Old July 26th, 2013, 01:11 AM   #1
passive101
Motorcycle(s): 2009 Ninja 250
low beam or high beam brighter? only choose one
I'm running 1 65W bulb which only give me enough on a 10A fuse to run 1 65W bulb and 1 55W. Would you rather have your low bream or high bream significantly brighter?
Right now I have the 65W in the low beam so I can always take advantage of more light, but I'm curious what others would decide if you had to choose one over the other.
passive101 is offline   Reply With Quote
Old July 26th, 2013, 01:30 AM   #2
Snake
Snake's Avatar
I would choose a brighter low beam as long as it was not so bright that it blinded oncoming traffic.
Old July 26th, 2013, 04:03 AM   #3
As long as you plan to use a Halogen bulb, I'd go with the low beam. You use it most often. Plus, as pointed out in the thread above, that reflector is designed to distribute light in a wide and low pattern. As long as you use a halogen, the light pattern won't change and you'll be just fine.
Old July 26th, 2013, 06:27 AM   #4
passive101
I noticed no change to the light pattern with these bulbs. They are actually H9's designed to fit an H7, so 700 more lumens and a bulb that lasts as long as a regular bulb, no 1/4 life bulbs
Low Beam Good, High Beam dead FvnnyL3tt3r1ng 1986 - 2007 Ninja 250R Tech Talk 4 February 21st, 2013 03:44 PM
make high beam into low beam? DaMan22 2008 - 2012 Ninja 250R Farkles 2 July 12th, 2012 06:34 PM
HID Low and High Beam Pudge Ate Me 2008 - 2012 Ninja 250R Farkles 7 November 29th, 2011 09:52 AM
