April 4th, 2010, 06:36 AM | #1 |
Join Date: Oct 2009 Motorcycle(s): Red 08 250r Posts: 218
Steering damper
April 4th, 2010, 06:50 AM | #2 |
Join Date: Nov 2008 Motorcycle(s): Ninja 250R 2009 Posts: A lot.
That's cheap for an Ohlins! I wonder what the S&H is to the states.
Never mind, I found S&H = $50.14 for 2.1 Kgs, so $210.15 delivered! |
April 4th, 2010, 06:56 AM | #3 |
that is cheap
April 4th, 2010, 07:23 AM | #4 |
Check out the front fender:
kkim is going to want one of these! |
April 4th, 2010, 07:27 AM | #5 |
And different handle bar options:
April 4th, 2010, 07:41 AM | #6 |
wow I like that
April 4th, 2010, 07:43 AM | #7 |
HEC,
You found this site. Check all the items out. I like this one: |
April 4th, 2010, 08:00 AM | #8 |
I like this one which looks like front suspension adjusters. Not realy sure I will have to check it out more closely. Great find!!!
005-k0005.jpg oops sry and thanks. The bottom pic. |
April 4th, 2010, 11:00 AM | #9 | |
Join Date: Dec 2008 Motorcycle(s): 08 Ninja 250R Candy Plasma Blue Posts: 129
April 4th, 2010, 11:37 AM | #10 |
The Sportisi Master
Join Date: May 2009 Motorcycle(s): 2008 Ninja 250 Posts: A lot.
yup you are correct. you can have the same setup for about $40 if you do it yourself.
Sportisimoto USA is born. |
April 4th, 2010, 12:11 PM | #11 |
Ya I see that now
steering damper | Frogger | 2008 - 2012 Ninja 250R Tech Talk | 6 | September 8th, 2013 09:11 PM |
Steering Damper Bracket | FvnnyL3tt3r1ng | 1986 - 2007 Ninja 250R Tech Talk | 26 | September 6th, 2013 06:05 PM |
Steering Damper | ator | 2008 - 2012 Ninja 250R Tech Talk | 44 | April 29th, 2013 12:20 AM |
Inexpensive Steering Damper | TheJimmyEnglish | 2008 - 2012 Ninja 250R Tech Talk | 25 | August 11th, 2011 11:31 AM |
