Old May 17th, 2019, 03:42 PM   #1
Seirra117th
Motorcycle(s): Ninja 250r 2008
Choke setup wrong.......idle and throttle issue?
Hey everyone, ive been looking onlune about this but cant seem to find much so any opinions are quite welcomed
got a ninja 250r prev owner new nothing bout the bike
i start it up with a little issue with idle
when started goes to 900rpm and slowly rises too 1350rpm
this is all with the choke off
rev when warm gets to 2000 then drops to 1300 or stalls (probably the main jets)
if i use the choke to start its harder.......choke currently has alot of free play........
when the bike first starts should the rpms be above or below the 1350 warmed engine
and have they possibly miss set the pilot screw based off how the chokes current setting
thanks for any help its always appreciated
Seirra117th is offline   Reply With Quote
Old May 17th, 2019, 04:22 PM   #2
Seirra117th
ok chokes actually set right.......got confused for a sec.......when i pull the choke forward it doesnt affect the rpms in a positive way until almost all the way open
best in the 70% to 80% range
but overall starts in the cold 15 deg cel with just a little effort
Bike not idling below half choke, idle screw not affecting idle speed Zaraki_Kenpachi 1986 - 2007 Ninja 250R Tech Talk 2 March 6th, 2020 11:13 AM
Requires choke to idle, bogs at half throttle Gregjnolan 1986 - 2007 Ninja 250R Tech Talk 9 February 8th, 2016 03:01 PM
bike idle and throttle issue randomwalk101 2008 - 2012 Ninja 250R Tech Talk 5 January 18th, 2015 04:53 PM
Idle jumps to 9000 rpm on choke then wont stay idle after off Shawn250 2008 - 2012 Ninja 250R Tech Talk 1 June 19th, 2012 06:45 AM
Idle Speed, Choke, and Throttle Hunting on a New-to-me '07 CantDecide 1986 - 2007 Ninja 250R Tech Talk 2 April 28th, 2011 07:59 AM
