#1 |
Join Date: Sep 2011 Motorcycle(s): 2011 Ninja 250R SE Posts: 78
Pulsating brakes?
This just happened to my front brakes 3 days ago. I thought it might have been low on fluids but thats fine. It feels like the brakes bite then let go and bite again. You can feel it pulsating on the levers as well. Any ideas?
#2 |
Join Date: Mar 2013 Motorcycle(s): 2009 Ninja 250 Posts: 43
Warped rotor? Seems unlikely on a 2011 though
#3 |
Join Date: Mar 2013 Motorcycle(s): 2005 Ninja 250 Posts: 64
Probably not a problem for you in San Diego but up here in Canada pulsing brakes is usually from rust build up on the disc's. If it sits outside and it's a rainy or damp night the rust seems to form around the brake pads and over time will eat its way into the disc causing pulsation as the pad passes the spots. Have a close look for rust marks. If you don't see any ask whoever you live with what they dropped on your bike.
#4 |
Join Date: Mar 2013 Motorcycle(s): 08 cbr1000rr, 2008 + 2012 ninja 250, 06 zx6r (636!) track only Posts: 150
I'm with a bent or deformed rotor as well
You don't have a spongy feeling lever correct so no fluid loss or air in the lines? You could check the pads as well, they are cheaper than a new rotor
http://www.1000rr.net/forums/showthread.php?t=90412 http://www.8thcivic.com/forums/ http://www.facebook.com/profile.php?id=1209877267 |
#5 |
Check the pads.
Need new brakes! | corksil | 2008 - 2012 Ninja 250R Tech Talk | 18 | September 28th, 2014 11:36 PM |
[kropotkin thinks...] - 2014 Silverstone MotoGP Race Result: Pulsating Head-To-Head C | Ninjette Newsbot | Motorcycling News | 0 | August 31st, 2014 06:31 AM |
Brakes | momoru | 1986 - 2007 Ninja 250R Tech Talk | 7 | August 10th, 2014 07:26 AM |
Better brakes?? | LittleRedNinjette | 2013 - 2017 Ninja 300 Tech Talk | 39 | July 11th, 2014 08:42 AM |
Pulsating headlight | CC Cowboy | General Motorcycling Discussion | 27 | September 26th, 2012 10:39 PM |
