Old July 11th, 2015, 02:04 PM   #1
Bob Marshall
Crankshaft rotational direction
Is the crankshaft rotational direction clockwise or counterclockwise on a 2008 ex250? Thanks
Bob Marshall is offline   Reply With Quote
Old July 11th, 2015, 02:22 PM   #2
Brother Michigan
Motorcycle(s): 2013 Ninja 300
It depends on from which side you are looking.
DISCLAIMER: I generally have no idea what I'm talking about.
Old July 11th, 2015, 02:26 PM   #3
Bob Marshall
From the flywheel side where the ign timing marks are
Old July 11th, 2015, 03:46 PM   #4
Turn the crankshaft only counter-clockwise.
You can rotate it using a tool via the plug on the left cover of the engine.
Welcome, Bob !!!
Old July 11th, 2015, 05:08 PM   #5
think of it this way, on nearly every 4 stroke engine, the exhaust end (front) pulls from top to bottom. so if you're on the left hand (clutch side) of the bike, its counter clockwise. if you're on the right hand (throttle side) its rotating clockwise.
Old May 14th, 2022, 07:16 AM   #6
bogiejr
bogiejr's Avatar
Crank rotation
Crazy, because the book incorrectly states to rotate it clockwise. Scary!
bogiejr is offline   Reply With Quote
Old May 14th, 2022, 12:36 PM   #7
petrolhead
Old mechanic here. If direction of rotation is unclear, dont dick around with timing.
Chain tensioner is on the side where chain travels up, the other side is the pulling side.
Jarno
petrolhead is offline   Reply With Quote
Old May 15th, 2022, 08:38 PM   #8
bogiejr
bogiejr's Avatar
Very good point!
Will Newgen crankshaft fit in my pregen? wankerboy 1986 - 2007 Ninja 250R Tech Talk 17 March 5th, 2015 04:17 PM
Broken rod and crankshaft drewsley 1986 - 2007 Ninja 250R Tech Talk 4 November 24th, 2014 04:27 PM
[webbikeworld.com] - Lazer SuperSkin is a Radical New Technology to Reduce Rotational Ninjette Newsbot Motorcycling News 0 February 7th, 2009 11:20 PM
[roadracingworld.com] - Only Mladin’s Crankshaft Was Checked After Sunday’s AMA S Ninjette Newsbot Motorcycling News 0 August 22nd, 2008 01:52 PM
[roadracingworld.com] - ‘Manufacture’ Of Mladin’s Crankshaft In Question Ninjette Newsbot Motorcycling News 0 August 22nd, 2008 12:19 PM
