December 3rd, 2014, 08:40 AM | #1 |
Join Date: Oct 2011 Motorcycle(s): 2004 Ninja 250F Posts: 308
Removing Rear Shock Spring?
Hi guys! This might be a dumb question, but is it possible to separate the spring from the damper on the rear shock? I'd like to pull out the spring to paint, but I don't want to disassemble my rear suspension if it's not possible.
December 3rd, 2014, 04:58 PM | #2 |
Join Date: Apr 2014 Motorcycle(s): 1978 Z1R, 1999 EX250 Posts: A lot.
MOTY - 2018, MOTM - Oct '16
You bet, but you'll need a spring compressor. Take the shock off the bike, compress the spring with the compressor, loosen the lock nut that locks the clevis to the shock rod then take the clevis off, loosen the spring compressor and whal-a it's off.
December 3rd, 2014, 06:48 PM | #3 | |
Please see: http://faq.ninja250.org/wiki/Rear_suspension_upgrades
Motofool .................................Never ride faster than your guardian angel can fly "Mankind is composed of two sorts of men — those who love and create, and those who hate and destroy. Love is the bond between men, the way to teach and the center of the world." - José Martí Last futzed with by Motofool; December 6th, 2014 at 02:56 PM. |
December 3rd, 2014, 07:56 PM | #4 |
December 3rd, 2014, 09:11 PM | #5 |
The Ninja 300 shock works great on our old bikes.
December 3rd, 2014, 09:17 PM | #6 |
Very true, I just preferred the options of changing the shock oil, and adjustable air suspension so to speak that the ZX600 shock offered.
I put 15wt synthetic and adjustable air is a nice touch when riding 2 up sometimes. On my EX500 I resprung the OEM shock with one from PRO SPRING, 500lbs spring very nice, easy and inexpensive modification.
December 4th, 2014, 05:58 AM | #7 | |
December 4th, 2014, 07:09 AM | #8 | |
Personally if you want to paint the spring, I would work some cloth inside the spring, and paint away.
December 4th, 2014, 06:05 PM | #9 |
Participant
Join Date: Oct 2012 Motorcycle(s): '94 K75 std Posts: Too much.
I don't think I've ever looked ay my pre-gen rear shock spring...
December 4th, 2014, 06:20 PM | #10 |
December 4th, 2014, 09:19 PM | #11 |
How did you do it?
December 5th, 2014, 05:25 AM | #12 |
December 5th, 2014, 07:58 PM | #13 |
Sorry, I got lost there.
December 6th, 2014, 08:40 AM | #14 |
December 6th, 2014, 08:50 AM | #15 | |
I don't know what "the lock nut that locks the clevis to the shock rod" is. Could you post some pictures of those?
December 6th, 2014, 10:37 AM | #16 |
December 6th, 2014, 11:50 AM | #17 |
Thanks!
I believe that my whole shock absorber was welded; but I have been wrong many times before. It is great that it can be disassembled, so a dust boot can be added to protect the shaft.
December 6th, 2014, 02:26 PM | #18 |
pics of removing clevis, jam nut is under the rubber bottoming cushion. Jam nut is 17mm. My "spring compressor" is a big bearing puller.
December 6th, 2014, 02:54 PM | #19 | |
Thank you very much, Roger; I stand corrected. Have you done it just for painting the spring, or for servicing the hydraulic absorber as well?
December 6th, 2014, 03:15 PM | #20 |
I did it so I could put a 1/2" to 3/4 inch spacer under the spring to preload it and get the sag with rider closer to where I wanted it, which raised the rear, the shock it's self is a sealed unit I believe. (but I didn't really look)
December 6th, 2014, 04:08 PM | #21 |
Again, thanks.
December 8th, 2014, 01:44 AM | #22 |
Thank you! That's really helpful. I ordered a spare shock from eBay to play with - hopefully it'll be here later this week and I can give this a shot. I'll report back with results!
December 29th, 2014, 03:11 PM | #23 |
EX500 full of EX250 parts
I just wanted to confirm what Ghostt said. The PreGen's spring is heavier than the one that comes on the 500, so I swapped it. I used a homemade spring compressor consisting of a couple ratchet straps (Redneck Engineering - Do Not Try This At Home!). Once you compress the spring, you just loosen the locknut and clevis from the shaft, then the spring will fall right off.
The 500's preload adjuster lets you release all tension from the spring, so you don't need a spring compressor. Here is the process for swapping the spring on the 500's shock, which should be about the same other than needing a spring compressor rather than just loosening the preload adjuster. Also note that the PreGen's top spring perch is held on the shock body with a circlip. I haven't tried it with the spring still installed, but you may be able to simply pop the circlip off once the spring is compressed. That would allow the perch to move up and relieve the spring pressure, which would then give you easy access to the nut at the bottom. The NewGen/300 shock has a notched lower plate that just slides in and out once you relieve the spring pressure.
Pregen rear spring shock alternatives | greenaero | 1986 - 2007 Ninja 250R Tech Talk | 41 | March 4th, 2016 08:53 AM |
Removing the vacuum spring from the petcock. | berserk81 | General Motorcycling Discussion | 5 | November 5th, 2013 08:07 PM |
What Rear Shock/Spring will work - EX300? | accident-prone | 2013 - 2017 Ninja 300 General Discussion | 90 | March 26th, 2013 06:38 PM |
Replacing my rear shock with a newgen rear shock... | ReDnEcK | 2008 - 2012 Ninja 250R Tech Talk | 4 | September 10th, 2010 12:38 PM |
