Go Back   ninjette.org > Marketplace > Motorcycle-related
Closed Thread
Old October 18th, 2011, 04:39 PM   #1
A7xschecter6661
A7xschecter6661's Avatar
Motorcycle(s): 2003 Yamaha R6
Pre Gen Part bike part out
Hey guys. When we bought my mom's ninja we got a parts bike with it for fairings and stuff.
We are gonna part some of it out, as we don't need anything else.
I am not going to price anything, I would like you to contact me at EDITED with your offer on a particular part and I will agree or disagree on pricing and figure out shipping.
Not looking to make a crap ton of money on this, looking to get it out of the barn and help you guys out.
We are willing to sell the whole bike, it just doesn't have a title.
I do not know much about the bike, the owner said it starts runs for a few seconds and stalls. He said something about a cracked head, I don't know
Bike (1998) had 11k miles, so everything should still work correctly.
Here we go.
Anything pictured is for sale, not only what I list!
Everything from this is available except the bottom cowling (now on moms bike) and the ignition/tail lock
Gas tank, the guy was doing the body work on this, I assume it was dented.
Holds gas.
Front rim/oem junk tire decent tread, forks, rotor, caliper, hose
handlebars- left one is bent, ignition cylinder with key is sold, killswitch,starter assembly, choke/horn assembly.
radiator, fan/motor, coils, carbs, shifter, header
coolant jug, hoses, swing arm, chain, sprockets, chain cover, rear caliper, rear rotor, battery cables, airbox, rearsets including passenger, computer, kickstand
side panels, decent condition, faded from sticker removal, needs a little work and paint.
front fender, crack on the right side that goes around the fork. Repairable with fiberglass, scratches from being removed incorrectly through the front.
Seat, no rips dots are just dust/dirt
lower cowl, needs to be sanded, stickers removed maybe a little body work and repainted, no cracks.
Main fairing piece, cracked in multiple locations. Was on Mom's bike when we bought it originally. Reinforced and everything bolted together properly. With the price of new ones somebody may want this and work on it, but shipping doesn't seem like it will be fun!
Miscellaneous pile of parts, ripped apart fender assembly, ripped apart headlight (mod potential maybe), mirrors-one is missing glass, a few lenses and brackets.
Items that have been sold, updated so you know!
Ignition cylinder with key, including rear tail lock
Last futzed with by A7xschecter6661; November 10th, 2011 at 09:00 PM.
A7xschecter6661 is offline
Old October 18th, 2011, 06:14 PM   #2
CynicalC
CynicalC's Avatar
Motorcycle(s): '96 EX250
Wow that bike has had a rough life. GLWS! Wanna send me the two screws that go through the back of the throttle controls? I lost mine >_<
Ç¥ñ頻| ßÿ Ñâ7µ®é. Äñt¡~§º¢Ïä| ßý Çhøî©è.
CynicalC is offline
Old October 18th, 2011, 06:24 PM   #3
A7xschecter6661
Most of the damage was from being disassembled and thrown around the 2 garages it is in.
I'd prefer not to sell just the screws, but definitely will if it comes to it.
They are listed around $30 on ebay but I can beat that if you want the whole assembly.
If not, take a screw out of the choke side, and head to a hardware store, I am sure they are probably the same
Old October 18th, 2011, 08:28 PM   #4
cerberusrex25
Accesories Guru
cerberusrex25's Avatar
Motorcycle(s): '99 EX250(Cafe/fighter project)
Just like cynical I am in need of a bit of hardware. I need the 4 screws that secure the tank bracket to the frame, the screw that secures the brake lever to the master cylinder, the little screw that secures the brake switch to the master cylinder and the 4 screws that secure the tail plastics onto the frame, and the little choke lever found on the left handle bar. Please let me know if you are willing to part with this items and how much do you want for them, we'll discuss details over PMs.
cerberusrex25 is offline
Old October 26th, 2011, 02:21 PM   #5
Lou
Lou's Avatar
Motorcycle(s): GreenSE 09 250R
How much for the seat???
Lou is offline
Old October 27th, 2011, 08:39 PM   #6
A7xschecter6661
$10+ shipping?
Email me at the address at the top of the first post if you want it
Old October 27th, 2011, 08:48 PM   #7
Jiggles
Jigglin' your Jiglets
Jiggles's Avatar
MOTM - Apr '13
Doh I wanted the seat
AFM #676
Supersports are for n00bs
Jiggles is offline
Old June 10th, 2012, 10:19 PM   #8
A7xschecter6661
Alright guys, I am bumping this UP.
I ripped a lot of the bike apart tonight while I was taking the carbs out to swap to my moms bike to see if I can fix an issue.
That being said, a lot of the parts are already disassembled and in a parts bin.
Contact me VIA Email EDITED if you need certain parts and we can discuss price and shipping
Most of the bike is there but I can't guarantee without confirming!
Front wheel
back wheel
rear rotor
rear master cylinder, reservoir,hose and caliper (I pushed on the piston and the other one blew out and shot brake fluid all over me, awesome!)
ignition coils
relays
main fuse block
engine computer
radiator
hoses
lines
wiring harness
right side clip on, left is bent a little
kickstand
center stand (I will have to make sure this is still worth using)
rear sets
ignition cylinder (comes with seat lock)
gas tank (see first post)
bottom fairing (could be prepped and painted)
side panels (could be prepped and painted)
seat (has white spots on it, might come off but didn't by just washing)
front fender (cracks around fork area, could be reinforced and painted)
header pipe
air box (no filter)
once again, EMAIL ME. I rarely check here
You name it, if I have it, I'll sell it!
Old June 11th, 2012, 07:25 PM   #9
A7xschecter6661
Here guys, a bunch more pictures!!
coils, I have both
main fuse block
horn
kickstand, has some rust
coolant jug and hoses
brake light switch
airbox, no filter
wiring harness
chain guard
rear caliper (needs a rebuild I think), hose, master cylinder and resovoir
tank, needs work on the outside, some rust on the part that forms around the main frame rail, holds gas and doesn't leak at pump or bolt holes.
Last futzed with by A7xschecter6661; July 1st, 2012 at 05:29 PM.
Old June 14th, 2012, 09:03 AM   #10
drdriftking007
Drdriftking007
drdriftking007's Avatar
still have the rear brake bracket? Ill buy
drdriftking007 is offline
Old June 14th, 2012, 10:10 AM   #11
davidw38901
Motorcycle(s): ninja 250r 2005
right handel bar shipped to 38901
davidw38901 is offline
Old June 14th, 2012, 11:19 AM   #12
Snake
Snake's Avatar
Email sent
Snake is offline
Old June 14th, 2012, 07:33 PM   #13
A7xschecter6661
All responded too, remember guys I want this stuff out of the barn.
No reasonable offer refused!
Please remember email is the best way to contact me!
Last futzed with by A7xschecter6661; June 14th, 2012 at 08:43 PM.
Old June 14th, 2012, 08:35 PM   #14
A7xschecter6661
Once I get it down to the frame I will probably be sand blasting it and repainting it and selling it as a title-less frame that you can weld your VIN on to. So that's up for grabs too as well as the motor, rims, header pipe, carbs.
Old June 18th, 2012, 07:33 PM   #15
A7xschecter6661
Keep em coming, everything must go.
Shipped out 3 packages, 1 pending payment
Old June 19th, 2012, 02:44 PM   #16
dirty nasty
Motorcycle(s): 2000 Kwak Ninja 250 and 1998 Yamaha YZ400F
Would you happen to have the front turn signals? Shoot me a PM when you can. Thanks!
dirty nasty is offline
Old June 19th, 2012, 03:51 PM   #17
kraazy
We need 1.21Gigawatts now
kraazy's Avatar
Motorcycle(s): 1Badazz2fiddy,ZRV 500
do have left handle bar
and left peg still
kraazy is offline
Old June 22nd, 2012, 07:45 PM   #18
A7xschecter6661
Keep em coming, I might have the engine sold, not sure yet though
Old June 23rd, 2012, 10:24 AM   #19
PM sent. Forgot to mention the pins that hold the pegs on. I could use those too!
CZroe is offline
Old June 25th, 2012, 02:28 PM   #20
A7xschecter6661
Keep em coming, contact me via email at top of page!
Lots left to part out
Old June 25th, 2012, 03:11 PM   #21
Mocha Man
Blue Shell magnet
Mocha Man's Avatar
Motorcycle(s): 1997 Ninja 250
Did you end up getting the turn signals by any chance?
Mocha Man is offline
Old June 25th, 2012, 05:42 PM   #22
arieon69
Motorcycle(s): 2000 Ninja EX250
handlebars and stuff?
arieon69 is offline
Old June 25th, 2012, 07:21 PM   #23
A7xschecter6661
I don't have front turn signals but I do have rear.
I have right side handlebar, left side appears bent a little
Old June 26th, 2012, 01:44 PM   #24
arieon69
I just need that whole piece.. I guess it's called the tree... on my parts bike its shotty.
arieon69 is offline
Old June 26th, 2012, 07:26 PM   #25
A7xschecter6661
What they connect to? Think it's the triple tree.
I have it, can sell it without the lock cylinder
Old June 26th, 2012, 08:04 PM   #26
arieon69
trying to get it all together but thats ok. does the starter switch and work properly?
arieon69 is offline
Old June 26th, 2012, 08:49 PM   #27
A7xschecter6661
I have no way to test anything as the bike is completely disassembled, the guy we bought it from said the bike does start with a battery. But like I said I have no way to verify sadly
Old July 1st, 2012, 05:29 PM   #28
A7xschecter6661
Keep em coming guys! Might have somebody local interested in the motor
Old July 5th, 2012, 12:49 PM   #29
/closed
OP plans to start another thread
Alex is offline
Closed Thread
New Gen part out RacerX113 Motorcycle-related 11 November 15th, 2014 04:36 PM
FS Ninja 250 Pre-Gen part out AFazakerley Motorcycle-related 13 October 23rd, 2013 01:28 AM
Pre-gen Part-out (pic heavy) AFazakerley Motorcycle-related 1 June 21st, 2013 08:49 PM
FS/ part out new gen and pre gen 250r ninja carlos Motorcycle-related 3 May 14th, 2012 10:25 PM
08' Ninja 250 Parts bike part out *you name the part and price* BuckyNaked Motorcycle-related 106 July 12th, 2011 02:01 PM
