Old August 1st, 2013, 04:44 PM   #1
indr
Cable adjustment perch hole stripping
The hole in the clutch perch where the adjustment nut for the clutch cable screws into. The threads inside it are stripped about ¼" of the way down. As the cable stretches, I have less and less room to back off the nut to take up the slack.
Anyone else have this problem? Any solution besides buying a whole new perch?
indr is offline   Reply With Quote
Old August 1st, 2013, 04:47 PM   #2
c-dog
c-dog's Avatar
Motorcycle(s): -
I bet you can get a used perch on ebay pretty cheaply. That's what I would do. Not sure any fix-it would be as safe for you.
c-dog is offline   Reply With Quote
Old August 1st, 2013, 05:18 PM   #3
mgentz
Board Member
Options:
buy a new perch
buy a used perch
buy some thread repair goo
buy a tap and clean up the threads
Old August 1st, 2013, 05:25 PM   #4
There is no effective way to repair that aluminum fine thread; hence, you have less regulation to stretch the cable housing.
Can you use the regulation at the other end of the cable?
If not, you could make a extension for the cable housing from an aluminum cylinder with a longitudinal groove.
http://en.wikipedia.org/wiki/Bowden_cable
Anyone ever used a paint stripping wheel? desrik 1986 - 2007 Ninja 250R Tech Talk 2 March 14th, 2013 12:15 PM
How long before your first chain tension adjustment.. and routine cable lubrication reaubideux 2008 - 2012 Ninja 250R Tech Talk 1 August 12th, 2011 09:54 PM
Fine throttle cable adjustment assembly broken. setasai 2008 - 2012 Ninja 250R Tech Talk 2 June 18th, 2011 09:10 PM
Help. Idle Adjustment Knob cable came off. RyanJames 2008 - 2012 Ninja 250R Tech Talk 3 November 2nd, 2010 11:22 AM
Clutch cable adjustment SteveL 2008 - 2012 Ninja 250R Tech Talk 2 August 17th, 2009 12:39 AM
