Old May 22nd, 2013, 11:58 AM   #1
az3200
az3200's Avatar
Motorcycle(s): 2002 Ninja 250
What Is This Part On My Bike?
Simple question, should be a simple answer for some of you. It seems obvious it has something to do with the gas since the lines are running to it, but all the pictures i've seen of gas tanks and the left side of bikes don't have this.
All the pictures ive seen have one vent line. I don't know what they do because they're always dry except for the middle one sometimes. That must be the overflow?
And this black box. It's bolted to the engine by a long bolt at the bottom, and a short one on the left. It looks like it was meant to be there but i have never seen other ninja 250s with this.
az3200 is offline   Reply With Quote
Old May 22nd, 2013, 11:59 AM   #2
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
That is useless CA emissions bullcrap!
AFM #676
Supersports are for n00bs
Old May 22nd, 2013, 12:02 PM   #3
az3200
az3200's Avatar
Can you elaborate? What does it do? can I take this off? So this bike originated or was once owned in California? I kinda like the way it looks. It makes the engine look a little fuller in the fairing lol.
Old May 22nd, 2013, 12:56 PM   #4
Jiggles
Jiggles's Avatar
MOTM - Apr '13
Yes you can take it off, there is a DIY in the DIY section under like kleen air system removal or something. If you modify your bikes exhaust/intake then the CA Bullshit system can cause popping on deceleration. I don't remember which is which but one of the those holes you have to plug, another has to vent, and the last one hooks up to the carb or something, idk
AFM #676
Old May 22nd, 2013, 02:03 PM   #5
NevadaWolf
Certified looney toon
NevadaWolf's Avatar
MOTM Jul '13, Jul '14
Not quite, it was built to meet California specific emissions requirements. I've got a CA newgen. Just a few other parts and tubes that make it interesting when following DIYs with bikes from the other 49 states.
<-- Linky
Old May 22nd, 2013, 02:13 PM   #6
lgk
dont remove it.
just ride your bike to CA, and sell for $5k.
then fly back and get another newgen for $2500
Old May 22nd, 2013, 02:17 PM   #7
bruce71198
bruce71198's Avatar
Thats the charcoal canister. The charcoal inside of it absorbes Gasoline and, in some cases, crank case fumes, stores them and then is evacuated by engine "vacuum" and burned up in the combustion chamber when the bike is running. The fumes that are emmitted from venting gas tanks and crank cases is said to elevate ground level ozone, but only in Cali !
How profitable is it to part out a bike? MrAtom General Motorcycling Discussion 13 January 14th, 2015 07:16 PM
Pre Gen Part bike part out A7xschecter6661 Motorcycle-related 28 July 5th, 2012 12:49 PM
Should I buy a bike to part it out? Live2ride Motorcycle-related 27 September 10th, 2011 02:29 PM
08' Ninja 250 Parts bike part out *you name the part and price* BuckyNaked Motorcycle-related 106 July 12th, 2011 02:01 PM
88-07 Bike part out $700 obo Loaded Moses Motorcycle-related 3 August 9th, 2009 02:45 PM
