Old October 20th, 2009, 04:43 PM   #1
headshrink
headshrink's Avatar
Does Preg-gen Carb. fit New-gen?
What I really want are the slides, but would either the slides or the whole thing work?
Old October 20th, 2009, 05:22 PM   #2
g21-30
g21-30's Avatar
Why not use '08?
http://cgi.ebay.com/ebaymotors/2008-...Q5fAccessories
Old October 20th, 2009, 05:27 PM   #3
headshrink
headshrink's Avatar
I was hoping to get a better deal.
Old October 20th, 2009, 06:35 PM   #4
what's wrong with the carbs that are in your bike? why do you need a complete second set?
Old October 20th, 2009, 08:22 PM   #5
headshrink
headshrink's Avatar
The carb itself is fine, but I have a tear around the lip of one of my slide diaphragms. Since these things are so dang expensive, I was hoping to scavenge parts for cheaper off an old ebay carb.
As you know, a new diaphragm is ~ $100, and carbs on ebay seem to be going for ~$150-175. That doesn't seem like enough savings right now to justify buying the whole thing (used), especially since I only need one right now. Ideally though, if I could get an old carb for cheap (under $100), assuming the slides fit and where in good condition, well that is what I am hoping for. That is why I was asking if the pre-gen carbs work.... or the slides...
Old October 21st, 2009, 04:29 AM   #6
g21-30
g21-30's Avatar
If the carbs are the same model (keihin sp?), should work. You should go to Kawi website and check the major part number-model for the carb of both years, say 08 and 06. Good Luck
Old October 21st, 2009, 04:53 AM   #7
g21-30
g21-30's Avatar
OK, I did the hard work for you. The vacuum diaphragm is the same in '09 and '06 .... part number 16126-1198
Old October 21st, 2009, 05:00 AM   #8
g21-30
g21-30's Avatar
11 hrs left on these: http://cgi.ebay.com/ebaymotors/Kawas...Q5fAccessories
Another ... Buy it Now $90: http://cgi.ebay.com/ebaymotors/Kawas...Q5fAccessories
Old October 21st, 2009, 05:11 AM   #9
g21-30
g21-30's Avatar
Based on my limited research, I don't know whether or not the pre-gen carb will fit the new-gen; however, the part you need is the same. For $90, you can get 2 of them.
Old October 21st, 2009, 09:52 AM   #10
headshrink
headshrink's Avatar
Cool. thanks for the research!
You are right about the part being the same, but it looks like the complete carb assemblies are a different part number. So, assuming slides are in good condition, it could still be a good buy. I'll be watching it, and possibly bid as the final hour nears.... but too bad business is so slow right now.
Old October 21st, 2009, 10:37 AM   #11
g21-30
g21-30's Avatar
You could always try the inner tube patch technique! It worked for VeX, I think.
Old October 21st, 2009, 11:07 AM   #12
headshrink
headshrink's Avatar
Yes, I say that... The tare on mine is around the lip (the cover was tightened down while it stuck out), so I don't think I could do it based on the placement of the tare. Too bad it wasn't easier to get thinner sheets of rubber for those that have a tare in an "ideal" place.
Old October 21st, 2009, 01:08 PM   #13
g21-30
g21-30's Avatar
Seriously, you might try a bicycle inner tube. I would get something like a 700X20. Trim a half moon circular piece big enough to overlap the tear (like a washer) and stick it to the original with tire glue. Let it dry and tighten it down. What do you have to lose?
Old October 21st, 2009, 01:12 PM   #14
g21-30
g21-30's Avatar
FWIW, pre-gen and post-gen carbs are the same models (with different Kawi part #s), so they would probably work on either bike. You would need to swap the appropriate exterior components, such as the choke connector, etc.
Old October 21st, 2009, 01:50 PM   #15
headshrink
headshrink's Avatar
Now I didn't think of that "rubber washer" idea.... thanks, that I can actually see potentially working in this case, being that it should seal evenly around the rim that way.
Thanks for the carb info too, that is good info.
So who from around here am I bidding against (a couple zero feedback bidders are going for it)?
Old October 21st, 2009, 02:01 PM   #16
g21-30
g21-30's Avatar
If you're willing to eventually pay $90 for the "Buy it Now" carbs, you should bid $90 on the other set and forget about it. You will get an email whether you win or lose!
Old October 21st, 2009, 09:39 PM   #17
headshrink
headshrink's Avatar
Got it for $46 and change after tax and shipping!
Old October 21st, 2009, 10:32 PM   #18
LazinCajun
LazinCajun's Avatar
Motorcycle(s): 2008 Ninja 250 (Blue!)
Nice!
LazinCajun is offline   Reply With Quote
Old October 22nd, 2009, 12:09 AM   #19
Glad your plan worked. I always hate when I end up bringing bidders against myself for whatever reason (I hope that isn't the case here), but rest assured that it wasn't me.
Old October 22nd, 2009, 03:30 AM   #20
g21-30
g21-30's Avatar
Another satisfied customer! Glad to be of service.
Old October 29th, 2009, 05:01 PM   #21
g21-30
g21-30's Avatar
Any update? Inquiring minds want to know!
Old October 29th, 2009, 05:41 PM   #22
headshrink
headshrink's Avatar
Yes, I received the carb a couple of days ago, and was finally able to take a look at it last night. It is old, but should work fine. I haven't pulled the slides out yet for a looksie, but they go up and down the way they are supposed to.
Old October 29th, 2009, 06:05 PM   #23
HKr1
IC2(SW)
HKr1's Avatar
When you get them slides out, measure the lift holes. Iam interested in knowing how they compare to the new gen. DJ mentioned drilling them out with a 7/64 bit.
Old October 29th, 2009, 07:47 PM   #24
headshrink
headshrink's Avatar
I'll take a look.... I have never heard this before, and assumed it was the same.
Old October 30th, 2009, 07:36 PM   #25
headshrink
headshrink's Avatar
I just pulled the cap off one of the '95 carbs, and discovered the needle is different. Does anyone know if this is the stock needle for that year, or could this be from a jet kit (pictured below)? The seller is a dismantler, so I doubt he would know.
HKr1: I forgot when I replied to your last post, that the slides have the same part number as the new-gen. I'll measure anyways for good measure (no pun intended).
Old October 30th, 2009, 07:41 PM   #26
if it were an aftermarket needle, it would have clip positions and a clip on it for adjustability.
that's one grungy looking needle.
Old October 30th, 2009, 07:51 PM   #27
headshrink
headshrink's Avatar
Good point, I didn't think of that.
Old October 31st, 2009, 05:00 AM   #28
g21-30
g21-30's Avatar
OEM needle, just compare the top (head) to your original.
Old October 31st, 2009, 11:04 AM   #29
HKr1
IC2(SW)
HKr1's Avatar
The two places I shop had the slide pic with the same number, but had differnt main p/n's. Since you mentioned this, I went and looked at some other web sites. They had same pic #'s and p/n's on both gen years.
I wonder why DJ found the slides needed to be drilled out on older models, but not needed on the new gen.
Old October 31st, 2009, 09:28 PM   #30
headshrink
headshrink's Avatar
The holes measure exactly the same (3/32 & 5/32) between the replacement and original slides. I drilled the replacement with a #70 bit to match the originals mod prior to installing it... perfect fit. I also added a 3rd washer under each needle. The difference was amazing.... it was like when I first shimmed, only better. Now it JUMPS off the line with almost no throttle The idle is a little more stable too.
I am not positive, but I think the tear may have still been sealed due to its location. The replacement and original slides are pictured below.
And a close-up of the torn diaphragm.
Preg gen Oldskool Cafe Racer Rassie 1986 - 2007 Ninja 250R Farkles 33 January 23rd, 2020 11:46 AM
pre gen carb subxero Motorcycle-related 6 March 25th, 2015 06:25 PM
Do fork legs from old gen fit new gen? scorch 2008 - 2012 Ninja 250R Tech Talk 8 May 9th, 2014 08:37 AM
new gen mirrors fit on pre gen? juanpak87 1986 - 2007 Ninja 250R Farkles 2 September 9th, 2013 01:53 PM
New vs pre gen carb spacing. Sipper' 1986 - 2007 Ninja 250R Tech Talk 9 December 20th, 2012 05:27 PM
