Old March 4th, 2012, 07:44 PM   #1
2012NewRider
Motorcycle(s): 2012 Kawasaki Ninja 250R
At home Fender Removal
A little time and creativity led to me removing the stock fender and creating my own tail.
I used a dremel to remove the tail then I bought some brackets to mount my plate but was unable to mount it in the location originally planned. the OEM plate bracket hit the turn signal mounts so I had to move it back.
I also do not have a license plate light at the moment. I'm going to order some license plate bolts with the built in L.E.D's.
Before the tail removal
After the tail was removed and L.E.D turn signals installed
2012NewRider is offline   Reply With Quote
Old March 4th, 2012, 07:50 PM   #2
ForceofWill
Blind 250 Loving Whore
ForceofWill's Avatar
Looks better, but for the love of god, move your base stickers
Old March 4th, 2012, 08:22 PM   #3
2012NewRider
I would but thats the only place big enough where it will fit plus, when I ride my leg covers it up.
Old March 4th, 2012, 10:16 PM   #4
leed
leed's Avatar
Motorcycle(s): Time will tell
Could you... Curl it around the side/top of your chain guard or on the swingarm all together?
Bike looks good though! You did a really good job cleaning up that tail end!
Old March 4th, 2012, 10:21 PM   #5
saxnbass
saxnbass's Avatar
Motorcycle(s): 2009 CBR600rr
That tail job looks nice, details?
saxnbass is offline   Reply With Quote
Old March 5th, 2012, 12:14 PM   #6
whomikedao
Motorcycle(s): Kawasaki Ninja 250r
Can you take closer pictures of your current license plate install? I wanna see how you did them so I can do them too!
whomikedao is offline   Reply With Quote
Old March 5th, 2012, 01:17 PM   #7
2012NewRider
I'll have to try and take some tonight.
Old March 6th, 2012, 10:18 AM   #8
2012NewRider
Wink
These are the close up pictures
I'll try and explain as much as I can.
I used a dremel to cut off the section of the tail that I didn't want to keep. I did keep the metal brackets that the turn signals mount onto and the hooks for a cargo net.
I tried to use the dremel as much as possible but there are some parts that I couldn't reach so I used sandpaper. After I removed the unwanted pieces I sprayed the plastics and metal bracket with gloss black to try and match the shine of the bike.
I saved the license plate mounting bracket to use afterwards. I had to buy some brackets and mounting hardware from Lowest (because they give a military discount).
I then aligned the holes on the brackets with the plastic undertail to drill the holes. After I set-up the OEM license plate mounting bracket and the L bracket, i also painted those in gloss black.
Unfortunately for me I did a test fit without the turn signal mounts attached so I had to flip the brackets and now my plate is farther back than I had planned.
I will still be doing some minor touch ups like: add my license plate bolt lights because I was not able to re-use the OEM light, I will also be drilling another hole on the right side for the right turn signal because I don't like the wire hanging, I might also get a longer L bracket to move my license plate farther back so it looks more like a professional install.
Old March 9th, 2012, 09:25 PM   #9
whomikedao
Thanks a lot! It looks really well done
Old March 9th, 2012, 10:17 PM   #10
Kstorm21
Kstorm21's Avatar
Motorcycle(s): 2009 Ninja 250R SE
Couldn't you put it on the black part right above the Ninja decal? That's were everyone puts them around here.
Kstorm21 is offline   Reply With Quote
Old March 9th, 2012, 10:25 PM   #11
2012NewRider
I would but it didn't fit unless I rolled it inward since its a smaller bike it also has a smaller area right there. I'll try to figure out a different place when my decals expire in December.
Old March 9th, 2012, 10:45 PM   #12
Kstorm21
Kstorm21's Avatar
The other place is on the front forks. Doesn't really matter I guess...just weird ya gotta spread your legs to show your stickers.
Old March 9th, 2012, 11:09 PM   #13
2012NewRider
It's even weirder when its a guy that has to check my sticker
Old March 10th, 2012, 06:42 PM   #14
2012NewRider
New LED License plate bolts and moving my license Plate farther back.
Old March 10th, 2012, 06:51 PM   #15
Snake
Snake's Avatar
Great job, looks very good.
Old March 10th, 2012, 07:20 PM   #16
2012NewRider
Thanks
For all you with home made fender eliminators... KawiKid860 Videos 12 October 20th, 2014 04:19 AM
Front Fender - Metal Bracket Removal Rollin.. 2008 - 2012 Ninja 250R Tech Talk 4 August 14th, 2013 06:35 AM
Airbox removal + Kleen air removal? MikeBudd 2008 - 2012 Ninja 250R Tech Talk 6 February 16th, 2012 04:57 PM
Front Fender Removal Poyter 2008 - 2012 Ninja 250R Tech Talk 3 October 20th, 2010 10:41 PM
home made fender chop ninjablk08 Pictures 10 May 22nd, 2009 06:18 AM
