012 Ninja 250r Ducati748 Yellow finally running 2003 SV650 S (SOLD)
I agree with @tripple Jim, you need to check if you damaged any of the wires up front when you added the triple clamps or something else.
Ducati999 is offline   Reply With Quote
Bike is dead! kris5495 2008 - 2012 Ninja 250R Tech Talk 12 June 10th, 2015 07:22 PM
[SPOILER] The Walking Dead - New Bike akima Pictures 13 April 9th, 2015 03:40 PM
dead bike smrr1 1986 - 2007 Ninja 250R Tech Talk 16 December 1st, 2012 06:22 PM
[urgent] my bike is dead. Very dead. Now what? arnoldc6 Riding Skills 15 September 8th, 2012 08:04 AM
15 miles on new bike = dead tach JoeLansing 2008 - 2012 Ninja 250R Tech Talk 7 June 12th, 2011 03:31 PM
