April 30th, 2019, 09:16 PM | #1 |
Join Date: Sep 2018 Motorcycle(s): 2007 Ninja 250R Posts: 8
Low idle then dies - mixture too rich?
I'm at a loss for what to do next on this bike. 2007 ninja 250, about 5000 miles
For backstory: the starter was making some terrible grinding, turns out it was missing the rollers in the starter clutch and the starter clutch gear was missing a tooth, which I replaced. At the same time taking off the carbs to clean and to address fuel overflowing. Got it all back together, fresh fluids, and the starter was working great but the carb was leaking gas again, pouring it into the cylinders so much it was dripping out the exhaust out the back and through the overflow tube. Took it back off, cleaned a little more and checked the float valves. Okay, reinstalled, and replaced spark plugs for good measure. At first it idled normally for a couple minutes, then nothing. After that I could only seem to get it to idle at about 800rpm with the throttle fully open, very low and rough idle. If I turn the fuel petcock to off it does its low and rough idle until just before it runs out of gas then it would rev right up. Alternatively I could get it to idle like that with no throttle and the choke almost fully on. Does anyone have any idea of what could be the issue here? Air filter is new, plugs new, drained the gas tank and added some seafoam too. I'm just at a loss with it at this point. Just want to ride. |
April 30th, 2019, 09:18 PM | #2 |
With the leaking fuel and running faster when you shut off the petcock it seems to be that your carburetor float valves are not shutting off the fuel when the level in the bowl rises. It's dumping fuel into the engine and flooding it. Then the idling with the enrichers on and no throttle points to clogged pilot jets or passages. I'd say your carbs need a real and thorough cleaning.
Sea Foam is not much more than snake oil. If anything is going to help it would probably be something with PEA in it like Techron. But with your sever symptoms I doubt if even that would substitute for a true cleaning. |
what is the best idle screw mixture | vmax | 2008 - 2012 Ninja 250R Tech Talk | 9 | July 1st, 2017 10:45 AM |
Question about idle mixture screw and low idle flux | daverdfw | 2008 - 2012 Ninja 250R Tech Talk | 3 | June 2nd, 2016 10:36 PM |
adjusting idle mixture screws | james250ninja | 1986 - 2007 Ninja 250R Tech Talk | 9 | September 1st, 2014 10:29 AM |
Idle Mixture Screw Problem | gogoKawi | 2008 - 2012 Ninja 250R Tech Talk | 6 | April 23rd, 2013 07:07 PM |
Idle Mixture ?'s | nebraskan | 2008 - 2012 Ninja 250R Tech Talk | 31 | April 13th, 2011 08:41 PM |
