Old May 21st, 2021, 02:54 AM   #1
xx_sevendayz
Motorcycle(s): EX250J
NINJA 400 rims on NINJA 250R?
as the title said: have anyone tried to put on stock 2018+ Ninja 400 rims to 2008-2012 Ninja 250R?
I am looking for replacement set for my bike and its kinda hard to find it in new condition. I know it will need new front brake rotors but other than that can I use other old parts (bushings, sprockets, etc.) to mount it?
If this is a hassle-free plug and play solution then it would be a great option.
xx_sevendayz is offline   Reply With Quote
Old May 31st, 2021, 08:15 AM   #2
InvisiBill
EX500 full of EX250 parts
InvisiBill's Avatar
I don't think it will be an easy swap. I believe the rotor mounting pattern changed, and the rotor is a different size too. Neither the 250 rotor or the 400 rotor would work with both the wheel and the caliper/mount, so you'd have to do some modding and/or get custom parts.
I think the 300 wheels are a closer fit, possibly even a direct swap. However, the 300 switched to an electronic speedo, so the 250's cable-driven speedo wouldn't work with it.
The NewGen 250 and Gen2 500 wheels are almost identical for mounting. I actually put aftermarket 250 wheels on my 500, with only a few little OEM spacers and such needing to be swapped. The 500 wheels' appearance is a bit dated (since they're from the mid-'90s), but they should be functional, and the look would be unique if nothing else. https://www.ex-500.com/threads/40125/ is the post on the 500 forum, which has more details about fitting the 250 wheels to the 500. If you want to go that route, that thread should give you an idea what 500 parts you'd need to swap along with the wheels themselves.
Old June 2nd, 2021, 01:27 PM   #3
MauR
MauR's Avatar
Motorcycle(s): 250R
I can confirm that 300 rear wheel is a direct fit and you can use 150 tire.
The front will fit but you will have to deal with a not working speedo and use a 300 rotor
MauR is offline   Reply With Quote
Ninja 250r Rims 08+ WesleySnipes Items Wanted 0 April 17th, 2013 05:19 PM
