Old April 2nd, 2013, 11:24 PM   #1
swede core
Valve rocker arm replacement
I was doing a valve adjustment and tightening the locknut on an intake valve rocker arm, and it flew out of its socket and chipped . It is a ball and socket joint and I have a seized ninja 250 engine as well as a older engine I received. I can take the rocker arm from the seized engine, if it is removable.
How would I perform the replacement? What do I need to remove and get to and if there is any know instructionals on this that would be great!
swede core is offline   Reply With Quote
Old April 3rd, 2013, 05:16 AM   #2
n4mwd
n4mwd's Avatar
Good thing you caught it before you put it back together. Overtorquing the rocker arms during a valve adjustment will destroy the engine if you run it like that. The max torque on the nuts is about 15#.
But to answer the question, you have to remove the cams - actually, just loosen them - to get to the rockers. So basically:
1) removed the cam chain tensioner,
2) remove the cam caps - leaving the sprocket still connected.
3) reach in and remove and replace the rocker.
4) put the cam caps back on.
5) Verify cam timing (it can slip a tooth while you are working on it) and then fix the cam timing according to the manual.
6) Verify the cam chain tensioner lever isn't stuck and work it free.
7) oil and reinstall the cam chain tensioner.
That should do it for you.
My Ninja Blog
Old April 3rd, 2013, 05:19 AM   #3
n4mwd
n4mwd's Avatar
Oh, and one other thing. You need to inspect ALL of your rockers to make sure they aren't also broken. If any have broken dog ears, then they will work out and destroy the engine.
Doesn't look that threatening, but it is.
My Ninja Blog
Old April 3rd, 2013, 05:22 AM   #4
n4mwd
n4mwd's Avatar
Oh, and invest in a $10 torque wrench at harbor freight. Otherwise, you'll be stripping the cam caps as well.
My Ninja Blog
Old April 3rd, 2013, 05:58 AM   #5
Welcome to the site, Kyle !!!
Old April 3rd, 2013, 07:31 AM   #6
swede core
Yea I need to go an get a torque wrench :/
Whats the trick to removing and reinserting the rocker arms? Do you just pull them off and push them back in?
Thanks a lot for the feedback!
Old April 3rd, 2013, 07:38 AM   #7
n4mwd
n4mwd's Avatar
pretty much. You just have to make sure they're sitting in there socket properly. Other than that it's the cams that actually hold them in.
My Ninja Blog
Old April 3rd, 2013, 07:39 PM   #8
swede core
Any idea the torque spec on the cam caps?
Despite all of the headaches i've encounter with this engine swap/rebuild... I'm having fun! I sure wanna hop back on the bike soon though.
Old April 3rd, 2013, 08:23 PM   #9
n4mwd
n4mwd's Avatar
Rocker arm nuts = 12#
Cam caps = 9#
They are very easy to strip.
My Ninja Blog
Rocker arm mod JAG 2008 - 2012 Ninja 250R Tech Talk 4 August 25th, 2013 08:36 PM
Broke a damn rocker arm during valve adjustment. SV_Hadder 1986 - 2007 Ninja 250R Tech Talk 7 April 3rd, 2013 03:00 PM
Missing Rocker arm and valve adjust screw/nut Ragnar1x 1986 - 2007 Ninja 250R Tech Talk 45 May 22nd, 2011 09:28 AM
[roadracingworld.com] - Crutchlow Undergoes Successful Arm Pump Surgery On Right Arm Ninjette Newsbot Motorcycling News 0 April 8th, 2011 09:30 AM
WTB-rocker arm yelve Items Wanted 5 April 6th, 2011 05:26 PM
