July 22nd, 2014, 05:36 AM | #1 |
KAWASAKI GURU
Join Date: Jul 2013 Motorcycle(s): Turbo Ninja 250 Posts: 863
Interested in cylinder head studs?
Hey guys, I am speaking with ARP for some cylinder head studs for my project 09 turbo 250 and I found out the 08-12 250r and the 2013+ 300 have the same cylinder head bolts so the studs should be the same but not yet verified but looking to see if any of the 300 guys would be interested in a stud kit for their 300's
If so please let me know here or threw PM. So far they told me it would vary from $140-170 per set. |
July 22nd, 2014, 02:33 PM | #2 | |
modaholic junkie
Join Date: Sep 2012 Motorcycle(s): 2001 ZX-12R, 2009 ninja 345cc and plenty of others in the past... Posts: 438
If noone has tried it before, I will !!! |
July 22nd, 2014, 05:39 PM | #3 |
KAWASAKI GURU
Well depending on what they say I may buy a few sets to keep on the shelf and list them online until they sell out possibly.
July 23rd, 2014, 12:46 AM | #4 |
modaholic junkie
sounds encouraging !! I'll see what it takes to put the new engine together and if my wife doesn't ask me for a divorce (yet), I will contact you for that !!
May 20th, 2015, 09:31 AM | #5 |
KAWASAKI GURU
I thought I would post this info here since I had another member contact me asking about 10mm studs. I found that ARP has a head stud kit for a Honda that is right around the right measurements length wise for the ninja 250/300.
A 8mm stud can only be torqued to 28ft lbs where as a 10mm stud can be torqued to 60ft lbs. You would have to machine the engine block to accept a 10mm stud so you will have to have a machine shop put the cases in a jig, drill and tap. Not ideal for most but it is an option.... busa guys have done this for a while. The ARP part number is 208-4301 That part number is 6.45" long with 10x.125 threads and has 1.3" threads on the block side and 1.0" on the nut side. ARP says we only need a 6.1" stud so these are .35" or 8.9mm longer than whats needed, that extra clearance should not be an issue as the cams are farther away than that or if you are running a spacer to lower compression (turbo applications) it would only be maybe 6.9mm longer than needed. or just whack .3" off the case side lol. Thought I'd share this info with anyone who is looking for ninja 250 head studs or ninja 300 head studs. |
May 20th, 2015, 10:39 AM | #6 |
Join Date: Jul 2010 Motorcycle(s): '08 Ninja 250R Posts: A lot.
MOTM - Oct '15
awesome info and thanks for sharing! I'm missing a large part of understanding here, but why does the block need to be machined? Don't the studs screw into the same threads as the head bolts? Or what am I misunderstanding here?
My therapist has 2 wheels and a seat. If you are ever in doubt to my tone, please refer to my avatar. |
May 20th, 2015, 10:42 AM | #7 | |
KAWASAKI GURU
Also this upgrade is probably only for turbo/nitrous guys maybe someone road racing revving to the moon or higher compression. If you missed my other thread I found out the 13-15 zx6r exhaust valve springs fit and you can get more pressure out of them = higher revs OK |
May 20th, 2015, 12:36 PM | #8 |
MOTM - Oct '15
awesome! Was thinking more for swapping heads a lot for some experimentation - the headbolts being stretch bolts gets expensive quickly...
May 20th, 2015, 12:38 PM | #9 |
KAWASAKI GURU
Not a bad idea, ARP can make a set but it gets costly and youd have to get a bunch of guys in on a group buy to make it worth the while unfortunately.
May 20th, 2015, 12:43 PM | #10 |
MOTM - Oct '15
well shoot, I can drill and tap the crank case... Might have to order a set of these up... Thanks again for the heads up!
May 20th, 2015, 05:01 PM | #11 |
Join Date: Oct 2014 Motorcycle(s): 2014 Ninja 300 Posts: 160
2 bits of information to note.
1. You will have to have cometic make head and base gaskets with 10mm holes or be VERY careful drilling yours out every time. 2. As with out massive 1/2" studs for the Hayabusa, more torque could potentially distort the head, block and case. Just some food for thought. |
May 22nd, 2015, 10:01 AM | #12 | |
KAWASAKI GURU
Very good points mike! Another option to help keep a gasket in place is O-Ring the block! |
May 26th, 2015, 09:11 AM | #13 |
O-ringing works well with a dry block and copper head gasket. If you are still running water, you will find it nearly impossible to seal correctly, as the only part of the gasket that gets good pressure is the ring around the cylinders.
Last futzed with by APEmike; May 26th, 2015 at 09:12 AM. Reason: typo |
May 27th, 2015, 05:16 AM | #14 |
modaholic junkie
APEmike has a strong point there !! in order to seal off liquids you will need a permanite gasket for which you will need to know how much will be "seated" under the pressure you bolt your head on so that both rings seal combustion and the permanite seal the liquids... we use it over here only on certain drag race applications, mostly turbo/nitro cars where cylinder walls are over 10mm of thickness... I tried it on my ZX-12R with muzzy 87mm offset kit and it was a p.i.t.a. to get it working properly....
May 27th, 2015, 06:47 AM | #15 | |
KAWASAKI GURU
May 27th, 2015, 03:09 PM | #16 | |
modaholic junkie
keep in mind it will lower significantly the CR... by about 0,4-0,5...
May 27th, 2015, 07:02 PM | #17 | |
KAWASAKI GURU
Damnit why have you not mentioned this before! Lol.... would be great to lower it a little on the turbo motor |
May 27th, 2015, 08:59 PM | #18 |
MOTM - Oct '15
is that where they get the extra displacement, or is the head taller (what is the opposite of decked?)
May 28th, 2015, 06:01 AM | #19 |
KAWASAKI GURU
No, they have a longer stroke on the crankshaft, they can have the same deck height if they use a shorter connecting rod which is what they did, they also moved the location of the piston pin as well.
May 29th, 2015, 09:09 AM | #20 |
The stroke increase is significant if I remember correctly.... But the blocks are interchangeable. If you want iron sleeves, an easy and cheap process of making a big bore block, or going BIG *relatively* and putting in larger sleeves and +6mm pistons, go with a New Gen 250 block. If you want better cooling, longer piston, ring, and cylinder wall life, go with the 300's aluminum/Nikasil block. The Nikasil block however is more expensive to over bore, not everyone can do it, and cant go as big... Rotating assemblies are interchangeable as long as you use ALL 250 or ALL 300 parts. Also, because of the separate block/upper case it IS possible to use spacer plates to raise the block for stroker cranks and/or lower compression or custom tall deck turbo pistons.
/Random info dump... |
Interested in cylinder head studs? | garth285 | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 5th, 2014 07:53 AM |
Cylinder head photos - Before porting | tubarney | 2008 - 2012 Ninja 250R Tech Talk | 1 | January 25th, 2013 05:29 AM |
Time for a new cylinder head | scottsa | 1986 - 2007 Ninja 250R Tech Talk | 10 | July 6th, 2011 09:29 PM |
WTB: 08+ ninja 250 cylinder head | spicy mayo | Items Wanted | 0 | March 20th, 2011 12:49 PM |
cylinder head cover - gasket | headshrink | 2008 - 2012 Ninja 250R Tech Talk | 7 | March 7th, 2010 04:22 PM |
