Old May 29th, 2019, 12:06 AM   #1
Tooch
Tooch's Avatar
Motorcycle(s): 2008 Ninja 250, 2015 zx10r, 2010 Ducati 848
Tach wire picture
If anyone has time, can someone take an actual picture of where the tach goes into the engine? Mine randomly stopped working one day... And I'm garbage at wiring diagrams. Also, any other suggestions? I've read that the tach needles randomly get stuck? It's an '08 with about 5000 miles
Tooch is offline   Reply With Quote
Old May 29th, 2019, 02:52 PM   #2
Trace black wire from left coil.
Not sure what can be done though.
Seems early '08 models had some issues with ignition box overheating and giving erroneous tach reading.
Old May 29th, 2019, 09:21 PM   #3
Tooch
Tooch's Avatar
Hmmmm.... The bike was cold on startup. Happened almost immediately after starting. Hopefully not that. I was thinking a loose wire, or worst case swapping the tach...
Old May 29th, 2019, 09:44 PM   #4
1. Sure, measure resistance between black-wire connector at left-coil to other end of that wire at cluster connector.
2. Would also need to measure resistance of segment between cluster connector to tach circuit-board itself.
3. Then there's signal itself on that wire. Would need oscilloscope to inspect that signal. Should look something like this with logic high most of the time with grounding drops to fire coil.
Also look at circuit board of tach for ballooned or blown capacitors.
Old May 29th, 2019, 09:50 PM   #5
Tooch
Tooch's Avatar
Thanks for the places to look, I appreciate it!
Tach Signal Wire Color??? ninjabeesh General Motorcycling Discussion 11 May 17th, 2016 09:06 PM
[American Motorcyclist Association] - Near-perfect wire-to-wire effort gives veteran Ninjette Newsbot Motorcycling News 0 March 11th, 2015 07:40 AM
[kropotkin thinks...] - 2014 Argentina Moto2 Race Result: Winning Wire-To-Wire Ninjette Newsbot Motorcycling News 0 April 27th, 2014 09:30 AM
[kropotkin thinks...] - 2014 COTA Moto3 Race Result: A Wire To Wire Win Ninjette Newsbot Motorcycling News 0 April 13th, 2014 10:10 AM
[motorcyclistonline] - Wiles Goes Wire to Wire at AMA Pro K&N Filters Grand National Ninjette Newsbot Motorcycling News 0 June 21st, 2010 06:40 PM
