Old August 12th, 2013, 11:43 AM   #1
Scattcatt
Scattcatt's Avatar
Motorcycle(s): 2008 Kawasaki Ninja 250R, 2003 Honda CBR600RR
HID Headlight Flicker
Have an interesting problem that I wanted to run by you all before I decided to yank and replace the relay.
My low beam light runs fine 100% of the time but when I turn on the high beam the high beam will warm up just fine, then when operating temperature has been reached it will begin to flicker, only at idle though. If at any other speed the high beam remains as stable as my low beam.
I've always been plagued by HID troubles with this bike, my last set that came with the bike was stable as far as the high and low beams were concerned by staying on without a problem, unless you ran over a jolting bump. Then both would shut completely off until you cycled the ignition.
My idea list for potential problems in order is as follows:
1) Headlight Relay
2) Voltage Regulator/Rectifier
3) The High Beam's Ballast
4) Any of the rest of the charging system (stator, flywheel etc)
I'll test the ballast sometime by simply swapping ballasts on both headlights. That'll at least knock one of the possibilities off the list easily.
My connections are solid and the battery is new, actually running with a CTZ10S battery instead of stock but I doubt that's causing any problem, all my headlight woes started well before I did the battery conversion.
Dug through some past threads but none really gave me much more of an idea than the car forums I've checked out in the past.
Anyone have any other ideas for this specific issue? Thanks
ATGATT
Scattcatt is offline   Reply With Quote
Old August 12th, 2013, 12:39 PM   #2
Panda
not an actual panda
I vote your not sending enough voltage to the ballast at idle.
I also vote for not really listening to me and waiting for others to chime in.
Old August 12th, 2013, 12:53 PM   #3
gantt
gantt's Avatar
Motorcycle(s): 2019 Ninja 400, Sold 2012 Ninja 650, Sold 2009 Ninja 250r, Sold 2007 DRZ400s
My bet is with the ballast. can you swap ballast from high/low beam?
gantt is offline   Reply With Quote
Old August 12th, 2013, 10:09 PM   #4
Dark
Simple kind of man
Dark's Avatar
Motorcycle(s): 2013 Ninja 300
It takes more juice to ignite the bulb then sustain it.
I would swap the ballasts to see if the problem follows it or not.
Dark is offline   Reply With Quote
Old August 13th, 2013, 05:14 AM   #5
rcruz17
rcruz17's Avatar
Motorcycle(s): 09 250r
Consider running a hid relay harness it's what I do on cars that have these issues.
My for sale thread!!!
rcruz17 is offline   Reply With Quote
Old August 13th, 2013, 05:28 AM   #6
Asspire
Fix It Till Ya Break It
Asspire's Avatar
Motorcycle(s): 08 250RRrrrr
Dont buy cheap ebay hids, its pulling too much current, also your going to cook your voltage regulator
HID headlight conversion. agentbad General Motorcycling Discussion 6 May 21st, 2014 07:13 PM
HID and headlight modulator ai4px General Motorcycling Discussion 1 May 15th, 2012 01:49 PM
HID Headlight Installed 2012NewRider 2008 - 2012 Ninja 250R Farkles 20 March 2nd, 2012 06:50 AM
HID Flicker 25ERic 2008 - 2012 Ninja 250R Tech Talk 6 August 13th, 2009 02:31 PM
