Old May 4th, 2019, 10:24 AM   #1
07pansy
Motorcycle(s): 07 ninja 250
Swap 250-650
So I keep reading it’s not worth it or doesn’t fit to swap an 07 250 to any other motor. How come an 07 650r motor won’t fit. It’s only a 2cyl
07pansy is offline   Reply With Quote
Old May 4th, 2019, 12:32 PM   #2
Who says it won't fit? That's what they said about 300 & 500 swaps as well and plenty of people have done those.
All you need is:
- donor motor
- floor-jack to lift engine up into position
- ruler
- measure connection points for engine-mount
- cut & weld as necessary for engine-mounts
- install engine
- install 650R harness and all electronics
- voila! Done!!!
BTW, 650R engine weighs something like 145-lbs. You'd end up with bike with wet-weight in 450-lbs range, or about same as 650R.
Old May 6th, 2019, 07:00 AM   #3
sharky nrk
Fighting Texas Aggie '05
sharky nrk's Avatar
the 650R engine is a relatively poor candidate because of the layout for the airbox and FI layout - the 500 at least shares the intake and exhaust layout with the 250/300
Swingarm swap from 300 to 250? Kurgan 2008 - 2012 Ninja 250R Tech Talk 17 August 27th, 2019 07:27 AM
2010 250 Engine Swap Duneger 2008 - 2012 Ninja 250R Tech Talk 3 May 6th, 2018 04:58 PM
ninja 250 engine swap tellmewhy! General Motorcycling Discussion 11 May 25th, 2016 06:38 AM
250@300 cc swap Shinigami 2008 - 2012 Ninja 250R Tech Talk 21 May 27th, 2015 12:23 PM
500 or 650 motor swap??? 09xxxr 2008 - 2012 Ninja 250R Tech Talk 16 March 26th, 2012 09:02 AM
