Old February 21st, 2020, 01:37 PM   #1
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Bolt reference
I'm getting ready to get my bike race ready, and I need to safety wire -- since I use anodized titanium bolts I need to get them pre-drilled. Is there any resource that has all the bolts with full measurements since the parts fiche seems to only give partial ones (e.g. BOLT,FLANGED,16X22 while I need something that has all 3 -- M10 x (1.25mm) x 20mm )
"most folks racing this bike get it in a competitive state of being with much less invested than you've already put in Saturn." - Alex
Old February 21st, 2020, 02:01 PM   #2
I haven't had any issues with drilling Ti bolts, they're softer than steel. A cobalt bit works well.
Old February 21st, 2020, 02:16 PM   #3
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
Would still need the measurements whether predrilled or no (sorry should’ve been clearer that I’m converting this from a stock bike not existing titanium)
Old February 23rd, 2020, 07:44 AM   #4
AwDang
https://www.probolt-usa.com/vaf/prod...el=297&Year=19
Don’t get tunnel vision on Ti, AL works as well or better in some places.
Old February 23rd, 2020, 08:54 AM   #5
Depends upon the bolt. Nothing structural should be Al, since it’s only 1/3rd strength of steel. Most weight-savings come from replacing biggest bolts first with Ti, about 6-8 lbs savings. Smaller non-critical bolts replaced with Al will save 1-2 lbs.
Titanium wheel axles and nuts, swingarm pivot bolt & nut, shock-mounting and linkage bolts & nuts, engine-mounting bolts & nuts,brake-caliper and rotor mount bolts, sprocket studs & nuts, triple-T clamp bolts, mirror bolts, fairing stay bolts, rearset bolts, passenger peg bolts, muffler mounting bolt, shifter rod, etc.
Aluminium = fairing bolts, tank bolts, battery-tray bolts, dog-bones, thermostat-housing bolts, water-pump bolts, sprocket cover bolts,
Last futzed with by DannoXYZ; February 23rd, 2020 at 10:21 AM.
Old February 23rd, 2020, 09:15 AM   #6
Ah... hmm, I've never found any listings of actual bolt sizes. I’ve had to measure whenever I replaced anything.
Old February 23rd, 2020, 01:17 PM   #7
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
It's not tunnel vision, I've used Aluminum plenty -- and I've used probolts website plenty. It's incomplete. For example, they have front brake available but the rear brake (regardless of material) in only available in a dome head. Since I need to safety wire both brakes, this makes it not an option for me since I'd rather not chew through bits if I can avoid it.
Old February 23rd, 2020, 02:01 PM   #8
AwDang
I’d just call them to order you oddities you can’t find in the catalog. They’ll match up a generic race spec bolt for you.
Old February 23rd, 2020, 04:10 PM   #9
Some alternate sources of Ti.
https://store.mettec.com/category/238
https://racetechtitanium.com
http://www.torontocycles.com/Selling...cle_Bolts.html (favourable exchange-rate)
https://www.titaniumjoe.com/index.cfm/products/bolt/
Old February 24th, 2020, 10:29 AM   #10
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
I still need the measurements though :P When you get the "Ninja 300 bolt kit" it doesn't tell you what it contains and the part fiche isn't complete either.
Old February 24th, 2020, 05:34 PM   #11
Which bolts are you looking for in particular?
Old February 24th, 2020, 11:25 PM   #12
Yakaru
The Violet Vixen
Yakaru's Avatar
MOTM - Jun '16
https://omrra.com/wp-content/uploads...ring-Guide.pdf
From this the ones that I believe i need are:
- Exhaust mount (already have these from @kbryant )
- Front Brake (looks like ProBolt has this kitted)
- Pinch Bolt et al on front forks
- Rear Brake
- Oil Drain Plug
- Water Pump
Old February 27th, 2020, 06:18 AM   #13
tfkrocks
tfkrocks's Avatar
MOTM - Jan '18, Sep '13
I'm pretty sure everything on the ninja is coarse pitch and not fine pitch, which is why they don't bother to give the pitch measurement. That should be enough to go off of given the bolt size. Given the choice of two different pitch numbers for the same size bolt, the smaller one is coarse pitch.
My Ninja 300
On vision, focus, and reference points Sirref Riding Skills 37 September 25th, 2016 10:07 PM
Safety wiring -- reference photos for noobs adouglas Ninjettes At Speed 3 March 22nd, 2014 03:26 PM
Oil Filter Cross Reference engineer151515 1986 - 2007 Ninja 250R Tech Talk 1 September 3rd, 2011 11:19 AM
A handy reference guide LuxMundi Off-Topic 3 August 30th, 2010 07:39 PM
EBC Brake Reference g21-30 2008 - 2012 Ninja 250R Tech Talk 0 November 25th, 2009 09:45 AM
