October 20th, 2014, 07:58 AM | #6201 |
I have the Yoshimura exhaust hanger for the J-bike but it doesn't have that hold for mounting the reservoir. They should both for both bikes!
October 20th, 2014, 09:37 AM | #6202 |
Finally unloaded it from the trailer yesterday. lol Needs a bath and various new bolts & bits.
October 20th, 2014, 09:08 PM | #6203 |
put a new windshield on it and some swingarm spools!
Midwest Instiute Massage Therapy Certification |
October 23rd, 2014, 08:14 PM | #6204 |
Certified looney toon
MOTM Jul '13, Jul '14
Changed to a 42T rear sprocket and got me some decent (hopefully) running shoes!
October 25th, 2014, 04:58 PM | #6205 |
Join Date: Jan 2014 Motorcycle(s): 2007 ninja 250 Posts: 80
Spark plugs and a bit of a wipe down. I park on dirt that's been getting looser every time I even think about using the throttle on it, so I'm growing to accept that dirty look/vibe.
October 26th, 2014, 08:45 AM | #6206 |
MOTM - Sep '14
K&N air filter installed.
Kerry said no ecu map change needed.
Keep calm and ride on -Motofool Never quit on a rainy day -ally99 |
October 26th, 2014, 08:48 AM | #6207 |
MOTM - Sep '14
What are you initial thoughts on the running shoes?
October 26th, 2014, 11:08 AM | #6208 |
Love them! After 1100 miles yesterday, they show almost no sign of being ridden at all (solid interstate yesterday and the DRIIs previously had begun to square off under similar conditions). Also I rode through heavy rains and intense winds and they stayed glued to the road regardless.
I feel very confident on these. So glad of all the reviews showing them to be solid tires.
October 27th, 2014, 07:14 AM | #6209 |
Turtle Dancer
Join Date: Oct 2014 Motorcycle(s): 2014 Ninja 300 SE Posts: 83
Got out the trusty Honda cleaner, cleaned all fairings and various parts and scubbed the seat clean. Put air in the tires. She was getting dusty from all the dead leaves.
October 29th, 2014, 09:03 AM | #6210 |
MOTM - Sep '14
Took it off the road until I get the chain tightened. More likely it will need replaced which means a couple of weeks stuck in the barn.
October 29th, 2014, 10:08 PM | #6211 |
MOTM - Jan '18, Sep '13
This arrived today: http://admorelighting.com/store/inde...product_id=176
I was ready to install it right after opening the package but found that they only sent me one led strip so now I have to wait
My Ninja 300 |
October 29th, 2014, 10:46 PM | #6212 |
Aimed my new garage security camera at it.
October 30th, 2014, 09:28 AM | #6213 |
MOTM - Sep '14
Tighten the chain and loosed up the tight spot that I think caused the extra slake. I do have a new chain and sprockets on the way, but I do not think I need to swap it out just jet. I am over 20,000 miles so soon
Should I change the sprockets when I change the chain even if they look OK?
October 30th, 2014, 09:35 AM | #6214 |
Certified Troublemaker
Join Date: Oct 2012 Motorcycle(s): 2006 Ninja 250r "Pikachu", 2017 Ninja 650 "Epona" Posts: A lot.
I always heard you change them together so they wear down the same or don't prematurely wear the new chain...
Raven's Rejuvenation A bruise is a lesson... and each lesson makes us better... |
October 30th, 2014, 09:48 AM | #6215 |
MOTM - Sep '14
I have read folks say every other time.
October 30th, 2014, 10:10 AM | #6216 |
I've always heard every time as well and that's what I go by. Chains are expensive.
My Ninja 300 |
October 30th, 2014, 03:39 PM | #6217 |
Almost died on it. Hit one of those things while changing lanes on the freeway in such a way that it sent me into the gnarliest wobble. The whole time I just kept thinking, man, I wish I had the power to drive out of this but I was already doing 80ish so I had almost zero left over torque. Sort of just rode it out, slammed my weight on the pegs a bit, tried to loosen up, but it definitely caught me off guard. Bit of a wake up call to brush up on my emergency techniques.
October 30th, 2014, 03:44 PM | #6218 | |
October 30th, 2014, 03:48 PM | #6219 |
Nope, found a place selling some for $10-$20! If you are brave that is....
November 4th, 2014, 03:36 AM | #6220 |
Installed the admore lighting LED kit in my Givi topcase. Works as running lights, brake lights, and turn signals. The brake light will also flash 3 times. Super easy install.
Video to come whenever youtube wants to stop being a piece of ****. ETA: Youtube refuses to process my video ETA2: Finally worked. I posted it in my thread https://www.ninjette.org/forums/show...&postcount=227
My Ninja 300 |
November 4th, 2014, 06:39 PM | #6221 |
Join Date: Oct 2014 Motorcycle(s): 2007 BMW F800s, Former 2011 Ninja 250r Posts: 117
Routine pre-ride safety check found burnt out left rear turn signal bulb. MSF BRC really drilled the need to do that, glad I did.
November 5th, 2014, 06:28 AM | #6222 |
Installed some new saddle bags. Loving the extra cargo space and no backpack.
November 7th, 2014, 06:04 PM | #6223 |
Track Clown
MOTM - Sep '15
Drained the radiator, now need to pick up some coolant before the freeze sunday night.
November 8th, 2014, 08:23 PM | #6224 |
4 out of 4 members found this post helpful. |
November 12th, 2014, 12:19 AM | #6225 |
twisties with a 300
I got a little overzealous with the pictures |
November 12th, 2014, 04:16 PM | #6226 |
Had my helmet and gloves stolen off my bike while I was at work. I guess My seat latch didin't lock down all the way and the thief made off with my gear. It was a cold, sniffly, and not so loud ride home. Lucky for me I had one ear plug. The luck. Going to lube up the chain since it's all dry and gritty from all the rainy excursions.
November 12th, 2014, 05:26 PM | #6227 |
Man, that sucks! What the f is wrong with people.
November 13th, 2014, 07:25 AM | #6228 |
Track Clown
MOTM - Sep '15
added more coolant to the radiator, its been <10* all week.
November 13th, 2014, 10:06 AM | #6229 |
Hooligan
Join Date: Jun 2013 Motorcycle(s): 2013 Ninja EX300 Posts: 250
That is beyond impressive!
I'm trying not to think about the fact that mine is sitting outside with less than a half tank of gas and no Seafoam in the tank. I really should have filled up when I finished riding on Monday and made space for it in the garage.
Qui patiens est, teres. Teres est, ieiunare. | Twitter: @Rogue_300 |
November 13th, 2014, 10:22 AM | #6230 |
MOTM - Sep '14
What is the temp there now? 250* kelvin
November 13th, 2014, 12:12 PM | #6231 |
Hooligan
We have warmed up to a balmy 25* F, which sadly, is about 10* warmer than yesterday.
November 13th, 2014, 07:44 PM | #6232 |
Oil change. I need to rejet back to stock.
November 13th, 2014, 10:44 PM | #6234 |
Track Clown
MOTM - Sep '15
we broke the kelvin scale here...
November 14th, 2014, 10:26 AM | #6235 |
You rode in that? At least it wasn't sticking to the roads. Not by me anyway.
Not that it was a blizzard or anything but hell no, not for me.
November 14th, 2014, 05:17 PM | #6236 |
got the front fairing primed and ready to go for the last of the blue paint! I'm so excited!!
November 16th, 2014, 07:27 PM | #6237 |
Unloaded it from the trailer to the garage, a sad day indeed. She will lie in wait until next season.
November 17th, 2014, 06:30 PM | #6238 | |
November 17th, 2014, 10:46 PM | #6239 | |
Good news. Found the thief today. He posted on craigslist and on Facebook trying to sell my stolen gear. Cops have been notified and the guy will be in for a rude awakening when he loses his job and I make his life a living hell. I love my moto friends!
November 18th, 2014, 06:56 AM | #6240 | |
Discovered something scary about my Ninjette today... | kjohng | General Motorcycling Discussion | 28 | October 15th, 2021 01:40 PM |
Sold the 2006 Ninjette today :( | Renner | General Motorcycling Discussion | 31 | October 16th, 2014 11:46 PM |
Today I Gave My Ninjette Wings! | BlueHairSar | Pictures | 5 | June 20th, 2013 07:38 AM |
my bro went down today on his ninjette | richierich781 | !%@*#$%!)@#&!%@ I crashed! | 46 | January 18th, 2013 11:59 AM |
Ninjette. org hacked today | CC Cowboy | Off-Topic | 9 | April 3rd, 2011 08:55 AM |
