Old August 7th, 2012, 03:19 PM   #1
fredhsu
Motorcycle(s): Ninja 250r 2012
Valve Adjustment
So this is a noob question but why do people get their valves adjusted ?
Rah
fredhsu is offline   Reply With Quote
Old August 7th, 2012, 03:28 PM   #2
Whiskey
So that they open & close at the right tolerances, too far open & they could get a bang of the piston, destroying them & probably the whole engine. too tight & they don't allow air (or exhaust) to flow properly, suffocating the engine.
Fazer thou intake valves after a bang of the piston...
Old August 7th, 2012, 03:32 PM   #3
fredhsu
i dont get why people would adjust though? cant i just leave it as stock?
Rah
Old August 7th, 2012, 03:37 PM   #4
Whiskey
They move up & down constantly, given time they'll go out of spec.
The valve adjustment is a case of check & if they're out adjust them back into spec.
Old August 7th, 2012, 03:41 PM   #5
Skid
troll bait
Motorcycle(s): 2006 Ninja 250EF
Don't worry. Your 2012 ninja won't need an adjustment for a long while...unless you're pushing 8k on the odometer already.
Skid is offline   Reply With Quote
Old August 7th, 2012, 03:44 PM   #6
red5
red5's Avatar
Motorcycle(s): 09 ninja 15.256
Everything does remain stock. The only thing that changes is the shim if the clearance is out of spec.
Over time, as the valve seat wears, the clearance between the valve and the lobe tightens up. If it gets too tight, thermal expansion can cause the valve to remain open slightly and the valve and the seat will be burned. Then it's time for a new head.
"We're not always doing business, but we're always open."
"For me, it is far better to grasp the Universe as it really is than to persist in delusion, however satisfying and reassuring." Carl Sagan
red5 is offline   Reply With Quote
Old August 7th, 2012, 03:56 PM   #7
fredhsu
got it! thanks guys
Rah
Old August 7th, 2012, 03:57 PM   #8
fredhsu
not even close...15xx
Rah
Valve Adjustment quarterliter 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2013 05:32 PM
Valve adjustment ?s Jewtoys 2008 - 2012 Ninja 250R Tech Talk 5 August 1st, 2012 08:47 PM
valve adjustment little fish 1986 - 2007 Ninja 250R Tech Talk 8 November 4th, 2011 10:10 AM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
anyone want to help with a valve adjustment? diablo250 Group Rides and Local Events 2 March 28th, 2010 02:00 AM
