Old February 19th, 2013, 03:12 PM   #1
blink
Always.
blink's Avatar
Motorcycle(s): '08 Ninja 250, '05 GSX-R600
Valve adjustment
Yes it's on a gsxr 600, yes I tried their forum; they are assholes and no help at all lol.
So i come here, because i enjoy this site.
Yes I googled it, i don't have an owners manual.
Google doesn't provide me with input, only answers.
My bike has roughly 38k, i emailed the previous owner, don't believe she was original owner, however she said something about her dad owning it, anyways.
She said she never did anything with the valves.
***Question:
My question is, should I just get it done? Or try to get her to find out if she knows if her father did it?
2) Should i just get the valve adjustment? Or as the shop called it "The complete package" with oil, filter, and what ever else that may include?
P.S I bought it at abouuuut 32k
blink-182
Last futzed with by blink; February 19th, 2013 at 03:13 PM. Reason: Added a post script
blink is offline   Reply With Quote
Old February 19th, 2013, 03:27 PM   #2
"the complete package" means "we're going to rape you out the ass with our COMPLETE PACKAGE (including the sack!) and charge everything we can"
do the work yourself.
Old February 19th, 2013, 03:29 PM   #3
TonyKZ1
TonyKZ1's Avatar
Motorcycle(s): 1975 Kawasaki KZ400D (Sold), 1989 Kawasaki Ninja 250 (sold), 1997 Yamaha XJ600s Seca II
Well, you could always just buy the workshop service manual or the haynes, etc. manual and do it yourself. Otherwise, not sure what the dealership would charge to do a valve check/adjustment. Most likely it's valves are adjusted via shims. And being a 4 valve per cylinder and 4 cylinder, it could be expensive. As for it ever having been done, doubtful - most likely not, and if you check it yourself or have a good dealership do it you'll know it's been done and won't have to worry about it anymore. Would you rather keep riding it, not knowing whether it was done or not, and then mess up the engine or head because it needed the valves adjusted and then you're going to out a bunch of money to fix the engine...
Tony
1997 Yamaha Seca II - mostly stock, Racetech upgraded forks, FZ6R rear shock, Oxford Heated Grips, Barkbusters Blizzard Handguards, a Scottoiler vSystem chain oiler. My Mileage Tracker Page.
TonyKZ1 is offline   Reply With Quote
Old February 19th, 2013, 03:29 PM   #4
blink
Always.
blink's Avatar
LOL thank you.
So paying 350$ for them to do it vs a noob who never has is also a bad idea?
Complete package was 800ish
ONLY V.A was 350ish
blink-182
Old February 19th, 2013, 03:52 PM   #5
krolinked
Nerd
krolinked's Avatar
Originally Posted by blink View Post
LOL thank you.
ONLY V.A was 350ish
Ask them whats included in the "complete Package" then see if you can do all of those things yourself, and maybe just have them do the valves only if your uncomfortable doing them yourself right now.
Old February 19th, 2013, 03:54 PM   #6
at an honest shop, valve adjust should cost around $150. (labor only, no parts outside of exchanging shims -- if they can do valve adjusts, they have a large stockpile of shims already. shims cost at most $10 for a set) oil change with the valve adjust should cost about $35 for the cost of oil and filter. no labor charge since its done at the same time as the valve adjust, it is only one extra bolt. coolant flush should be included in the valve adjust as they need to remove the cooling system to get to the valves. full brake service (pads and fluid) should be about 80$ including parts. most mechanics will lube and properly tension your cables as a complimentary service. it shouldn't cost more than $10 if they're cockbags and wont just do it for free.
Old February 19th, 2013, 04:28 PM   #7
lgk
http://www.fixyomoto.com/suzuki-gsxr...ervice-manual/
i'm not sure which gsxr you got, but for a K4 its on page 24, or 2-7
Old February 21st, 2013, 01:41 PM   #8
blink
Always.
blink's Avatar
Thanks guys!
That manual link was also very useful! Much appreciated.
I will do brake pads myself; it is good practice and isn't too complicated.
blink-182
Valve Adjustment quarterliter 1986 - 2007 Ninja 250R Tech Talk 7 June 25th, 2013 05:32 PM
Valve adjustment ?s Jewtoys 2008 - 2012 Ninja 250R Tech Talk 5 August 1st, 2012 08:47 PM
valve adjustment little fish 1986 - 2007 Ninja 250R Tech Talk 8 November 4th, 2011 10:10 AM
Valve Adjustment-Really Tight adjustment screw? mikesova 1986 - 2007 Ninja 250R Tech Talk 5 May 2nd, 2010 04:57 AM
anyone want to help with a valve adjustment? diablo250 Group Rides and Local Events 2 March 28th, 2010 02:00 AM
