April 3rd, 2010, 06:02 AM | #1 |
Join Date: Sep 2009 Motorcycle(s): 09 Ninja 250R SE Posts: 376
Battery Lead Access?
Simple Question: How do you get to the the battery leads?
I'm going on an overseas trip in a couple of months (2 weeks long), so I bought a "Battery Tender Junior". In order to prepare ahead of time I'd like to learn how to actually access the battery leads but I have no clue. Do you only remove the seat? Some fairings? I haven't seen a DIY on this yet, but maybe I missed it. Thanks! |
April 3rd, 2010, 06:34 AM | #2 |
Join Date: Feb 2010 Motorcycle(s): '94 Vulcan 1500, '06 Katana 600, '08 FZ1 Posts: 133
Yes, seat comes up but you don't need to connect to the battery terminals themselves, although that is the easiest. I detest extra wires hanging off the battery terminals, especially since I pull my battery for winter storage. There's the main fuse just under the back of the tank (seat has to come up and the rear tank bracket might have to be lifted) and if you pull back on the rubber cover on the connector going into the main fuse you'll find an empty spot in the connector that will allow a 1/4" female spade to be inserted. This is after the 30A main fuse so the jack would technically be fused for protection although you'd probably want smaller (10A?) fuse for your needs which comes inline with the new jack I believe. You can ground to 1 of the 4 tank bracket bolts and run the jack under the easily removable tail seat for access. Also you shouldn't need a battery tender if it's going to sit for only a few weeks, if the battery dies that fast you need a new battery!
April 3rd, 2010, 12:41 PM | #3 |
Here's what I did for a battery tender lead that can also be used for heated clothing:
http://www.ninjette.org/forums/showthread.php?t=3
April 3rd, 2010, 02:04 PM | #4 |
Thanks guys. My friend who owns a Ninja 1000 and is very hands-on, came over today to help me out. We got the seat out, which was surprisingly easy. He put the leads on the battery and routed it through to the passenger seat in the back. So that way there are no wires hanging out, but there is very easy access to the wire if I'm going on a trip and want to keep it charged.
Cheers! |
FS: Battery Tender 022-0165-DL-WH 12-Volt 2-Bank Battery Management System (Automotiv | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
FS: Battery Tender 800 Waterproof 12V Battery Charger (Automotive) tagged "motorcycle | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
FS: Battery Tender 021-0128 Battery Tender Plus 12V Battery Charger (Automotive) tagg | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
FS: Battery Tender 021-0123 Battery Tender Junior 12V Battery Charger (Automotive) ta | Amazon Postbot | Amazon - Popular Motorcycling Items | 0 | April 23rd, 2013 04:52 PM |
