August 9th, 2014, 06:18 PM | #1 |
Join Date: Mar 2014 Motorcycle(s): 04 ninja 250, 2010 klx 250sf, 86 gsxr 750 Posts: 21
How to identify cams?
Bought a set SUPPOSEDLY from an 86, but the seller wasn't all that sure, they also came with some tiny but feelable nicks on one of the lobes, anyways is there an easy way to determine exactly what group of years it came off of? (86/7 88-92 92+ right?) as best I could measure with a digital caliper the lobes go from about 26mm to 30.5, not knowing the rocker ratio I'm not sure how to tell the lift or anything really.
August 17th, 2014, 01:26 PM | #2 |
Free bump.
August 17th, 2014, 05:50 PM | #3 |
Hard to say as I do not know much of the earlier years but you could always look on ebay at pictures of cams and compare the part number and build code on the cams.
August 19th, 2014, 01:06 AM | #4 |
Phoenix Salvage
Join Date: May 2014 Motorcycle(s): 2007 Ninja 250R Posts: 71
Surprisingly little info on the subject, but I at least found something:
cam duration specs as per ninja250.org: 86-92: 280' duration 93+ 272' duration. If you can measure the duration, you may have a clue as to the year range. earlier cams supposedly have better top end, later cams better low-mid. Hopefully that helps a tiny bit?
See my current inventory of used parts for sale here |
Help Identify hose. | BoBO | 2008 - 2012 Ninja 250R Tech Talk | 2 | July 27th, 2014 06:06 PM |
How to identify a country song | adouglas | Off-Topic | 10 | January 13th, 2014 05:59 PM |
Help identify this substance? | iplante | 1986 - 2007 Ninja 250R Tech Talk | 11 | October 12th, 2012 01:56 PM |
Help identify this connector | Maielstrom | Off-Topic | 3 | June 29th, 2012 05:17 PM |
Identify Leak | Cuongism | 2008 - 2012 Ninja 250R Tech Talk | 35 | May 11th, 2011 12:44 PM |
