Old June 1st, 2019, 08:20 AM   #1
ducatiman
ducatiman's Avatar
for all those bread tie lovers out there
Cleaning all my spare jets, Mikuni and Keihin maybe 30-40? Out of them all I encounter 1 severely clogged pilot jet, 3-4 courses of ultrasonic and intense compressed air...still clogged....its a 38 Keihin (stock 250) pilot, now I'm determined to see wassup... I hit it with a .013" guitar string....first into the jet from top (still blocked) then backwards (into spray end of jet) a load of poop comes out (from top) featuring a broken, tiny remnant of soft wire (which was blocking the whole port) Very likely from someone using the ever popular bread tie.
Lesson to be learned...for pilot jets DO NOT buy into the "bread ties work great" BS. Or any other wire that is simply "convenient" and "fits".
Its of great benefit to know the size of the opening involved, using the appropriate size steel guitar string (very rigid) you'll easily clear a pilot with no drama (or "leftovers").
Nope, no pics, you'll have to trust me on this one. A valid learning experience, and the pilot jet just may return to service some day! SAVED!
gordon@customcarbservices.com
Custom Carb Service
www.customcarbservices.com
Old June 1st, 2019, 08:44 AM   #2
Redneck pro tip: Cut the guitar string at a 45 angle for tough clogs but cut at a 90 for 99% of the rest of the job(s).
Old June 1st, 2019, 01:11 PM   #3
ducatiman
ducatiman's Avatar
can be filed to a needle like point as well. be careful, will pass right through a finger or hand.
Custom Carb Service
Old June 2nd, 2019, 09:08 AM   #4
Guitar string’s very strong!
Old June 2nd, 2019, 10:58 AM   #5
ducatiman
ducatiman's Avatar
Absolutely, work really well, knowing your size before going in is imperative. Don't believe I've ever been unable to clear a clogged jet, however damage to the head frequently justifies bitchy removal and replacement. Gorilla unnecessary over tightening is the main offender. Firm but not stupid tight is called for.
Just the other day was forced to drill and e-ze out 2 Mikuni pilots way overtightened (with resultant damaged heads) in Ducati carbset (ebay spares, my property)
Mikuni BDST38 for Ducati uses removable jet holders (pictured, hold pilot, main and starter jets) convenient to service jets.
This removal precipitated the jet cleaning project...and led to this very "bread tie" thread/rant.
Custom Carb Service
Old June 2nd, 2019, 11:15 AM   #6
Is there a torque spec for these jets?
Old June 2nd, 2019, 11:45 AM   #7
ducatiman
ducatiman's Avatar
I've never seen any value....IMHO just use common sense with eventual removal in mind.
Custom Carb Service
Old June 2nd, 2019, 12:21 PM   #8
An understatment. Music wire can get over 400,000 psi tensile strength, but you probably knew that.
Old June 3rd, 2019, 08:41 PM   #9
Wow, never knew the specifics of guitar string, thanks!
Wonder if a super-strong, super-light frame can be made from the stuff...hmmm....
Old June 4th, 2019, 06:22 PM   #10
dcj13
Participant
dcj13's Avatar
Motorcycle(s): '94 K75 std
That works out to about 53 lbs tensile strength, based on wire diameter.
Last futzed with by dcj13; June 4th, 2019 at 07:41 PM. Reason: Clarification...
[motorcyclistonline] - KTM Toaster For Those With Bread To Spare Ninjette Newsbot Motorcycling News 0 October 21st, 2014 09:10 AM
[superbikeplanet.com] - Elbowz Drops Bread Crumbs on Twitter Ninjette Newsbot Motorcycling News 0 July 24th, 2012 07:10 AM
[topix.net] - Bikers join Bread of Life ministry for toy drive Ninjette Newsbot Motorcycling News 0 December 25th, 2011 12:20 AM
for all you bacon lovers... alex.s Off-Topic 3 November 24th, 2011 03:47 PM
Gerbing Heated Gear - Better than sliced bread! g21-30 Motorcycle Gear 1 December 19th, 2009 11:35 AM
