January 9th, 2016, 12:36 PM | #1 |
Join Date: Jan 2016 Motorcycle(s): 83 harley fxr, 2011 ninja 250r Posts: 10
Having some issues
January 9th, 2016, 12:39 PM | #2 |
Join Date: May 2009 Motorcycle(s): 2016 Kawasaki Vulcan 900 Custom / 2017 Kawasaki Ninja 300 Posts: 133
Looks like it may be the rear brake switch.
January 9th, 2016, 12:50 PM | #3 |
I believe your right
January 9th, 2016, 12:54 PM | #4 |
n00bie to wannabie
Join Date: Sep 2015 Motorcycle(s): 2012 250R (Red), 2005 VFR800A (Red), CRF450X (Red), 2012 F800GS (Wants to be Red!) Posts: A lot.
MOTM - Nov '15
First picture is the rear brake switch. Post a picture of your right footpeg. Specifically; we want to see if your footpeg is stock or if a "rearset" has been installed without the necessary design to hook up the switch. If it's not possible to connect then you must be sure to use your front brake so you will light up your brake light!
Second picture is the connector for your right front turn signal. And welcome to the forum and performance motorcycling!
The Smart Money: #1 - ATGATT, #2 - Training (machine skills and survival skills), #3 - The bike; whatever floats yer boat with the money you have left over |
January 9th, 2016, 01:00 PM | #5 |
January 9th, 2016, 01:11 PM | #6 |
n00bie to wannabie
MOTM - Nov '15
January 9th, 2016, 01:27 PM | #7 |
January 9th, 2016, 01:38 PM | #8 |
Drain it and have a look at what comes out, but that doesn't look good.
January 9th, 2016, 01:42 PM | #9 |
n00bie to wannabie
MOTM - Nov '15
Looks like you're taking on a hella project for your first sportbike!
Lots of info and help here though. If your at all capable of swinging a home mechanic wrench; it's a great bike to cut your teeth on. I do question the coolant tank: are you sure it's a 2011 bike? That is not a stock tank style judging by the tank bolt. And it looks like it's had a pretty hard life. Perhaps you have a Frankeinbike made up of whatever can be haywired on! Post a couple other pictures of the whole bike, shock, dash etc. It will help us when trying to figure out replies for you. Sorry; just reread and see it's not your first time wrenching.
January 9th, 2016, 01:47 PM | #10 |
No worries. It is my first sport bike, but I did rebuild my shovelhead harley fxr Last winter.
It's kind of Janky for sure, previous owner painted everything and did an extremely crappy job of it. Unsure of year for sure, any vin decoder available? I'll grab some more pics of the dash etc |
January 9th, 2016, 01:52 PM | #11 |
January 9th, 2016, 02:17 PM | #12 |
January 9th, 2016, 02:48 PM | #13 |
Cool! Gas in oil is an easier fix than coolant in oil.
January 9th, 2016, 02:51 PM | #14 |
VERY true lol. The petcock may have been left on previously, don't know how long it's been sitting. Still going to check the carbs. Also going to grab a manual for it, any suggestions? Clymer was garbage for my harley, is it any better for the ninja?
January 9th, 2016, 02:56 PM | #15 |
Your google fu will serve you well here. The ninja 250r service manual is easily found online in pdf form.
January 9th, 2016, 05:35 PM | #16 |
Fast-Guy wannabe
MOTM - Jan '13
Yup I keep a copy on my phone in PDF form for easy access.
January 9th, 2016, 08:17 PM | #17 | |
It could be leak from the pump, from head gasket or condensation due to long storage. Check the coolant for signs of oil and don't start the engine with that mix; rather flush it with oil a couple of times before a definitive oil/filter change.
January 9th, 2016, 11:06 PM | #18 |
Motorcycle Nurse?
Join Date: Sep 2013 Motorcycle(s): 2010 250R, 1998 Ducati 748L #77/100 Posts: 606
Year in the VIN is noted by the 10th digit, here is a chart that decodes.
January 10th, 2016, 01:11 AM | #19 |
Certified looney toon
MOTM Jul '13, Jul '14
Here's a comparison shot of my 2012. Please ignore the muck, haven't bothered cleaning in awhile.
January 10th, 2016, 01:43 AM | #20 |
Join Date: May 2013 Motorcycle(s): '75 CB550:.'82 XV920:.'00 KLR650:.'00 EX250:.'08 Ninja 250 Posts: A lot.
MOTM - June '15
It's definitely water, hopefully some jack hole left the cap off, and it's not anything that needs a tear down!
'82 XV920: Soon to be tracker--'00 KLR685:adv --'04 DRZ400E--'12 Super Tenere --'13 Versys Ride more, worry less. |
January 10th, 2016, 08:20 AM | #21 |
2011? Sheesh - what the heck did the PO do to that thing?
The initial signs are not good, but hopefully you'll find something simple causing the coolant in the oil. Best of luck bringing it back to life. This section may be helpful - http://faq.ninja250.org/wiki/Ninja250_Howto |
January 10th, 2016, 09:35 AM | #22 |
n00bie to wannabie
MOTM - Nov '15
This is what ethanol gas and not changing your oil in the fall will do to your engine!!!
January 10th, 2016, 11:35 AM | #23 |
January 10th, 2016, 12:18 PM | #24 |
n00bie to wannabie
MOTM - Nov '15
January 10th, 2016, 01:06 PM | #25 |
January 10th, 2016, 02:12 PM | #26 |
MOTM - June '15
And riding in the rain. I remember that one time my bike got wet, it looks just like this!
January 10th, 2016, 08:19 PM | #27 |
Join Date: Nov 2015 Motorcycle(s): 2009 Ninja 250 Posts: 386
holy crap who would paint the exhaust? If you want a stock one let me know, I don't need mine.
January 11th, 2016, 06:02 AM | #28 |
Okay, so Ive drained the oil. Airbox and filter have been gone for a while, po rode it like that for a bit, I've got a new one coming. Got a bunch of parts coming to put it back right. Will update when parts come in
January 11th, 2016, 06:05 AM | #29 | |
Bike has been sitting outside with no airbox or filter, po rode it a few miles like that as well. Got a lot of new parts coming in this week, going to try to chase the issue when I get a new battery and oil filters |
January 11th, 2016, 06:41 AM | #30 | |
A trip of few miles with that emulsion could have partially damaged the main bearings of the connecting rods. If damaged happened, you could have seen some tiny flakes of bronze in the drained lubricant. I hope the engine is still good to serve well.
January 11th, 2016, 08:13 AM | #31 | |
He's messed-up everything you can possibly mess-up! |
January 11th, 2016, 08:20 AM | #32 | |
As for bronze shavings in the oil, I didn't notice any, but doesn't mean they aren't there. I noticed the oil pressure sensor wire is pulled apart, along with headlight clips. I love it when people don't take care of things |
January 11th, 2016, 10:30 AM | #33 |
Join Date: Apr 2011 Motorcycle(s): 2015 636 ABS - 69 Honda 305 Posts: A lot.
Not that this helps any, but that's not a 2011. Its 08-10, the 11's and up had white face gauges. Unless it was just the SE's, but I think it was all models. Either way, that's the least of your worries, good luck!
Current - 2015 30th Anniversary Ninja 636 ABS - 1969 Honda 305 Scrambler Previously - 2011 Ninja 1000, 2008 Ducati 848, 2011 Ninja 250 SE |
February 6th, 2016, 12:58 PM | #34 | |
Join Date: Oct 2015 Motorcycle(s): Ninja 250R, 2010 Posts: 20
OK - here in Denmark, I have a 17-digit VIN-#, and if I select digit 12 (A), I get 2010 model from above list. And how do I know it's a 2010 ? Well - greeen with a "seat beam" in black should only have been issued in 2010 ;o) It seems that US and Continental VIN's are different ? |
March 1st, 2016, 08:20 AM | #35 |
Yes - it looks like Europe has a slightly different setup. I tried to download the ISO standard for it, but it wasn't free.
Several issues | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 21 | June 12th, 2013 10:16 AM |
Some issues | The_big_dill | 1986 - 2007 Ninja 250R Tech Talk | 12 | May 21st, 2013 04:59 AM |
Still Having Issues! | Achilles | 2008 - 2012 Ninja 250R Tech Talk | 11 | March 3rd, 2013 10:26 AM |
Helmet issues? | Apex | General Motorcycling Discussion | 11 | June 22nd, 2010 01:08 PM |
I was having issues... | Apex | General Motorcycling Discussion | 24 | February 6th, 2010 05:21 PM |
