Go Back   ninjette.org > General > Pictures
Old March 12th, 2019, 01:59 PM   #1
alexhart
Motorcycle(s): 2007 Ninja 250R
Talking My First Ninja 250 & Street Fighter Conversion
Hello Ninjette.org! This is my first post. I just bought my first motorcycle which was an 07 Ninja 250! I am pumped to become an active member.
*Pictures Below*
I picked this thing up for $900 from a guy off Facebook. It runs (has some rattling but hey it runs).
The guy had done the bug eye headlights and called it a "Street Fighter" conversion but I thought it could use some more touches. I bought a classic 7" headlight for it and then, like a rookie, DROPPED IT AND BROKE THE HEADLIGHT after I had pulled out the wiring for the bug eyes so now that I had to put them back on, they don't work so that's fun. It was a plastic China knockoff so no foul.
Let me know what you guys think or if you have any suggestions on after market parts?! I am also going to need to figure out the idle problem. I have to keep adjusting the idle because it wants to sit at like 4,000rpm and if I go lower it sometimes just putters and die. Maybe a carb issue?
Here are some side by side pictures of when I bought it and after I was done doing my street fighter look conversion.
What I did:
-Cut front fender to take some weight off it and painted
-Cut fairings for naked frame look and painted
-Wheels painted
-New Taillight w/ integrated turn signals
*Ordering new headlight so that's coming.
BEFORE
AFTER
alexhart is offline   Reply With Quote
Old March 12th, 2019, 03:56 PM   #2
Ceeloo Yello
Motorcycle(s): 250
Yes bug eyes are ugly and you could do better on the fender eliminator but other than that you seem to have a solid plan.
Old March 12th, 2019, 03:58 PM   #3
Ceeloo Yello
Motorcycle(s): 250
I always thought that maybe a ruckus type dual headlight setup would look pretty good.
Old March 12th, 2019, 05:07 PM   #4
alexhart
Yeah, I need to get some metal loop extensions so I can fit the license plate right under the light and then I can chop off all that extra hanging metal underneath and make it a little tighter!
Old March 13th, 2019, 06:15 AM   #5
dodgerdad
dodgerdad's Avatar
Welcome! I bought a 2007 with the same idea as you
I'd recommend painting the rear exhaust hanger/bracket and maybe the rearsets as well.
As for the idle problem, if the bike sat for a while there's a good chance the idle circuit is clogged up so you'll likely benefit from a good carb cleaning.
Looks good so far. Stay motivated and keep on posting pics of your progress.
Old March 14th, 2019, 10:58 AM   #6
CaliGrrl
CaliGrrl's Avatar
Motorcycle(s): Ninja650
Welcome!
Old March 15th, 2019, 08:11 AM   #7
Cafe Racer
Motorcycle(s): Harley Fatboy, Honda CX500, Harley XL1200C Sportster, 305 Honda Dream, Ninja 250
Ditch the front tire and fender and up the size to a 120. Looks much better.
Cafe Racer is offline   Reply With Quote
My 05 250 street fighter build ieathonda 1986 - 2007 Ninja 250R Farkles 19 April 5th, 2016 01:09 PM
Street fighter ninja 250 $1500 CHEAP & CLEAN + BOLT ONS ieathonda Motorcycle-related 3 May 29th, 2015 07:22 AM
08 250 fighter miles<4k-1500$ & Vstar650- $2500 Klondike1020 Motorcycle-related 19 August 20th, 2013 03:17 PM
