Old May 29th, 2019, 03:39 PM   #1
achimedes
achimedes's Avatar
Motorcycle(s): 2012 ninja 250r
Turn signal bolt
I removed this turn signal bolt and when I try to replace the screw will turn forever and doesn't lock into anything. I checked my Clymer maintenance book and past threads on here and didn't find any solutions to this. Is there supposed to be a bolt on the other side? If so, I don't have one anymore. Any ideas?
achimedes is offline   Reply With Quote
Old May 29th, 2019, 04:32 PM   #2
Ralgha
Ralgha's Avatar
There is supposed to be a metal piece, basically a plate, on the inside of the fairing that it screws into.
Part number 92200: https://www.bikebandit.com/oem-parts...4178#sch731569
It's possible that the plate fell off or got pushed out of position enough that you can't get the screw back into it. You may have to take off the fairing to see what happened to it.
bike * miles = smiles
smiles / bike = miles
smiles / miles = bike
Old May 29th, 2019, 05:37 PM   #3
achimedes
achimedes's Avatar
Thanks man
Old May 29th, 2019, 09:46 PM   #4
Yeah, reach in behind fairing and follow wire away from hole in fairing. Plate probably slid down to lowest part of wire.
Old May 29th, 2019, 10:13 PM   #5
achimedes
achimedes's Avatar
Yep that's exactly what happened
Looking for 09 oem rear turn signal and front turn signals and tail fairings mbbernas Items Wanted 1 September 11th, 2013 10:48 AM
turn signal help akcalhoun 2008 - 2012 Ninja 250R Tech Talk 24 February 25th, 2013 06:09 PM
How to fix turn signal? 47ninja 2008 - 2012 Ninja 250R Farkles 2 May 18th, 2012 06:46 AM
Turn signal problem!!! danjaho 2008 - 2012 Ninja 250R Tech Talk 1 March 23rd, 2011 07:25 AM
Turn signal went out, looking for a new turn signal austinm911 2008 - 2012 Ninja 250R Farkles 3 January 23rd, 2011 08:58 PM
